Old 1st July 2013, 15:22   #211
sreejeshmp's Avatar
Thanked: 576 Times
Default Re: MM550 XD NGCS - The War Horse
Moved the license plate to a safer place
FP serviced & Nozzles replaced - 6100.00
Replaced the lift Pump & top of the Diesel filter Assy - 1025.00
Crown & pinion Changed to 43/8 (5.38) ratio.
tested in Wayanad OTR recce Found the rev is too low & black smoke. Pump was little advance in setting.
Today morning tuned the FP perfectly and now It runs fine, The Diffratio with 31" tyre really makes difference in on/off road .
sreejeshmp is offline   (4) Thanks Reply With Quote
Old 1st July 2013, 16:03   #212
svsantosh's Avatar
Thanked: 1,444 Times
Why was the nozzles replaced (beyond serviceable)?
How much was the 5.38 conversion cost? Crown? Pinion? Labor?
svsantosh is offline   Reply With Quote
Old 1st July 2013, 22:16   #213
dhanushs's Avatar
Thanked: 4,504 Times
Very eager to see what difference the 5.38 makes!
btw, nice capture!
Old 1st July 2013, 23:15   #214
vinod_nookala's Avatar
Thanked: 416 Times
Laying my hands on NGCS ARMY DI turbo at Mahindra Adventure. After seeing your thread cant wait to drive it off-road
vinod_nookala is offline   Reply With Quote
Old 2nd July 2013, 09:04   #215
sreejeshmp's Avatar
Thanked: 576 Times
SVS two nozzles where stuck , serviceable but not to the best So replaced all the four. I exchanged My old 4.88 Crown & pinion with old LSD(Now works like an open diff) + 1000.00 for the 5.38 set with one prop shaft flange(Pinion milling & flange is different in NGCS (new model)). labor charge was 2500.00 for FP Servicing,Differential work, general service including Oil change etc.
btw, nice capture!
lets test it on next recce with Jeevan.
That Legend is really a Legend, I still remember the Wayanad MGE recce with you in that MM Legend, that too with that JK Elanzoo tyre .
sreejeshmp is offline   (1) Thanks Reply With Quote
Old 2nd July 2013, 21:04   #216
Thanked: 416 Times
No I am not talking about legend. I am talking about NGCS Army 550 with DI turbo engine and 4.3 ratio
vinod_nookala is offline   (1) Thanks Reply With Quote
Old 8th July 2013, 12:06   #217
sreejeshmp's Avatar
Thanked: 576 Times
After BAOTR I was really disappointed with the Articulation & NGT520 + 4.88 + 31" tyre It was just like a Gypsy with jeep Body.
Now I am Happy after lot of experiments and proper tuning of Engine/FP, Suspension,Differential Ratio.Now Its a wonderful Machine Both On road and Offroad.
few pics from the Wayanad Monsoon Offroad Recce.
Slush,Slush & More Slush finally got stuck :- Need LSD / MLD
At articulation pit
I think the Suspension articulation is better than the articulation with Chassis flex. There is no strain on Chassis/Body Thank you Tini .
sreejeshmp is offline   (6) Thanks Reply With Quote
Old 8th July 2013, 12:27   #218
AVR
AVR's Avatar
Thanked: 531 Times
Sreejesh,
Can you elaborate on what you've done with your suspension? What leaf-springs and shackles did you use? Shocks?
Look forward to more details.
Cheers,
Adi
AVR is offline   (1) Thanks Reply With Quote
Old 8th July 2013, 13:44   #219
sreejeshmp's Avatar
Thanked: 576 Times
Originally Posted by AVR View Post
Sreejesh,
Cheers,
Adi
Adi,
Rear is from Thar CRDe & front is still in R&D I will update the details after testing with few more changes. Shocks are same NGCS OE.
- Sreejesh
sreejeshmp is offline   (5) Thanks Reply With Quote
Old 9th July 2013, 06:09   #220
dhanushs's Avatar
At articulation pit
For the first time in Wayanad.
A huge change from Bangalore OTR till now.. Still way more to go! and, No doubt it is the better option. But, what is the limit? I guess we will wait and see!
Old 9th July 2013, 10:04   #221
svsantosh's Avatar
I am surely interested in the rear changes you have done. The stock NGCS Armada Grand rear leaf stack is very stiff and hardly moves!!
Can you detail out the rear changes to be done, part by part?
Old 9th July 2013, 10:29   #222
Rajith's Avatar
Thanked: 407 Times
Interesting.let's see more.
I'm also doing similar .
Rajith is offline   Reply With Quote
Old 9th July 2013, 18:07   #223
sreejeshmp's Avatar
Thanked: 576 Times
Thank you Rajith for giving your Thar's leaf spring for testing & arranging almost brand new Spring set from Your friend . But why you used Armada grand springs on front ?
- Sreejesh
sreejeshmp is offline   Reply With Quote
Old 9th July 2013, 18:11   #224
Rajith's Avatar
Thanked: 407 Times
- Sreejesh
Except m&m military ngcs 4wd all other ngcs 4wd range with solid axles are having same part num for spring assy and brackets.More over it was recommended to me by my reliable ex doctor from plant.
Old 2nd August 2013, 14:28   #225
sreejeshmp's Avatar
Thanked: 576 Times
After Wayanad AOTR Not got enough time to Drive My jeep. Just Did a Water service and kept in Garage. two days back when I try to start the jeep It shows strange behavior after a full crank the Starting motor Bendix comes back & Motor keeps rotating, Started the jeep by pulling using my Bolero and Starting motor serviced Bendix was fine but the fork was the problem Changed The fork & Brushes (Rs 1024.00 includes Brush,servicing & fork).
Now its time for a complete Transfer case overhaul. Can't drive with the pathetic Humming Noise .
On Duty at Wayanad AOTR
sreejeshmp is offline   (3) Thanks Reply With Quote
PICS : The rare MM550. NGCS, 4WD & 1.8L PETROL svsantosh 4x4 Vehicles 58 25th February 2018 15:46
Presenting My 2005 NGCS MM550 BEAST. 4x4 cruiser 4x4 Vehicles 39 9th November 2011 13:50
Vento -- My Horse of Battle, Horse of Ballet! msprabhakar Test-Drives & Initial Ownership Reports 10 6th December 2010 09:06
