Old 29th September 2015, 17:06   #166
Thanked: 1,078 Times
Default Re: Can the Duster AWD scale Sandakphu, the highest peak in West Bengal?
Originally Posted by BlackPearl View Post
Thanks for the post Pawan. Great to see that you took the Duster on a proper trail that it deserves and not just some weekend soft-roading
This is a concern. When I had created this thread I was concerned only about the steepness of the slopes. It had not come to my mind that width can be a factor as I had always taken the Bolero to Sandakphu and never faced any issue with the width. I don't know the numbers but it seems that the Bolero is quite narrow compared to the Duster. There was only one place while going to Phalut where I had to get past a rock with very little gap between it and Bolero side step.
BTW, is the Pajero SFX wider than the Duster?
Most of the popular 4x4 are quite narrow
- Gypsy
- Land Rover Defender
- Pajero
- CJ-3
The reason is that they were designed go go up narrow trails both in hills and forests, where a wide trail is a luxury. Modern 4x4 SUV are designed primarily for comfort followed by bad roads mostly for Deserts, Savannah or open plains, rarely for narrow mountain trails.
Aroy is offline   (3) Thanks Reply With Quote
Old 29th September 2015, 17:29   #167
AJ-got-BHP's Avatar
Thanked: 2,672 Times
Sumitro good point there by Papa Bravo !!
Originally Posted by PapaBravo View Post
The width is a big issue. Width stats below :
Duster : 1822 mm
Bolero : 1745 mm
Scorpio : 1820 mm
Pajero SFX : 1775 mm
Fortuner : 1855 mm
Storme : 1965 mm
Bolero is approx 3 inches narrower. That is good cushion in such narrow roads. I doubt that a fortuner will pass thru. Also, thing don't loo too bright for Storme.
Good Data Compiled there Pawan. You seem to be superly charged up after the trip.
However, where we are comparing the width of the vehicles, I guess a closer look at their respective turning radius(s) shall also come in handy; specialy when it comes to Sandakphu !!
Over to the experts !!
And btw Pawan .... why bother about the brownie points anyways !! Just go with the flow as the age old saying goes "If you have it, use it".
AJ-got-BHP is offline   (5) Thanks Reply With Quote
Old 30th September 2015, 20:44   #168
GhostRider28's Avatar
Thanked: 228 Times
Thumbs up Re: Can the Duster AWD scale Sandakphu, the highest peak in West Bengal?
Stage 2 : Rocky & Muddy road to Sandakphu. The tarred road ends just after Chitrey & the rocky road starts. The terrain looks like it has been made only for leafsprings. The road is quite narrow with some very steep hairpins. After some point we encountered this.
Bravo Pawan! It is really commendable that you went up to Tumling even in such inclement weather conditions!
Some points to be noted :
1. The handbrake performed perfectly. It has the capability of holding the vehicle in place at steep inclines.
2. The reverse gear is powerful enough to a reverse climb. We encountered a LR from the opposite side while we were climbing down. We had to reverse up to a point where we could give it some space to pass.
3. The Hill assist work on reverse too. If you are on an incline nose down & want to reverse up, the brakes hold the vehicle for 3 seconds.
4. There was one very steep hairpin where we encountered an LR stopped just after the turn (Not a very wise thing to do). We had to brake midway on a hairpin. On the first recovery try, felt for the first time that extra power would be required. The engine couldn't pull up & died. Restarted & got through by slipping the clutch with high revs.
5. There is no scope of error. Provided you have a 4x4, it all depends on the driver skills. My respect for all those who have done this trail including Blackpearl, 1100D, mr.sinha & himadrimondal. It is quite taxing to your brain.
6. Vehicle width is one major issue. Duster is quite wide, It is even wider (although marginally) than the new gen Scorpio. I doubt anything wider that Duster can make it up due to that rock.
That's a nice comprehensive coverage of all critical points. I was concerned about the ratio of the reverse gear. I hope one wouldn't need to burn the clutch in the sleepest inclines during the last 3 KM from Bikeybhanjan - particularly when coming down in case of 3 points turns. I am particularly concerned about these last set of swictbacks - (captured by 1100D)!
http://www.team-bhp.com/forum/attach...d-img_9383.jpg
The Hairpins
Pawan
Good snaps of the hairpins!
Thank you gearhead_mait.
Duster : 1822 mm
Bolero : 1745 mm
Scorpio : 1820 mm
Fortuner : 1855 mm
Storme : 1965 mm
Pawan
Nice Stats - for the Scorp this is for the new one right?
GhostRider28 is offline   (1) Thanks Reply With Quote
Old 1st October 2015, 09:04   #169
PapaBravo's Avatar
Thanked: 1,604 Times
Most of the popular 4x4 are quite narrow..............mountain trails.
True.
Correct AJ. Turning Radius is quite important. Specially on the switchbacks.
Thanks Sayantan. Next time we will do it together. This time the weather was really bad.
They are quite difficult, but should be doable in the Duster. We will find out on the next trip.
Thanks. Yes they are for the new Scorpio. I believe the old gen was narrower at 1817mm.
