Old 29th March 2015, 23:29   #46
manveet's Avatar
Thanked: 585 Times
Default Re: Never thought I'd build a Jeep! My MM540 story
Hi Everyone, went in for a tire upgrade over the weekend, from 31 inches to 35 inches. Two pictures attached for reference.
I think the Jeep will need more chopping of the body to fully articulate on these wheels. Rear is OK, but there is only a 1 inch gap between the front tire and front wheel-well on full side-lock.
But this is just from observation - city driving has not thrown up any issues but the real test will happen only during the next OTR.
Oh, and I forgot. My mechanic had forgotten to fully connect the exhaust and it was rattling but I kind of liked the throaty growl so have just removed all the "dholki's" and now just have a two feet straight pioe from the exhaust manifold to side of the body. It sounds damn nice now but any effect on performance? Does the lack of back-pressure reduce the pick-up in any way or has the free-flow improved the pick-up?
Any queries, suggestions or inputs around this or in general are most welcome.
Cheers!
p.s.
took the Jeep out for a spin today with my wifey riding shotgun, the Jeep is a head-turner for sure - the tires have made a hell lot of a difference. Lot of people - kids, women, men- all age brackets - stopped to stare, pass positive comments, give "thumbs up" - was good fun. And it hasn't even been painted yet!
manveet is offline   (4) Thanks Reply With Quote
Old 30th March 2015, 18:00   #47
Hi Manveet,
I have been following your thread and I must say, It has been a pleasure to follow your systematic and functionality oriented mods.
With your comments about further chopping the body to accommodate the larger tires, I just wanted to know what is the front and rear track of the axles that you are using on this Jeep.?
I would personally go for a wider axle width rather that further chopping the body as it would serve two purposes, firstly, it would increase the gap during full lock on the steering.
Secondly, with the raising of the Center of Gravity with the larger tires, it would not be a bad idea to increase the track width to make the Jeep more planted and stable.
Keep up the good work.
L.o.R
lifeoffroad is offline   (1) Thanks Reply With Quote
Old 30th March 2015, 20:00   #48
manveet's Avatar
Thanked: 585 Times
Originally Posted by Manveet
.. . around this time both axles were replaced by wider Mahindra Bolero Pik-Up's axles. Not sure what the width is though - any info on that will be most appreciated
Good question. I had asked the same question in my second post on this thread but nobody answered. The previous owner had replaced the 540 axles with wider axles of the Pik-Up, not sure of the exact width though. Any idea of what the Pik-Up's axle width is? I hate not knowing the technical specs of my own vehicle :(
Both points valid and taken.
I have been following your thread and I must say, it has been a pleasure to follow your systematic and functionality oriented mods.
L.o.R
Thanks, glad you like it. And welcome to TBHP, hope to see you around here more often. Cheers!
manveet is offline   Reply With Quote
Old 30th March 2015, 20:24   #49
I am not certain, but AFAIK for Mahindra Maxx/Pickup series:
Front Track: 57"
Rear Track: 59"
You should be able to roughly identify them by simply measuring the distance between the Brake drums.
But if this is the case, there is no wider Mahindra axle that you can use. The axles for the pickup are the widest of the lot.
But considering that the issue is on full lock, if the 1" gap between the wheel and the fender or between wheel and the inner wheel well/ ladder chassis frame.
This should govern where to chop from.
Also, Before chopping, do try to measure the gaps on full lock+full flex of the suspension. Try using something like a RTI ramp, or if that is unavailable, try to drive on one side of a car wash service ramp.
This number would be different from when the Jeep is on flat ground.
L.o.R
Old 31st March 2015, 11:15   #50
Shubhendra's Avatar
Thanked: 1,178 Times
Please refer below list of width of different diffs in different jeeps over last few decades
1) CJ3B/4A - 48.5"
2) MM540/550, CL500 - 51"
3) NGCS (550, Thar CRDe, Bolero, pickup etc) - 57" front and 53" rear
4) NGCS (Thar Di and NGCS Major) - 53"
5) Mahindra FC - 58"
Manveet Ji: most probably your front diffs are 57" OKBJ and rear are 53 FFRA.
PS: Credit goes to Arka for above information.
Shubhendra Singh
Shubhendra is offline   (1) Thanks Reply With Quote
Old 31st March 2015, 11:26   #51
manveet's Avatar
Thanked: 585 Times
Shubhendra Singh
So I knew what OKBJ (Open Knuckle Ball Joint) is. Am sure this is what I have. And this is from the Pik-Up and not FC, so must be 57". Front is sorted.
Now about the Rear. Had no idea what FFRA was. Google got me here - http://www.team-bhp.com/forum/4x4-ve...-complete.html (It's a 'Jeep' Thing!" - Army Spec MM550 - Restoration in Bangalore - PHASE 1 COMPLETE)
So now how do I figure if I have Full Floating Rear Axle or Semi Floating Rear Axle? And about the width, there was an each side 2" track difference evident on the 31" wheels but with the new 35' wheels, it's difficult to say. Any specific photo I should take and share which will resolve the width and FFRA aspect w.r.t. the rear axle?
Old 31st March 2015, 11:37   #52
Shubhendra's Avatar
Manveet Ji,
FFRA have double bearing setup. refer below pic of you jeep and area which is circled in black, this is how you identify FFRA.
To identify SFRA, refer the link which you had posted in your previous response and you may see just a small red cap.
i can confidently say that your rear diff is 53" by looking into few picture posted in previous pages.
