Old 21st June 2014, 18:36   #61
wanderernomad's Avatar
Thanked: 789 Times
Default re: A Mahindra CJ500 DP and a custom made Expedition Trailer
The work is progressing well and the entire front end is complete in respect of axles, bushes, spring leafs, brake shoes and brake linings. Work is now on the rear axles. Only the front two shockers have been changed with Escorts make as Gabriel were not available. Some body work will also be required at the rear panels and on the metal plate beneath the diesel tank. The pedals have come from the lathe and have been fitted. An extra tube has been fitted around the ball of the front axles which according to the mechanic eliminates the death wobble. Gurus?
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140621_170333695.jpg
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140621_170341753.jpg
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140621_171528461.jpg
wanderernomad is offline   Reply With Quote
Old 21st June 2014, 19:28   #62
Thanked: 789 Times
Sorry but the connection went off before I could edit the previous post.
The radiator has some markings of madras heat transfer. Maybe its the original radiator still doing the duty? The remaining pictures:
PS: I just noted that the mechanic has got the rear shockers for fitting up front. Are they all same or different?
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140621_165824998.jpg
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140621_165216533.jpg
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140621_165304747.jpg
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140621_170018797.jpg
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140621_163211882.jpg
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140621_164451242.jpg
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140621_164240170.jpg
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140621_164249059.jpg
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140621_164600542.jpg
Old 22nd June 2014, 08:49   #63
dhanushs's Avatar
Thanked: 4,346 Times
They are slightly longer shocks, but, should do the job better.
Old 25th June 2014, 17:42   #64
Thanked: 789 Times
The mechanical works are almost over and now electrical works have started. Also some tinkering work that needs to be done are to be started. The points here are:
1. To retain the half doors but the frame is higher than the tub body line. Suggestions?
2. How to frame a spare tyre carrier separate from the rear door so that even the rear door is functional? Or we weld the frame to the chassis and do away with the rear door functionality?
The pictures:
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140625_165022688.jpg
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140625_165032811.jpg
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140625_165106991.jpg
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140625_165919745.jpg
Old 25th June 2014, 18:33   #65
Thanked: 789 Times
The few rough hand drawings that I have in mind are as follows:
Old 26th June 2014, 14:50   #66
Thanked: 789 Times
The brake master cylinder service kit cannot be sourced and the mechanic says it has to be changed. Should we change it to the newer double cylinder one? What are the pros and cons? Will the change require any more adaptations to be made to the brake pipes and lines?
Old 28th June 2014, 18:09   #67
Thanked: 789 Times
Purchased the double master cylinder for brakes. But then decided to explore the servo assisted brake cylinder. Got an old one from the Marshall but the mechanic says cannot be done on my jeep for two reasons:
1. There is not enough space in the engine bay and the foot well to accommodate the servo booster mechanism.
2. It requires a hanging pedal and won't work with the floor one. Any adaptation is bound to be unreliable plus the entire brake system is designed for the low pressure mechanical type while with the servo assist, it becomes high pressure hydraulic?
So have to let go. Here are the pictures of the old master cylinder and the new one purchased. Also the mounting rack in the foot well required for the hanging pedals and the firewall which is supposed to hold the assembly and cylinder.
Also in the picture the rear seat is removed to be set further ahead and lower to accommodate the swing canopy bars.
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140628_121303294.jpg
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140628_121310525.jpg
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140628_163050387.jpg
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140628_163101721.jpg
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140628_163120338.jpg
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140628_163018650.jpg
A Mahindra CJ500 DP and a custom made Expedition Trailer-img_20140628_163037548.jpg
Old 28th June 2014, 22:02   #68
Thanked: 2,330 Times
If you stick to drum brakes, you don't need the servo. In fact, I would strongly recommend against a servo if the other components are (drums -> discs) are not changed as well. Servo will also mean an alternator with a vacuum pump.
Something about your tailgate picture is bothering me. Can't put my finger on it.
Check the battery support, and spare wheel mounting bracket for cracks.
Sutripta
Old 28th June 2014, 22:59   #69
Thanked: 789 Times
Sutripta
Dada, we have the alternator with vacuum pump but its the matter of changing everything right upto the lines that has stopped us from being so adventurous for now. The sag towards the right side in the tail gate or the upturned rear bench in the background? In any case the battery support is being done afresh as adding the alternator has changed the space dynamics in the engine bay.
Old 29th June 2014, 22:03   #70
In my opinion the vehicle would have become almost undrivable. Walking on eggshells all the time.
Neither.
Sutripta
Old 29th June 2014, 23:10   #71
Thanked: 789 Times
Do we get bed liners in the local market like monstaliner? Details at www.monstaliner.com. If not, can we have it brought in baggage from US. One gallon would be suffice for the 500 body tub? Any body having an experience of a similar product here?
Old 30th June 2014, 10:52   #72
Shubhendra's Avatar
Thanked: 1,178 Times
I have bought few cans of Rust'O'leum bed liner and anty rust coating on few occasions from US of A. I have no idea about monstaliner but Rust'O'Leum are not so good.
Shubhendra
Shubhendra is offline   (1) Thanks Reply With Quote
Old 30th June 2014, 15:30   #73
Thanked: 789 Times
Shubhendra
Thanks mate, so it was not worth the effort? Should I just get the tub and chassis spray painted then?
Any ideas about the paint scheme? Desert Tan is what I am leaning towards or a deep shade of blue like in the polo.
Old 30th June 2014, 15:47   #74
Shubhendra's Avatar
Why dont you try Wurth products, i have heard good reviews about them.
You can even think of reusing existing color scheme, IMO it would look good.
Shubhendra
Shubhendra is offline   Reply With Quote
Old 30th June 2014, 19:43   #75
Thanked: 789 Times
Shubhendra
But it keeps reminding of the sarkaari ancestry and I would like to look it a bit more personal. tough I know that a darker shade would mask its longer looks while a lighter shade would make it look even larger.
Grand Vitara gets custom made skid plates Samurai 4x4 Technical 107 11th October 2016 10:47
Project: 1987 Mahindra CJ500 4x4. Turbo & more drsamuelk 4x4 Vehicles 17 30th July 2016 15:25
Mumbai Cops on Custom made Enfields iron Motorbikes 1 14th April 2014 18:45
Report & Pics: Mahindra Navistar MN25 Tipper & MN40 Tractor Trailer Launch Stratos Commercial Vehicles 17 3rd April 2013 20:17
