Old 24th March 2013, 15:07   #196
swastikviji's Avatar
Thanked: 158 Times
Default Re: MM550 XD NGCS - The War Horse
Sreejesh'e, here's a 60" jack mounted on the back of a jeep. . I think its not protrusive and looks fine? Whatsay?
Dhanush this is my Jeep, 60" Hi-lift in back attracts unwanted peoples attention from opposite traffic, lot of drivers turn back to see what is that thing projected from top, after two years use i chopped that Hi-lift to match Jeep Top Height,
swastikviji is offline   (1) Thanks Reply With Quote
Old 25th March 2013, 11:48   #197
sreejeshmp's Avatar
Thanked: 571 Times
Default MM 550 XD NGCS - The War Horse
Dhanush,
I found another place to Mount the Hi-Lift Jack,Almost finished the Fabrication Will post the pics.
Yesterday we took the Jeep to Offroad, It performed better after the leaf spring cambering.
- Sreejesh
sreejeshmp is offline   (6) Thanks Reply With Quote
Old 25th March 2013, 16:54   #198
sreejeshmp's Avatar
Thanked: 571 Times
Default MM550 XD NGCS - Hi -Lift Jack Mount
This is how I am going to Mount the 60" Hi Lift Jack.
- Sreejesh
sreejeshmp is offline   (3) Thanks Reply With Quote
Old 26th March 2013, 06:19   #199
madhkris's Avatar
Thanked: 70 Times
Wow Sreejesh the Chocolate Jeep is awesome and loved the 2nd pic. One query though: How do you plan to fix the Hi-lift jack there? Will those rods bear the weight? I guess you can also consider placing it in front of the front windscreen as on many Hyderabad Jeeps.
madhkris is offline   Reply With Quote
Old 3rd April 2013, 12:12   #200
Thanked: 69 Times
Sreejesh, i think I saw your jeep on Thrissur - Angamali stretch on Thursday, 28th March.
Was it you driving it? Took a little time to realize that it might be you.
ArunV is offline   Reply With Quote
Old 4th April 2013, 15:54   #201
sreejeshmp's Avatar
Thanked: 571 Times
Hi Arun,
Not this Jeep. May be My old Jeep ,Its in Trissur Now.
- Sreejesh
sreejeshmp is offline   Reply With Quote
Old 23rd April 2013, 20:53   #202
sreejeshmp's Avatar
Thanked: 571 Times
Default Custom DIY Hi-Lift jack Mount for my NGCS
I used a 1.25" GI pipe for the Mount frame (Got from our factory so free of cost) got it bend from a local industries Rs.30.00 .
Base drawing for the plate for bracket frame. Cut it using a Cutting wheel.
Welded the base plate to the pipe frame and checked the alignments .
My school mate Mujeeb (Advantage of studying in Government School ) helping me to get a proper welding (My welding made enough holes on the pipe) .
Got a spray paint bottle from our SuperMarket , Costs Rs.90.00 Primer Rs.50,Brush Rs 15.00. Grinned the welded surfaces.
Applied 2 cot of primer using Brush
Applied 2 cot of Black spray paint.
Finally fixed the Hi-Lift jack
Custom cover to protect from rain and dust.
Now time for the Suspension Modification. Rajith Brought me a set of Surprise .
sreejeshmp is offline   (1) Thanks Reply With Quote
Old 24th April 2013, 10:02   #203
Thanked: 822 Times
Small suggestion.
This can be added later & will provide you some space to mount some extra accessories .
Here the proposed addition bracket for your Jack carrier . It will also strengthen the existing bracket & ease the load on the top pipes of the hood .
Here ( Not to scale of course )
Pic credit to you only .
Sudarshan
Sudarshan is offline   (2) Thanks Reply With Quote
Old 24th April 2013, 12:59   #204
svsantosh's Avatar
Thanked: 1,392 Times
Sree, great outcome! as I said earlier, just loose-steel-twine it up for a few weeks while testing.
bhai - giving PS a run for its money with MSpaint
svsantosh is offline   Reply With Quote
Old 1st May 2013, 15:37   #205
sreejeshmp's Avatar
Thanked: 571 Times
Default MM 550 XD NGCS - Turbo Intercooler .
Finally decided to do an experiment before the engine swap. A turbo Charger with Intercooler .
sreejeshmp is offline   (5) Thanks Reply With Quote
Old 8th May 2013, 21:43   #206
sreejeshmp's Avatar
Thanked: 571 Times
Experiment on Suspension Continues. Now articulates more than the stock NGCS with Custom Leaf springs and Shackle.
Making custom washers for new rear leaf springs.
New leaf springs
After suspension tuning , But not satisfied with front Springs.
does that difference in track width preventing the articulation of front Springs ?? I seriously doubt. So next is a Spacer.
Innova seats for more comfort and better seating position, visibility
Old 5th June 2013, 16:31   #207
sreejeshmp's Avatar
Thanked: 571 Times
Jeep testing the new road through our land. Yes it articulates perfectly and no wheel on the air .
sreejeshmp is offline   (4) Thanks Reply With Quote
Old 11th June 2013, 13:59   #208
anzrulz555's Avatar
@sreejeshmp: Have you managed to install the Turbo kit and inter cooler unit yet ?
anzrulz555 is offline   Reply With Quote
Old 15th June 2013, 17:05   #209
sreejeshmp's Avatar
Thanked: 571 Times
Not yet. Wayanad OTR is coming so no time for experiments http://www.team-bhp.com/forum/4x4-ex...tr-2013-a.html (Wayanad Annual Monsoon OTR - 2013!).
Now going for a 43/8 (5.38:1) diff with LSD and a custom exhaust muffler.
- Sreejesh
Old 23rd June 2013, 17:11   #210
sreejeshmp's Avatar
Thanked: 571 Times
Bought a set of 43/8 crown and pinion and a Muffler. Silencer pipe for rerouting the stock setup.
PICS : The rare MM550. NGCS, 4WD & 1.8L PETROL svsantosh 4x4 Vehicles 55 2nd November 2015 13:24
Presenting My 2005 NGCS MM550 BEAST. 4x4 cruiser 4x4 Vehicles 39 9th November 2011 13:50
Vento -- My Horse of Battle, Horse of Ballet! msprabhakar Test-Drives & Initial Ownership Reports 10 6th December 2010 09:06