SHubhendra Singh
Old 31st March 2015, 16:16   #53
manveet's Avatar
Thanked: 585 Times
But considering that the issue is on full lock, if the 1" gap between the wheel and the fender or between wheel and the inner wheel well/ ladder chassis frame. This should govern where to chop from.
The 1 inch gap is between wheel and fender, this pic will give you clarity - I have hashed out the area that needs to be chopped - solution looks simple to execute and I don't foresee any issue.
Also, Before chopping, do try to measure the gaps on full lock+full flex of the suspension. Try using something like a RTI ramp, or if that is unavailable, try to drive on one side of a car wash service ramp.This number would be different from when the Jeep is on flat ground.
Thanks, point taken. Will try this out during the next OTR. Like mentioned earlier, front is sorted, however I am now more worried about the rear. Here is my current setup - do you guys see an issue in the rear? If the tire articulates in the direction of the arrow then I'm safe but if it goes vertically up, then am in a soup as there is no more space to chop, so I may need to resort to spacers.
manveet is offline   (1) Thanks Reply With Quote
Old 31st March 2015, 21:11   #54
Attachment 1355899
That is a good question.
Ideally, the wheel travels in a curved trajectory kinda like what you have drawn. But having said that, I still feel that the best course of action for you would be to max out the suspension and identify the problem areas.
Once that has been done, you can have a few options to choose from depending upon the areas identified.
For example, a simple body lift would increase clearances all around. And with an extreme rig as yours, I would definitely not rule out SPOA option either.
Out of curiosity, what was the price for the 35 inchers?
L.o.R
lifeoffroad is offline   Reply With Quote
Old 7th April 2015, 22:01   #55
manveet's Avatar
Thanked: 585 Times
So deposited the Jeep to denter once again. Moving the rear shackles and hence rear axle back by about 4.5 inches to make space for the rear wheel to articulate; this entails replacing the shortened pipes with longer ones. Chopping off 3-4 inches from the front fender to create some space there as well.
Somewhat OT : Any idea what is the optimal gear ratio on the MDI Turbo and 35" wheels should be, application a mix of cruising and low-end torque.
I have been told my XD3P comes with 4.88 ratio - I feel my low-end torque has reduced after moving to 35 inches, but this would improve once I move to the DI turbo due to its different dynamics - so don't need to change the crown-pinion right now. Is this understanding correct?
These retail at about 16K-17K per tire.
Old 8th April 2015, 10:50   #56
Shubhendra's Avatar
[quote=manveet;3680626]
QUOTE]
Manveet Ji,
Switch to 4.27 to reach 70-80 on highway and have good low end torque (Di has loads of torque anyways) for offroading.
Shubhendra
Shubhendra is offline   Reply With Quote
Old 8th April 2015, 12:52   #57
[quote=Shubhendra;3680861]
QUOTE]
Manveet Ji,
Shubhendra
Although technically Shubhendra sir is right but there is a certain amount of personal preference and driving style that applies to it.
I'd say that try a couple of otrs after the engine transplant and see how it suits you. Gear up or gear down as per your personal choice.
L.o.R
Old 8th April 2015, 20:05   #58
manveet's Avatar
Thanked: 585 Times
Manveet Ji,
In your opinion my current ratio is 4.88. Is that correct?
Point taken. Why waste money by changing things twice. I'll push this change to post-engine transplant.
Especially if Shubhendra can confirm that I am currently on 4.88.
Old 9th April 2015, 10:32   #59
Shubhendra's Avatar
Manveet Ji,
550 used to come with 4.88 so there is a high possibility that its 4.88, i can not guarantee as too many things have changed in your Jeep and most of Jeeps in general get played with over a period of time. I have seen MM Classic with 4.27 whereas it should have been 5.38 and owner didnt have idea.....
[quote=lifeoffroad;3680985]
SIR,
I am not sir, neither i have theoretical knowledge nor i am aged enough
But your point definitely makes sense to try and match crown pinion ratio. If someone dont mind limited highway speed (60-65 kmph), 4.88 in Di engine is killer for rock crawling
Shubhendra Singh
Old 10th April 2015, 01:40   #60
[quote]
SIR,
Shubhendra Singh
Point taken Shubhendra,
No Sir from now on Sir.
With the kinda mods Manveet is undertaking on this Jeep, I would not want to take it over 70 Kmph on the highway anyways, at least not with the standard brakes, steering and suspension geometry.
Too unsafe and unpredictable at speeds above that for our roads.
It is a purpose built offroader. Which brings me to the question:
@manveet:
When you started this project, did you have a certain type of offroading in mind? If so, what was it?
I ask this because in the world of purpose built offroaders, the design approach would be different for different terrains and events.
For Example, a rig designed for Mud bogging would not fair well on rock crawling trails and vis a versa.
Would love to know your thoughts before starting this project?
L.o.R
Never thought I'd buy a Mahindra Thar! My Jeep Story. EDIT: Now sold manveet 4x4 Vehicles 591 14th August 2017 18:18
That car you never thought you'd end up buying! manson The Indian Car Scene 45 4th September 2012 17:47
MM540-4WD wish list - what you really want in your MM540-4WD? DHABHAR.BEHRAM 4x4 Vehicles 299 7th January 2010 13:02
Thought I would never get mine (RD350) hormaz Motorbikes 23 23rd March 2009 13:13
Never thought giving an intro was this easy - Hi BHPians ms_mahu Introduce yourself 22 29th March 2008 20:55
