Old 14th March 2010, 14:30   #196
SPIKE ARRESTOR's Avatar
Thanked: 703 Times
@Trammway, very well documented and nice info there, would be keeping a close watch on this thread.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 14th March 2010, 18:46   #197
svsantosh's Avatar
Thanked: 1,378 Times
Wow... At last the 'posting' begins.
I see the gear wheels between the CJ3B and classic are very different. So what did you end up changing to solve these issues?
PS - is it best to remove the gearbox down to fix a OD, or do it whilst hosting the jeep up?
And the video, is is the entire OD unit? It is so small!!
PS - Bharani is becoming a celebrity... he needs to pay royalty back to you
svsantosh is offline   Reply With Quote
Old 14th March 2010, 22:15   #198
trammway's Avatar
Thanked: 210 Times
Spike
Spike I wish to hear from you, do you know any information about the PTO port / Transfercase main drive gear having some dimensional changes between the Mahindra Classic ones and CJ340/MM540 ones (with same KMT90 and T18 combination, only difference is that of 2 lever and single lever)?
The drive gear has definite difference that I have already explained.
Nope, you don't need to remove the gearbox down to fit the OD.
Nope what you see is only the planetary gear unit of the OD, please check the previous posts where I have published the complete OD kit.
I think so, may be I will ask him for a discounted labor charges
I will wait till tomorrow afternoon for guessing of the road block at this point, otherwise I will post it tomorrow evening.
trammway is offline   Reply With Quote
Old 15th March 2010, 13:42   #199
Tejas@perioimpl's Avatar
Thanked: 4,858 Times
If the lac isnt a problem, then the 2 year waiting will tire you out.
Where did you get those figures? Herm replies to my emails within 24hours. He has promised to ship within 4 days of receiving any order.
And cost of the OD quoted to me is approx 42K INR + shipping.
Looking closely at this thread before deciding.
Tejas@perioimpl is offline   Reply With Quote
Old 15th March 2010, 14:14   #200
svsantosh's Avatar
Eh, Ok I exaggerated the lac. May be it was close to 70K. But regd the production waiting period, I got to check with my friend. Will revert asap. Thanks for the 42K figure BTW... Looks more afffordable now.
Old 15th March 2010, 14:36   #201
trammway's Avatar
Thanked: 210 Times
Here is the quote I have received from Herm:
1 no. 29 tooth 15 spline overdrive (Mahindra)------------------$ 940.00
1 no. 4 speed shift linkage------------------------------------$ 60.00
1 no. single lever floor plate and rubber----------------------$ 15.00
sub total-------------$1015.00
shipping options:
USPS postal Service International Priority Mail--$ 170.00
BAX/Schenker-------------------------------------$ 120.00 (If I opt this for calculations)
Wire Transfer charges: 10+40+20 = $ 70
Note: Initially your bank will charge a fee associated with the wire transfer, domestic wires average about $10.00US,
international wires about $40.00 US
If your bank uses a mediator bank, there may be an additional charge, average $20.00 US
that could be deducted from the wire amount. This will delay your shipment, because the full amount has not been received by us.
So the total damage is USD: 1205 = INR 55430 (@46 per USD)
Santhosh said the waiting period from my experiences & learning and actual delays from Herm due to unavailability of parts.
Now Herm side delay's could be avoided as he is having few ODs in stock.
Old 15th March 2010, 14:52   #202
Super break up!
How much time did it take for the shipment to arrive via USPS?
He told me the total weight is 25pounds. Is it correct?
Waiting for the remaining of your post on how you solved the roadblock.
Old 15th March 2010, 15:44   #203
trammway's Avatar
Thanked: 210 Times
Super break up!
Nope, I have not ordered and took the pack via international shipping option. Instead one of our TBHPian (guess who) with great gesture carried it all the way from US to India. However the shipping charges were incurred locally in US itself as he had less time and ordered from Herm through some overnight delivery option. Total came to the same figures.
