Old 5th February 2012, 02:44   #241
Thanked: 247 Times
Default Re: Pre-OTR check-up
Originally Posted by ex670c View Post
Hi Spike,
The Tyres have been changed to Goodyear G90 7.50XR16 Radial LT (these are my MT usage Tyres).
Superb Grip and nice ride.
Arka
Hi Arka,
Can you share where did you buy these tires and for how much? Are these imported or is Goodyear making these in India. Tread looks promising. Any pics of your ride with these shoes on?
vishwas
vishwaschettri is offline   Reply With Quote
Old 6th February 2012, 10:19   #242
ex670c's Avatar
Thanked: 1,821 Times
Hi Vishwas,
I bought these tyres from a friend, who bought it off another friend, who bought it from Allan (extreme_power); who got these from South Africa.
Bought them Rs5500 per Tyre for 6 Tyres.
Arka
Old 8th February 2012, 22:07   #243
Thanked: 247 Times
Hi Vishwas,
Arka
Thats a steal at 6k. Any pics of your ride with these on? So who do I contact if I am interested in a set? You, your friend, your friends friend or Allan?.
Sorry couldn't resist it.
cheers
vishwas
Old 9th February 2012, 14:18   #244
ex670c's Avatar
Default Pics Goodyear G90
Any pics of your ride with these on? vishwas
Hi Vishwas,
You can get these from South Africa :P.
Arka
Old 10th February 2012, 10:20   #245
discoverwild's Avatar
Thanked: 1,139 Times
Default Re: My MM540XD upgrade
Anything more you intend to do on the Jeep, Arka? Before the coat of paint??
discoverwild is offline   Reply With Quote
Old 10th February 2012, 14:07   #246
ex670c's Avatar
Hi Suraj,
Actually, Tube Fenders (Front) & Shock Absorbers.
Arka
PS - I did paint the vehicle before the BAOTR2012, but I'm not complaining
Old 23rd December 2012, 16:14   #247
Thanked: 86 Times
Default Re: Rise of the 540 (2007 Part2)
Hi Guys,
Few Pics of the MM540D with the winch, JEEP THRILLS 2A and TPC07.
Arka
Arka,
I have read this thread in one sitting for the 3rd time in the last 2 years. I own an MM540XD and has learned a lot from here. Currently I am getting my vehicle prepared for the Bangalore OTR. One quick question I have is on the picture no: 5 where you come down the sandhill and move through the slush, was this on 1st gear 4L or 2nd gear 4L, while coming down the sand. and once you are down on that marshy area, what gears would you prefer to use on your 540.
Hope to see you again for the Bangalore event.
Thanks and Regards,
Vivek
jmvivek is offline   Reply With Quote
Old 24th December 2012, 10:26   #248
ex670c's Avatar
Originally Posted by jmvivek View Post
Arka,
Thanks and Regards,
Vivek
Hi Vivek,
Way back in 2007 we were trying various techniques, like descending in 1st Lo and shifting to 2nd Lo. But this technique caused the vehicle to loose momentum.
So on "SAND" I prefer using 2nd Lo to make rapid ascends and descends, however on taller climbs 3rd & 4th Lo are used.
Arka
ex670c is offline   (2) Thanks Reply With Quote
Old 25th December 2012, 01:08   #249
Thanked: 86 Times
Default Re: Auto-Locker Re-Install
Hi Guys,
The main culprit was a worn out differential pinion Cross Shaft, this was causing the Auto-Locker Coupler to move a few mm causing the noise and throw.
After the re-installation the noise has been reduced by 95%, now the locker clicks at extreme turns or slaloms.
Arka
Arka,
When you changed to FFRA Bolero on your MM540, was there any differential strengthening that you had to do? Did this setup, cause any problems after installation, Which I guess not,as I remember you mentioning about the ruggedness of this setup over the SFRA some place else in this thread? is it possible to retain 5.38 diffs once we change to FFRA Bolero? the 57' front axles of Maxx and the 53'rear axles of Bolero, what model year onwards do you suggest for MM540 axle upgrade? Do advise, If I need to know anything additional in getting this setup done!!!
Old 25th December 2012, 12:33   #250
ex670c's Avatar
Arka,
Hi Vivek,
The only problem I faced after switching the Axle Tubes on the 53" Bolero Axles/Housing, was the Spring Saddle/perch was not welded properly hence in the Avalakonda 2010, I ended ripping the rear propshaft.
Use the post 2006 OKBJ 57" Front Axle they come with Disc Brakes.
The differential ratio depends on the Dana 44 Carrier 3.73 and Down or 3.92 and Up. If you examine the current differential ratios in M&M JEEPs you will figure out which carrier to use.
Arka
ex670c is offline   (1) Thanks Reply With Quote
Old 26th December 2012, 16:55   #251
andy.001's Avatar
ex670c
Hi arka,
you have a great off-roader there. I loved every bit of reading about it.
I understand you have changed the front axle with 57" OKBJ one and the rear one with 53". In the attached picture, the rear and front tires look aligned better. Have you put in any kind of spacers in the rear? If yes please can you guide me how you achieved this ?
i am looking to build a jeep using 2004 mm550 ngcs, hence my question. The scrawny rear sticks out like a sore thumb to my eyes. i was hoping in some not-harmful-to-the-jeep way, i could match the track widths. Or at least minimize the difference. Your advice and help would be greatly appreciated.
Thanks in advance.
andy.001 is offline   Reply With Quote
Old 27th December 2012, 10:19   #252
ex670c's Avatar
Originally Posted by andy.001 View Post
ex670c
Hi arka,
Thanks in advance.
Hi Andy,
I haven't used any kind of spacer. since the picture is angled from the front the front & rear track look the same.
However to achieve 57" Front and Rear you will need 2" Spacers at the Rear.
Arka
Old 27th December 2012, 10:50   #253
andy.001's Avatar
Hi Andy,
Arka
Thanks for your prompt reply arka.
Will putting spacers have any adverse effects on the jeep ? The last thing i would want is to compromise the structural integrity of the jeep.
Aashish.
Old 27th December 2012, 16:39   #254
headers's Avatar
Thanked: 464 Times
Aashish.
Please dont go in for Spacers - Modifying the Wheel Centreline will have impact on Steering, handling, suspension, and wheel bearings as well
headers is offline   (2) Thanks Reply With Quote
Old 7th April 2014, 04:06   #255
Thanked: 85 Times
The Fenders don't cut into the tyres as the re-tread is 12ply.
Where did you get the retreading done and how much did it cost?
Live To Jive is offline   Reply With Quote
The Jeep - MM540XD Transformed! dhanushs 4x4 Vehicles 65 26th October 2017 20:26
My Jeep Story Continues! Now, the MM540XD dhanushs 4x4 Vehicles 197 3rd October 2013 20:04
Problems after converting MM540XD 2WD to 4WD HJ13 4x4 Technical 44 27th January 2012 16:41
To upgrade or not to upgrade? Steeroid Tyre & Alloy wheel Section 22 20th June 2007 19:13
Audio system upgrade for Octavia Ambiente cruise_control In-Car Entertainment 7 14th September 2004 17:46
