Old 3rd May 2014, 16:00   #301
prabhuav's Avatar
Thanked: 112 Times
Default Re: MM550 XD NGCS - The War Horse
the 30 spline semi floating is bullet proof.. current heavy duty pickup from mahindra is running it
prabhuav is offline   Reply With Quote
Old 3rd May 2014, 16:22   #302
4x4addict's Avatar
Thanked: 2,513 Times
I would agree with sturdy but bullet proof is a stretch. I live in Ooty, and I have seen many of these pick ups on it side.
4x4addict is offline   Reply With Quote
Old 7th May 2014, 16:14   #303
Thanked: 29 Times
Sreejesh and other experts, I want to know if it is difficult to source the front shaft for NGCS MM550 (with NGT520). I am in need of one. Any hints what I should be asking in Automobile stores ?
Also since it is said that NGT530 is improved version of NGT520. Will the front shaft length remain same for both ?
sad:) is offline   Reply With Quote
Old 7th May 2014, 19:15   #304
Thanked: 4,673 Times
Originally Posted by sad:) View Post
Since it is said that NGT530 is improved version of NGT520. Will the front shaft length remain same for both?
Dear Sad - NGT 530 and NGT520 are completely different transmissions, please go below the vehicles and see naa! .
Torque carrying capacity of NGT530 is more than that of NGT520, therefore NEF / mHawk engined vehicles have NGT530 only. NGT530R (currently used with tunnel casing) is a derivative of the NGT530 (split casing) which itself is derived out of the Peugeot BA10 of 1981, which was originally used by Peugeot on their J9 vans with remote shift.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   Reply With Quote
Old 8th May 2014, 14:49   #305
Thanked: 29 Times
Behram Sir, Thanks for the information.
I purchased a MM550 NGCS recently, I am totally new to this Jeep thing and it is just the begining phase for me. I am gathering all the useful information(theory) that Team BHP has to offer.
I was in a situation where I got a front drive shaft but later realized that is too short for the MM550 NGCS that I have. That was mainly because the gearbox housing of NGT520 (it is much longer). So I wanted to know if any other Mahindra models front shaft can be used. If i can get a bolero or scorpio or Thar or any other model front drive shaft and fit it directly.
I will try to go below some of the vehicles with a measurement tape to check if the shaft length match
This would be easy if i join in on OTRs. Getting below the vehicle parked on street would be dangerous..
Sada.
Old 8th May 2014, 15:14   #306
I got a front drive shaft but later realized that is too short for the MM550 NGCS that I have. That was mainly because the gearbox housing of NGT520 (it is much longer). So I wanted to know if any other Mahindra models front shaft can be used. Sada.
Dear Sada - I presume you mean "front propeller shaft". Please let me know what engine you are running on your MM550 NGCS. 99% it will be MDI3200, then Thar DI propeller shaft should slot in perfectly because MDI3200 / NGT520 layout is common. If you are running XD3, then you may be running NGT530 and not NGT520. Do post some photographs, it will help me to decide.
Best regards,
Behram Dhabhar
Old 8th May 2014, 15:41   #307
svsantosh's Avatar
Thanked: 1,392 Times
If you have a shaft thats few inches short, just cut it and make it longer by welding a steel pipe of same dia. Any lathe/mechanic can do it for you. Lathe - because they can maintain the trueness of the pipe, any bend will cause wobbling and failure of few important stuff.
svsantosh is offline   Reply With Quote
Old 9th May 2014, 14:00   #308
Thanked: 29 Times
Behram Sir,
I was under assumption the it is a XD3 engine with NGT520. I will update pics to clarify.
Santosh Sir,
I was also suggested that the shaft can be cut and extended, but i doubt how reliable that would be. That would be the last option for me.
I actually wanted to start a new thread on my MM550, but since I have brought it, I am hardly finding any time to start up a thread.
Old 9th May 2014, 22:14   #309
sreejeshmp's Avatar
Thanked: 571 Times
Originally Posted by Shubhendra View Post
Sreejesh Ji,
Are you sure you want to move to BA10 from NGT520? last evening i was discussing below configuration with Arka
Scorpio gear drive engine, BA10GB and BW TC (manual shifter)
Arka explained very nicely on the shortcomings of BA10 and its fragile nature. Just wanted to let you so that you make an informed decision.
Shubhendra Singh
BA10 is the only option I have now to put a 30 spline center offset axle. or I may put NGT530 and continue R&D to make a Manuel shift BW.
clarify?! IFS/CV type diffs on you jeep? What are you upto?
SVS only the rear diff with scorpio old Diff ratio.
dai - he is putting the 30 spline rear diff - so that he can use the army LSD.
right koya??
yes Sir. Taking a VFM short cut .