Total weight of the consignment is around 10-15kg. I will post the next phase of installation with how the road block crossed information in this evening as I'm now sitting in my office. Need to upload lots of pics and videos ,please wait till EOD today.
Old 15th March 2010, 15:58   #204
svsantosh's Avatar
Talking
......as I'm now sitting in my office. Need to upload lots of pics and videos ,please wait till EOD today.
What do you think we do in Office.
If this post is I.T-filtered, I am dead...
Come on, keep a few excel files open, open 2 diaries next to you, have 4-5 printed papers next to you, put your chat into DND mode and start the pics, Anna!!
Old 15th March 2010, 18:15   #205
trammway's Avatar
Thanked: 210 Times
Well, the road block as I mentioned in my previous post is explained in here.
The OD kit was supplied with a ring kind of stuff called Spacer, this will be the first component to sit before the planetary gear assembly.
The spacer provides sufficient gap between the internal oil seal and planetary gear. Also the spacer sits above the main drive shaft.
The spacer provided in Herm's overdrive kit is not fitting properly into the transfercase for two reason.
1. The height of the spacer is bit shorter than the Mahindra Classic's main drive gear spec (see the pic below)
2. Outer dia of the spacer is sort of smaller, hence it is not fixing properly with in the oil seal on the drive shaft / main gear wall. (outer side of the green circle shows the oil seal in transfercase, the new spacer's outer dia is bit smaller than the oil seal's inner dia)
Now with out it if I install the OD, it will simply compress the oil seal and will create unnecessary friction with the transfer case inner wall.
Look at the following figure which shows the old main drive gear next to mahindra classic, the dia of the front portion is not matching to each other. The same goes with MM540/CJ340 main drive gear, hence the herm's spacer that came with OD kit is of the older MM540/CJ340 model transfer case.
Name:  Copy of IMG_6267.JPG
To over come this issue, I need to fabricate a spacer that matches to the Mahindra Classic's oil seal inner dia and to match the drive shaft length.
How did custom made fabricated spacer looked like, how much was the damage to pocket ?
to be continued...
Old 15th March 2010, 18:33   #206
JeepCaptain's Avatar
Thanked: 468 Times
Default All the Best
Hi Siva,
Glad to see that you have started the OD installation. Waiting for more pics and videos and a finally a full fledged test drive report.
Just realised that your OD has already travelled about 20K Kilometers from Herms factory before it reached you and been through three continents!! North America, Europe and Asia.
JeepCaptain is offline   Reply With Quote
Old 15th March 2010, 19:15   #207
Hope you have measured accurate dimensions of the new spacer!
Old 15th March 2010, 22:29   #208
Jaggu's Avatar
Thanked: 7,179 Times
Siva please continue and kill this suspense please! all eyes glued into this thread!
Old 15th March 2010, 22:48   #209
svsantosh's Avatar
How did custom made fabricated spacer looked like, how much was the damage to pocket?
Did you fabricate a new one in lathe or CNC? Must have cost anything between 500-2000, depending on the complexity and raw material.
Hehe, I can see the raised eyebrow. You dont want to put down half a lac and fabricate something you have no prior experience with!!
+1, anna - this is too much suspense. Let the bird out...!!
PS - Hope Herm reads this thread, You can give a feedback to him explaining the fabrication you had to do...
Old 16th March 2010, 00:21   #210
trammway's Avatar
Thanked: 210 Times
Originally Posted by JeepCaptain View Post
Hi Siva,
Without you I'm sure this is not happen mate. Thanks a ton.
Ofcourse yes. Please watch out my next post for details
he he he... ok this time I will take your request
The next episode follows, I will sure let Herm know about this thread after completion of the installation part.
I need to start posting the performance report after that
1 Gypsy 4 Humvees - Indian & US army Exercise Parm 4x4 Vehicles 15 19th October 2009 15:47
Could people be interested in designing their own track? As a fun exercise? 1Day Int'l Motorsport 5 17th June 2007 23:23
