Old 16th June 2011, 08:43   #226
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
Default Re: My MM540XD upgrade
Originally Posted by Sudarshan View Post
This enhances the bush life as the center tube is not kind of pre rotated before the vehicle assumes the normal position . ( on its suspension )
Hmm, this is the correct method.
Originally Posted by ex670c View Post
then tightened the Bolts fully by hand (with out cheater bar or rod extension).
After the vehicle was removed from the Jack stand, checked all the bolts.
Arka, final tightening of all suspension components must be with wheels on the ground. As told by Sudarshan, it improves bush life and roll too! Try it next time and you will feel the difference.
Spike
SPIKE ARRESTOR is offline   (1) Thanks Reply With Quote
Old 29th June 2011, 03:47   #227
V-16's Avatar
Thanked: 862 Times
Hi Arka, what would have been the chances of your Jeep rolling in the ditch sideways, had a lift (which on any Jeep can mean by the way of a shackle lift or an SPOA) not been undertaken on your JeepJJust my layman question since im wondering whether to do this on my MM550 which is going to be shod with 15"- 8.5J rims and 10.5X31" tyres.
Are you considering plonking a rollcage on to your Jeep? If yes what will it be, a 4 point or a six point?
Besides the broad Thar like stance, what good are the FC axels on a MM550?
Thanks in anticipation.
V-16 is offline   Reply With Quote
Old 29th June 2011, 08:12   #228
svsantosh's Avatar
Thanked: 1,443 Times
Eh, Arka doesnt have any lift. Any lift, in theory, will increase the center of gravity, thus increasing the chances of roll over. Once I got the longer shackle, I immediately felt that effect on trails.
svsantosh is offline   Reply With Quote
Old 29th June 2011, 09:53   #229
Thanked: 825 Times
Exclamation Re: My MM540XD upgrade
One thing I learned about longer shackles is that you only get half the lift of the shackle length used
for example if a vehicle uses a shackle length of 4" as standard & If you want a lift of 1" you will need to put a 2'" longer shackle than the standard & that means a 6" long shackle .
I don't think its worth it , using a 2" longer shackle for a mere 1" lift --- one can adjust his driving or improve skills .
Sudarshan
Sudarshan is offline   Reply With Quote
Old 29th June 2011, 11:57   #230
ex670c's Avatar
Thanked: 1,820 Times
Hi Gogi,
I don't have a Shackle Lift, maybe a shackle lift, would have improved articulation, but I doubt, it would have prevented the roll-over.
Since my JEEP is a daily drive and I use it for utility work a roll-cage will take away lot of useful room (Rear Seats & Wheel Arch).
If I were to install a roll cage I would go in for a 6 Point Roll-Cage.
The FC Axles will improve,
i) Stance,
ii) Cornering Stability,
iii) Axle Articulation
iv) Rear is FFRA
v) For the same knuckle geometry, there will be more room to move the tyres, and can translate to improved turning radius.
Arka
ex670c is offline   (2) Thanks Reply With Quote
Old 29th June 2011, 12:26   #231
jeepster's Avatar
Thanked: 1,027 Times
hi arka,
the FC axles are meant for SPOA so the pinion angles will be different than normal 554/550 axles right?
can they handle 34" tyres?
jeepster is offline   Reply With Quote
Old 29th June 2011, 13:14   #232
ex670c's Avatar
Originally Posted by jeepster View Post
hi arka,
Hi Nikhil,
The FC Axles are fitted SPOA on the FC Van. However in JEEP Application we will have to weld the spring saddles and orient them as such.
Do you think they can handle 34" Tall Tyres, what about the additional weight of the tyres?
Arka
Old 29th June 2011, 15:28   #233
jeepster's Avatar
i asked the question.
i dont think so, but have seen some 550 with 34" tyres.
rgds,
Nikhil
Old 23rd January 2012, 20:21   #234
ex670c's Avatar
Default Pre-OTR check-up
Hi Guys,
The following work was done on my MM540XD, in anticipation to the Bangalore Annual OTR.
1) Servicing the winch (Motor was rewound and Carbon Bushes changed)
Works fine, does not heat up, but not yet tested under full load.
2) Re-Stitch the top with Ticket #20 Nylon thread (needle & bobbin)
3) Brakes & Hubs serviced
4) Paint Touch-Up
5) Serviced Injector Nozzles.
6) Changed the RTC Steering Damper Shocks to Amby type.
7) Changed clutch Plate & Cover Assy (Diaphragm Type). My clutch plate torque springs got cut while driving and for the first time my JEEP, had to be towed to the garage. Luckily it was on "Kaanum Pongal" and there was no traffic.
The Diaphragm Type cover Assy is smoother & comfortable to use, vehicle feels peppier & lighter.
8) the usual
i) Engine Oil Filter Changed
ii) Diesel Filter changed
iii) Engine Oil Changed (5ltrs)
iv) Air-Filter Cleaned
v) Clutch Linkage Changed
vi) Clutch & Brake Pedal Bush Changed.
Arka
ex670c is offline   (1) Thanks Reply With Quote
Old 23rd January 2012, 20:25   #235
headers's Avatar
Thanked: 464 Times
Cool Re: My MM540XD upgrade
So Arka, do we get to Chennai - Bangalore in 6 hours since your Jeep is peppier now?
Old 23rd January 2012, 20:26   #236
ex670c's Avatar
Hi Vikram,
Depends on what FUEL ECONOMY, YOU want to get!!!!
Arka
Old 23rd January 2012, 20:29   #237
Thanked: 809 Times
Default Re: Pre-OTR check-up
Hi Arka,
I was expecting updates on this thread. What about tires, are you using the same ones as last year or something new coming up ?
4) Paint Touch-Up
It is sometimes good you take her to the beautician, will keep her happy.
All the best, enjoy ! Please convey my regards to UBS Sir.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 23rd January 2012, 20:33   #238
ex670c's Avatar
Hi Spike,
The Tyres have been changed to Goodyear G90 7.50XR16 Radial LT (these are my MT usage Tyres).
Superb Grip and nice ride.
Arka
Old 23rd January 2012, 21:08   #239
sreejeshmp's Avatar
Thanked: 576 Times
Hi Guys,
Arka
Arka,
Please share the details of the Clutch plate and cover Assy. I am still searching for my 550. Your's is XD3P so there will be a step on the fly wheel So The same Clutch and cover assay will solve my problem (Right now my clutch and cover assay from MM- pik-up).
- Sreejesh
sreejeshmp is offline   Reply With Quote
Old 24th January 2012, 10:08   #240
ex670c's Avatar
Hi Sreejesh,
Part No3210129 240mm for DI/Marshal/Single Cab/Double Cab
Arka
The Jeep - MM540XD Transformed! dhanushs 4x4 Vehicles 65 26th October 2017 20:26
My Jeep Story Continues! Now, the MM540XD dhanushs 4x4 Vehicles 197 3rd October 2013 20:04
Problems after converting MM540XD 2WD to 4WD HJ13 4x4 Technical 44 27th January 2012 16:41
To upgrade or not to upgrade? Steeroid Tyre & Alloy wheel Section 22 20th June 2007 19:13
Audio system upgrade for Octavia Ambiente cruise_control In-Car Entertainment 7 14th September 2004 17:46
