Old 10th May 2010, 12:34   #181
svsantosh's Avatar
Thanked: 1,392 Times
Originally Posted by ex670c View Post
The difference in acceleration & deceleration is obvious the vehicle feels very sure, you cannot feel the engine and transmission moving (pitching).
Hi Arka,
I can now faintly relate to what I experience in a TATA like Sedan (TATA because they dont make real sedans) - when coasting in, say, 3rd or 4th gear at a particular RPM - IF I give sudden throttle inputs on-off-on-off - I can feel the while gear stick moving back and forth a couple of MM's. I cant imagine how much CM's will it move in a Jeep, coz of the (very limited) 2 engine mounts and 1(?) GB mount.
Lets wait for Spike/Dhabar to write more on the use of a Spike Arrestor.
Santosh
svsantosh is offline   Reply With Quote
Old 26th July 2010, 19:19   #182
The Wolf's Avatar
Thanked: 58 Times
I have the spike arrester fitted but without the pipe. Any idea what should be the slack in the cable? Or is it supposed to be installed with no slack at all??!!
The Wolf is offline   Reply With Quote
Old 27th July 2010, 13:35   #183
ex670c's Avatar
Thanked: 1,799 Times
Default Spike Arrestor
Hi Wolf,
I have seen only the cable attached in most of the Ex-Army MM550XD.
Has this system been carried over to the NGCS MM550XD?
Guess Spike and DB Sir and answer these queries.
Arka
Old 27th July 2010, 14:32   #184
Blue Thunder's Avatar
Thanked: 330 Times
...Any idea what should be the slack in the cable? ...
From what I understood, there should be no slack at all, both in tension and compression (to arrest the spike ).
Blue Thunder is offline   Reply With Quote
Old 27th July 2010, 16:06   #185
The Wolf's Avatar
Thanked: 58 Times
I am not sure if that is correct coz any integrated moving component needs to have minor clearances to aid flexing without which there is a possibility of breakage. My gear lever doesnt have any movement as it is and my mechanic set the spike arrester with may be a 10mm pre-load flex/clearance. Got to learn the right thing from an academic stand point now, the testing will be done spontaneously
Behram Sir, UBS Sir, anyone??!!
Old 17th October 2010, 23:41   #186
Thanked: 27 Times
Hi Arka
could you please let me know the source & band of the Coil-Over Hydraulic Damper installed in your MM540XD.
Chengappa.
Timson is offline   Reply With Quote
Old 18th October 2010, 13:16   #187
ex670c's Avatar
Default Rtc
Originally Posted by Timson View Post
Hi Arka
Chengappa.
Hi Chengappa,
The Return To Centre Steering Damper is for CJ5/6/7 made by Tough Dog (Australia).
Cost around 150-200AUD, a friend got it for me in June 2007.
Arka
Old 18th October 2010, 23:24   #188
Thanked: 27 Times
That was very quick, thank you very much for the info. The OKBJ and steering upgrade is excellent, your workshop guys seem very enthusiastic and competent.
Thank you once again,
Chengappa.
Old 20th October 2010, 13:34   #189
IronWolf's Avatar
Thanked: 36 Times
So is the vehicle owner!
Need drive down to Chennai to Ali's garage for a series of mods noted from this MM540/550 resource thread.
Without doubt Arka would also be there to guide and supervise (?)
IronWolf is offline   Reply With Quote
Old 20th October 2010, 19:00   #190
ex670c's Avatar
Default The Best
Chengappa.
Absolutely, M.Santanam & Mhd.Ali are the top M&M JEEP especially 4WD Mechanics in the country.
Old 20th October 2010, 23:10   #191
shekaran's Avatar
Thanked: 63 Times
Arka Sir, How can you be so modest ?
Friends, actually mhd.ali asks arka for technical correctives, and as far as i know, arka is the living encyclopedia for mm jeeps, next to UBS sir !!!
shekaran is offline   Reply With Quote
Old 21st October 2010, 07:46   #192
Originally Posted by shekaran View Post
Absolutely,
Well, who does'nt? Arka's approach to building jeeps is truly commendable. Modifications suggested by him are simple yet render the vehicle extremely capable off road and reliable on road.
I have benefited immensely from the discussions I have had with him and several of his inputs go into the jeeps I build.
'When in doubt call Arka' is almost a protocol I follow, whenever I wish to try out something new on either my clients' jeeps or mine.
flanker.r is offline   Reply With Quote
Old 11th November 2010, 11:34   #193
ex670c's Avatar
Default OOOOOOOOOOOOOOOOOOOPs!!!!
Hi Guys,
Went out for a rather unprepared off-road exploration.
I became a case study of what not to do for an OTR.
1) Went out in One vehicle. Once stuck had to wait 2hrs to get pulled out by Vikram (Headers) and Maj.SR Roy.
2) No Recovery Gear in the Vehicle, there were 5 of us we could have easily got the JEEP back on her wheels.
3) Carrying more than Driver & Navigator, had 3 passengers at the back, put them is a difficult situation and at risk of injury or worse. Thank god no one was injured, not a scratch.
4) Not wearing Seat Belts, I slid on top of my brother, while he was standing on the LHS Door.
5) Did not Roll-Down the Door Glasses, nothing happened, but the can be a cause for injury.
The result was one Damaged RHS ORVM, while climbing out, a minor dent on the LHS Rear Wheel Arch, the weight of the vehicle was on the Left hand Front and Rear Wheels, thanks to the wide-track they stick out from the body.
And off-course had to wait for 2Hrs before the cavalry arrived.
Arka
Old 11th November 2010, 12:00   #194
jeepster's Avatar
Thanked: 984 Times
thank god that no one was injured.
your brother must be a strong man to support strong man like you.
had faced similar situation 2 years back in a scorpio. (me driving & the next moment i was standing on front passenger door)
but it was a road accident & at 1.30 am in the morning. (one of the worst memories in my life)
be careful next time.
jeepster is offline   Reply With Quote
Old 11th November 2010, 12:44   #195
nitrous's Avatar
Thanked: 283 Times
Reminds me of my experience 4 years back.
You were MY cavalry, then
The Jeep - MM540XD Transformed! dhanushs 4x4 Vehicles 65 26th October 2017 20:26
My Jeep Story Continues! Now, the MM540XD dhanushs 4x4 Vehicles 197 3rd October 2013 20:04
Problems after converting MM540XD 2WD to 4WD HJ13 4x4 Technical 44 27th January 2012 16:41
To upgrade or not to upgrade? Steeroid Tyre & Alloy wheel Section 22 20th June 2007 19:13
Audio system upgrade for Octavia Ambiente cruise_control In-Car Entertainment 7 14th September 2004 17:46
