Old 2nd March 2016, 14:24   #76
wrongturn's Avatar
Thanked: 424 Times
Default Re: Need help: Buying a used 4WD (Jeep/Gypsy)
As far as I know the Gypsy transmission is designed to cater to the current engine's torque. Any thing more (say 50% more torque) and the axles will start breaking. That is why till date no deisel has been fitted to the Gypsy.
You second option - rebuild the Verito and sell it off. Then buy yourself a 4x4.
Thank you for replying. So, I cant use this gem of an engine in a Jeep or Gypsy. What a waste, I really wanted to use this engine and other car parts like power steering & maybe disc brakes, etc. to build something good. One of the mechanic I know says it could be done, or he is rather it 'may' be done by the way he sounds about it and I am scared it might end up being some sort of a 'JUGAAD'.
Rebuilding Verito isn't too exiting as its resale is already too low and being an accidental case it would not help its cause anyway. I also don't want to build a 4x4 that would be standing 24x7 in a mech garage.
So its time to hunt for a Logan/Verito body shell. Anything that involve cars is exiting anyways.
I was also thinking about Renault Logan/ Dacia Logan Pickup. But I guess converting it to those will make it illegal on road. And I am not too sure what purpose would it serve. So I think rebuilding Verito it is.
Need help: Buying a used 4WD (Jeep/Gypsy)-dacia_logan_pickup_by_vladyd.jpg
Need help: Buying a used 4WD (Jeep/Gypsy)-screenshot_20160219190138.png
wrongturn is offline   Reply With Quote
Old 2nd March 2016, 14:35   #77
Thanked: 1,011 Times
Before you embark on rebuilding the Verito find out
A = How much the junk dealers are willing to give for your car as is.
B = How much will it take to rebuild the car.
C = How much can you sell it for after rebuild.
If C > A + B, then it is financially viable, else just sell it as is. Even if you make less than 10K profit, it is not worth the time and effort spent.
Aroy is offline   (1) Thanks Reply With Quote
Old 2nd March 2016, 14:43   #78
wrongturn's Avatar
Thanked: 424 Times
Difference is huge, I got a couple of quotes that are both under 75k. If I rebuild this, which is a 2011 Verito D4 which has done 27K Kilometers, it holds a resale value of around 2.5L and more. And its engine is still in good condition and running, all it needs is a new body majorly. I think rebuilding it is the way forward.
Old 2nd March 2016, 16:02   #79
dhanushs's Avatar
Thanked: 4,119 Times
^^ It will take a long time and a whole lot of effort more, but selling parts individually might fetch you more value
Mahindra 4WD vs Modern 4WD Samurai 4x4 Technical 137 19th February 2012 19:46
CL340-4WD wish list - what you really want in your CL340-4WD? DHABHAR.BEHRAM 4x4 Technical 43 23rd December 2010 00:05
MM540-4WD wish list - what you really want in your MM540-4WD? DHABHAR.BEHRAM 4x4 Vehicles 299 7th January 2010 13:02
2009 Jeep J8 Multipurpose 4WD.....return of the WILLYS JEEP!!! amit V8 The International Automotive Scene 14 27th July 2009 01:12
