Old 7th April 2014, 13:22   #256
ex670c's Avatar
Thanked: 1,820 Times
Default Re: My MM540XD upgrade
Originally Posted by Live To Jive View Post
Where did you get the retreading done and how much did it cost?
Hi Live to Jive,
I got the tyre retreaded in 2009, using Midas Retreads. It cost Rs1800 per tyre, including the tread and re-treading.
Not aware of the current prices.
Arka
ex670c is offline   (1) Thanks Reply With Quote
Old 7th April 2014, 17:38   #257
Thanked: 1,077 Times
There are plenty of retreading operators, but they mostly do truck tyres. You can find out from nearest highway petrol pump or puncture repair guys.
Old 7th April 2014, 17:45   #258
Thanked: 85 Times
Originally Posted by ex670c View Post
Hi Live to Jive,
Arka
Thanks for the information. From the picture it appears that the original tyres were Sandgrips. How was the performance with this thread and would you recomend it? Asking this on behalf of a friend who's buying an ex-army MM550 which has Sandgrips but worn out.
Live To Jive is offline   Reply With Quote
Old 7th April 2014, 20:03   #259
Thanked: 58 Times
Default Re: 4-Way Steering Stabilizer
1) Construction
Coil-Over Hydraulic Damper
2) Advantages
i) Eliminates wheel wobble
ii) Eliminates Bumpsteer (when wheels hit obstacles and transfer the shock to the steering wheel)
iii) Reduces wear of steering components
iv) Improves Return-To-Center of Steering Wheel.
3) Disadvantages
i) Does not show/highlight wheel imbalance
ii) Doesnot show/highlight Kingpin wear (cause for wheel wobble)
iii) Makes steering a little bit harder.
Arka
Hi Arka,
Where can I get one of these in India, any make/model you would advise, and how much would one run for?
Thanks!
lugnut
lugnut is offline   Reply With Quote
Old 10th April 2014, 11:05   #260
ex670c's Avatar
Default 4-Way Steering Stabilizer/ RTC Damper
Hi Lugnut,
I'm using a Tough Dog RTC Steering Damper since 2007, cost 135 AUD.
This has been installed and been in use since Feb 2008. I have changed the shock absorber Thrice, the coil springs are doing well.
2008 -2010 -- Original Tough Dog shock absorber + Coil Spring
2010-2012 -- Ambassador Front Shock + Coil Spring
2012-present -- Ambassador Front Shock + Coil Spring
The coil springs have done 70,000Kms approx.
The warranty was for 2 years or 40,000kms.
This design was made by Tough Dog, now there are a lot of manufacturers.
A friend of mine (matchless) is currently working on importing RTC Dampers, will keep you updated.
Arka
The Jeep - MM540XD Transformed! dhanushs 4x4 Vehicles 65 26th October 2017 20:26
My Jeep Story Continues! Now, the MM540XD dhanushs 4x4 Vehicles 197 3rd October 2013 20:04
Problems after converting MM540XD 2WD to 4WD HJ13 4x4 Technical 44 27th January 2012 16:41
To upgrade or not to upgrade? Steeroid Tyre & Alloy wheel Section 22 20th June 2007 19:13
Audio system upgrade for Octavia Ambiente cruise_control In-Car Entertainment 7 14th September 2004 17:46
