Old 6th March 2013, 15:29   #181
Geje's Avatar
Default Re: MM550 XD NGCS - The War Horse
Originally Posted by sreejeshmp View Post
Read it once more, not off road "on road"
- Sreejesh
Sir, This is my first post as a BHPian,
I am not going for the 57" OKBJ and FFRA. It is the standard 550 front and rear Axles.
Originally Posted by sreejeshmp;
I personally know few from Coorg with 58" FC axles and 57"+53" axles on their 540s all are saying it good for Photography
This led me to the conclusion that it was not good Off roads. Thank you very much for your suggestions. I will soon be starting a New thread on building up my off roader.
Geje
Geje is offline   Reply With Quote
Old 11th March 2013, 10:01   #182
sreejeshmp's Avatar
Thanked: 576 Times
Geje
Geje,
Please don't call Me "Sir". There will not be much problem in off road with 57" OKBJ & 53" FFRA because I think It can articulate More on a C-section Chassis. But with 31" tyre you may need to cut your fender or suspension lift / Body lift to accommodate those tires which will leads to Bad handling on road.
- Sreejesh.
Saturday I got the jeep from Workshop with the service charge 6k.
Work Done -
Gasket Change
GB Overhauling
Steering work.
Changed tie rod end kit - 1450.00
Yesterday Morning drove the jeep to Coimbathur for registration.
At Prabhu's WorkShop.
Prabhu takes a test Drive. Now Prabhu's headache starts .
sreejeshmp is offline   (3) Thanks Reply With Quote
Old 11th March 2013, 23:46   #183
Jerrycan's Avatar
Thanked: 107 Times
Could have got it registered in January last, had you not taken it for the BAOTR. No worry, we'll get it regd at the earliest.
Btw, that's not my workshop, had my cousin seen this post, all the restorations will come to a stand still.
Prabhu
Jerrycan is offline   Reply With Quote
Old 14th March 2013, 13:35   #184
Thanked: 28 Times
@sreejeshmp
The final out come of the restoration is a Stunner, good choice of color congratulations . Would like to know the differential ratio your running?
Chengappa.
Timson is offline   Reply With Quote
Old 14th March 2013, 22:18   #185
sreejeshmp's Avatar
Thanked: 576 Times
Prabhu
If I couldn't take it to BAOTR, I can wait until next Monsoon. BTW thank you for allowing me to take the Jeep with that "For Reg.Temp /" Yellow sticker .
Originally Posted by Timson View Post
@sreejeshmp
Chengappa.
Not yet finished, SoftTop, custom bumpers,seats etc are waiting for the registration formalities. It should be 4.88 .
sreejeshmp is offline   (1) Thanks Reply With Quote
Old 15th March 2013, 13:11   #186
Jerrycan's Avatar
Thanked: 107 Times
Attachment 1060695
Attachment 1060696
The Jeep is Registered. That would be My FIRST NGCS 550 and the Only NGCS 550 to get Coimbatore Registration.The Registartion is at Coimbatore Central
And the No would be
TN 66 H 88xx / 89xx
There were around 150 vehicles at the RTA office, a majority of them were two wheelers. This was the 3rd vehicle after 2 Mini trucks to get Registered.
Total time Taken For Registration 15 days including the Preliminary Inspection before BAOTR
All the Best Sreejesh
Jerrycan is offline   (2) Thanks Reply With Quote
Old 15th March 2013, 14:32   #187
Geje's Avatar
Sreejesh,
Congratulations on getting it registered.
Will you let me take a test drive on your Vehicle, before you take it to Kerala ? I Checked the Jeep at Prabhu Anna's Workshop. Couldn't Meet him though. It has come out really good. Can you Please Share the total Cost of Restoration and Registration.
I planning to request Prabhu Anna to handle my rebuild.
Geje
Old 16th March 2013, 13:36   #188
sreejeshmp's Avatar
Thanked: 576 Times
Sreejesh,
Geje
Hi Geje,
I will be coming tomorrow (Sunday) to take the jeep back to Kerala so give me a call tomorrow for test Drive.Planning to reach there before 12 PM cos I need to buy an Oil pressure meter and D-Shackle. I need to calculate the total Cost I spend up to now. But it should be between 4.5-4.75L including registration and tyre.I think That Workshop is good enough for the Axle swap and 4WD Conversion.
- Sreejesh
Old 17th March 2013, 00:07   #189
Jerrycan's Avatar
Thanked: 107 Times
Number plates for the war horse.
Just a temporary measure to drive it back to Gods Own Country.
May be you should affix an IND no plate as per rules.
Got to drive the Jeep for a while.
Jerrycan is offline   (4) Thanks Reply With Quote
Old 19th March 2013, 21:18   #190
sreejeshmp's Avatar
Thanked: 576 Times
Took the delivery of Jeep from Prabhu after the paper works. I started around 8.45 PM from Coimbathur and reached Home at 12 O'Clock . Thanks to the Superb Handling of the NGCS Chassis ,taking turns at a speed of 70-80 is no more a problem (in case of a Jeep).
Now Need to re camber the leaf springs. any idea about the OE camber of NGCS 550 Leaf springs ?
- Sreejesh
sreejeshmp is offline   (2) Thanks Reply With Quote
Old 20th March 2013, 11:46   #191
r_nairtvm's Avatar
Thanked: 1,574 Times
Attachment 1063867
- Sreejesh
Sreejesh,
The Jeep looks nice.
In the above picture - the visuals of "Kani Konna Poovu" brought back a wiff of nostalgia and a reminder that "Vishu" is round the corner
Best Regards & Drive/Ride Safe
Ram
r_nairtvm is offline   (2) Thanks Reply With Quote
Old 21st March 2013, 14:21   #192
sreejeshmp's Avatar
Thanked: 576 Times
Did the leaf spring recambering to OE spec Changed all the leaf spring bushes. Did a ramp test from local service station.
Finally He Understand I am not going to give up , So started articulating with a light of Hope .
Old 21st March 2013, 14:40   #193
dhanushs's Avatar
Thanked: 4,504 Times
One big question: How did you use the ramp at the local service station for the 'articulation' test, without making the guys there think you are crazy!
- Sreejesh, as I mentioned, please do a test again with:
1) No stabilizer bar.
2) No stabilizer bar + No shocks
3) No stabilizer bar + No shocks + fewer leafsprings
After this, you might get some good pointers from experts here.
Old 21st March 2013, 16:17   #194
svsantosh's Avatar
Thanked: 1,444 Times
Hey, when did you finish the front bumper work? more pics plz.
Without shocks arti improves a lot but changes a ton of other thing. Stabilizer bar can be removed and wont make a diff! At least it didnt in my AG.
How many leafs was in a stock NGCS 500? 6 front, 5 back?
svsantosh is offline   Reply With Quote
Old 24th March 2013, 13:14   #195
dhanushs's Avatar
Sreejesh'e, here's a 60" jack mounted on the back of a jeep. . I think its not protrusive and looks fine? Whatsay?
PICS : The rare MM550. NGCS, 4WD & 1.8L PETROL svsantosh 4x4 Vehicles 58 25th February 2018 15:46
Presenting My 2005 NGCS MM550 BEAST. 4x4 cruiser 4x4 Vehicles 39 9th November 2011 13:50
Vento -- My Horse of Battle, Horse of Ballet! msprabhakar Test-Drives & Initial Ownership Reports 10 6th December 2010 09:06