Basically giving up a fully floating rear axle to semi floating to put LSD?
Yes Tini , Cheap and best like two birds in one shot.
Both are different GB uses Different TC so length may change.
Don't do cut and weld on Shaft. NGT530 never came on army NGCS.
- Sreejesh
sreejeshmp is offline   Reply With Quote
Old 13th May 2014, 13:26   #310
Thanked: 29 Times
- Sreejesh
Behram Sir,
Here are some pictures from below the vehicle. As Srejeesh said about NGCS, it is a NGT520 gearbox..and here the pics of the engine. I measured the length of the propeller shaft from the diff to the TC it measures approx 77cm or 30 inch. Does this fit to any other mahindra vehicles from propeller shaft ?
Sada.
sad:) is offline   (1) Thanks Reply With Quote
Old 14th May 2014, 17:14   #311
Shubhendra's Avatar
Thanked: 1,178 Times
- Sreejesh
Sreejesh Ji,
IIRC NGT520/530 have center offset rear output or i am missing anything ?
Also during my hunt for chain drive SZ+ engine, one of engine dealer told me that all gear drive and chain drive engines came with BA10 only, is it correct or dealer is taking me for a ride ?
Shubhendra Singh
Shubhendra is online now   Reply With Quote
Old 14th May 2014, 18:32   #312
During my hunt for chain drive SZ+ engine, one of engine dealer told me that all gear drive and chain drive engines came with BA10 only, is it correct or dealer is taking me for a ride? Shubhendra Singh
Dear Shubhendra - SZ+ or NEF (new engine family) engine came in Scorpio. Scorpio came with NGT530 transmission till 2007, then it came with NGT530R transmission. Both NGT530 and NGT530R are derivatives of the BA10 transmission only. I don't think dealer has explained you properly. You can use either NGT530 or NGT530R because both have the torque carrying capacity to match the NEF engine, but please ensure that you use the direct shift version. BA10s with remote shift versions are also floating around the various chor bazaars, don't get conned. Best is to remove the complete drivetrain from a total loss Scorpio.
By the way, don't buy the gear drive engine at all, you will be inviting trouble forever, the gears get worn out very quickly. They also make a lot of noise! Gear drive engine does not have separate power steering pump, that way you can visually differentiate.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   (2) Thanks Reply With Quote
Old 14th May 2014, 18:52   #313
Shubhendra's Avatar
Dear Shubhendra -
Best regards,
Behram Dhabhar
Guru Ji,
I was eagerly waiting for you to pitch in. Let me tell you my problem statement:
I have Bolero LX (XD3P, AC+PS, BA-10 GB with manual shifter borg warner transfer case), as per Odometer it has run more than 1.6 lac kms and as per last owner engine has never been overhauled. though i have replaced fuel pump and vehicle is as of now working fine but i am anticipating engine overhaul in near future. after listening so many horror stories of XD3P builds and personally seen them, i am not very convinced to rebuild this engine. I am also not looking for everyone's favorite Di TC engine as i dont want that noisy engine which can not even touch speed of 100 +. What option you suggest for my bolero ?
I want a vehicle which can do 110 + throughout the day, should have Mahindra engine with torque to help me in offroad OTRs as well. BTW, i am using another XD3P bolero and other than pathetic performance on highway it can do almost everything which Thar does ( keeping in mind the LWB of vehicle)
Shubhendra Singh
Old 16th May 2014, 11:09   #314
prabhuav's Avatar
Thanked: 112 Times
best option , buy a total loss scorpio with the sz+ engine and the NGT 530 GB. swap the rear housing ,the main shaft and the transfer case of the BA10 onto the NGT 530..
Presto you have 4wd NGT530.. This is what allan adn beboy did on their builds..
i would also recommend using the rear diff off the scorpio as well
Now you have a bullet proof truck
prabhuav is offline   (1) Thanks Reply With Quote
Old 16th May 2014, 11:41   #315
Shubhendra's Avatar
Prabh Anna,
This is what i have in my mind, but i was inclined to gear drive SZ engine due to lack of vitamin M. Is gear drive engine is so bad not worth the effort ?
What is the advantage of rear diff of scorpio ?
Shubhendra Singh
PICS : The rare MM550. NGCS, 4WD & 1.8L PETROL svsantosh 4x4 Vehicles 55 2nd November 2015 13:24
Presenting My 2005 NGCS MM550 BEAST. 4x4 cruiser 4x4 Vehicles 39 9th November 2011 13:50
Vento -- My Horse of Battle, Horse of Ballet! msprabhakar Test-Drives & Initial Ownership Reports 10 6th December 2010 09:06