Pawan
PapaBravo is offline   (1) Thanks Reply With Quote
Old 7th October 2015, 19:06   #170
Thanked: 617 Times
This is awesome, Pawan. Too bad the weather didn't cooperate for you to go on further. But good decision to turn back. There will always be a next time.
mr.sinha is offline   (1) Thanks Reply With Quote
Old 30th March 2016, 18:41   #171
sinhsha's Avatar
Thanked: 71 Times
My last posts deleted as photos were not there.
So yes Duster can reach to sandakphu, I think that was the major discussion point of this thread.
We did go to sandakphu by a duster AWD.
The route is really tough as it was full of stones and very steep, the major problem was traction and crawling for any AWD.
We reduced the tire pressure and did it 4WD lock which helped.
Anyone trying to go there in an AWD have to take high level of caution.
I am posting videos and photos to show the situation.
Videos
sinhsha is offline   (8) Thanks Reply With Quote
Old 30th March 2016, 18:50   #172
DriveTrain's Avatar
Thanked: 311 Times
Congrats , this is quite a feat and a testament to the abilities of the driver and the car. What was the pressure you maintained , and was this the same on all tyres ? Noticed the missing driver side ORVM cover , did that happen on the trip ? How was your experience on the turns while coming down ? You mentioned about clutch burn , how bad was that ?
Do keep the pictures and the story coming.
DriveTrain is offline   Reply With Quote
Old 30th March 2016, 22:01   #173
sinhsha's Avatar
Thanked: 71 Times
Yes mirror was broken in kol to siliguri route in a congested place a bike hit it and ran away.
Clutch burn was little bit not very serious.
While coming down underbelly scrapped due to suspension travel on rocks under weight.
Turns were sharp but not big problem as duster's turning radius not very bad.
In bolero turns could seem very tight
sinhsha is offline   (1) Thanks Reply With Quote
Old 31st March 2016, 15:40   #174
tsk1979's Avatar
Thanked: 16,421 Times
From the video I feel your technique is not right. You are using clutch slip. The first gear has enough torque to do gradual climb without wheelspin.
You are gunning it and slipping tires. If you do it gently, she can climb up without ado.
The Duster AWD is known for exceptional climbing ability.
Also, when climbing was the traction control light flickering?
tsk1979 is offline   (1) Thanks Reply With Quote
Old 31st March 2016, 19:04   #175
sinhsha's Avatar
Thanked: 71 Times
I tried to use the low 1st gear torque. But in some places like in the videos that was not enough. As it was around 11000 ft altitude i suppose car was not responding as it does in lower altitude. I tried to use torque but car was not moving an inch. The major issue could be rocks and the wanderars tires.
Old 10th May 2016, 11:09   #176
Thanked: 2,522 Times
Has anybody taken a Gypsy up to the top yet? Seems like a good fit for this trail, small, lightweight and nimble.
Dry Ice is offline   (1) Thanks Reply With Quote
Old 10th May 2016, 20:09   #177
BlackPearl's Avatar
Thanked: 5,144 Times
Sorry for not updating the thread earlier. sinsha had already updated though.
Here is the video of the first Duster AWD to have made it to Sandakphu -
More details can be found here -
http://www.team-bhp.com/forum/travel...ndra-thar.html (Sandakphu and beyond in a Mahindra Thar)
Yes Dry Ice, one of my friends, a veteran rally driver has taken his Gypsy 1.3 mpfi to Sandakphu. He was complaining about the huge turning radius, the lack of low end grunt and the horrible ride quality of the Gypsy.
BlackPearl is offline   (3) Thanks Reply With Quote
Old 11th May 2016, 10:06   #178
Woah, and I thought the Gypsy had a tight turning radius and wouldn't need to do 3 point turns on the switchbacks, unlike the larger 4x4s.
Dry Ice is offline   Reply With Quote
Old 11th May 2016, 14:11   #179
Thanked: 40 Times
@BlackPearl ... Kudos to Duster awd for this climb. Kindly comment. From the video it looked like Duster had to struggle and do a speedy climb compared to Thar which was able to climb slow and cool.
ManuMacher is offline   (1) Thanks Reply With Quote
Old 12th May 2016, 15:28   #180
BlackPearl's Avatar
@ManuMacher, the Duster was struggling due to several reasons as mentioned by sinsha who was driving it -
1. Lack of Low ratio GB
2. The driver was unfamiliar with the terrain and hence was stopping to check the exit points of the steep turns. As a result it required quite a lot of effort to get moving in those steep slopes after coming to a complete halt
3. The lack of torque of the 110 ps Duster at lower RPMs was causing a problem as well
BlackPearl is offline   Reply With Quote
Bangalore-Raichak (West Bengal) Jan 2011 drive_or_die Travelogues 3 18th November 2010 21:10
Petrol Pump Buying in West Bengal - Need suggestions akaushik Shifting gears 3 8th April 2010 22:12
Xylo at Deomali - Highest peak in Eastern Ghats H3LIOS Travelogues 27 2nd January 2010 10:46
My say on West Bengal traffic esteemer Street Experiences 17 3rd July 2009 21:41
