Old 30th January 2009, 12:37   #31
ex670c's Avatar
Thanked: 1,821 Times
Default Upgrade - Part II
Once the dates were finalized for Munnar OTR, I decided to upgrade my MM540XD a bit more.
The Following Work was done
1) Strip the old rusted body
2) Strip/Prime/Paint the Chassis
3) Install a new Tub (old 1987 MM540DP) and new Body beds.
4) Change the rear Axle to Bolero
Arka
Old 30th January 2009, 12:49   #32
Samurai's Avatar
Thanked: 15,775 Times
Only to complain later that Munnar trail was not challenging enough.
Old 30th January 2009, 13:44   #33
Blue Thunder's Avatar
Thanked: 335 Times
Question
...3) Install a new Tub (old 1987 MM540DP) and new Body beds....
Arka, that tub looks familiar ??
Blue Thunder is offline   Reply With Quote
Old 30th January 2009, 18:30   #34
DirtyDan's Avatar
Thanked: 776 Times
Hi Arka, are you going to rust proof it after painting? What will you use to do this if so?
Why did you change to Bolero axles? Wider stance?
Old 31st January 2009, 11:39   #35
ex670c's Avatar
Default Wider Axles
Hi Dirty_Dan,
I will sand blast the body and do the minor tinkering and then considering one of the following Primers
1) Polyurethane Primer
2) Expoxy Primer
3) Zinc Sulphate
4) Red Oxide
While tinkering I have given strict instruction not to use Bondo/metal Paste.
Because the metal paste absorbs water and rust the sheet metal.
Bolero Axles.
After the Front OKBJ conversion the track difference was 6".
1) Vehicle was looking very funny
2) I wanted to switch to One Piece FFRA. The older setup the outer flange develops play/slack and cuts the axle splines. ( suffered that twice)
Also wrt NGCS MM550XD (post 2004). They use 53" Front and Rear Track.
Old 5th February 2009, 10:54   #36
ex670c's Avatar
Default Chassis Painting and Body Swap
The Following work was done
1) The Old body was removed from the chassis
2) The chassis was scrapped of old paint
3) Chassis was washed with washing soda
4) Chassis was primed & painted
5) New Body (1987) was fitted with new body beds/mounts
Old 5th February 2009, 11:05   #37
starter's Avatar
Thanked: 327 Times
Hi Naren,
Could you please specify on which New or Old M&M vehicles these Diff-Ratios are used.
3.73:1 = 41/11
Arka
Dear Arka,
I've been researching quite a lot on 4X4s available in market currently (affordable ones though). I think the new Major (CL550) comes with the differential ratio of 3.73:1. I am a real rookie in this, so maybe, i am wrong. If so, please excuse me.
Cheers,
Deepak
starter is offline   Reply With Quote
Old 5th February 2009, 11:42   #38
vinod_nookala's Avatar
Thanked: 416 Times
wonderful arka,
You are practically doing a mini restoration project. Work happening at lightening pace i suppose!! What tyres are you planning to replace your current NDMS?
Long time since we met...let us meet up some time!! :-)))))
P.S- Must appriciate your sourcing ability, you sourced rare bolero 4wd axles and now a complete body which seems to be in good condition!
vinod_nookala is offline   Reply With Quote
Old 5th February 2009, 12:12   #39
ex670c's Avatar
Default Rear Differential
Since my front track was 57" and Rear track was 51".
I decided to change the rear track to the Bolero Differential.
The Only catch was the Bolero Differential was off-set to the left where as the MM540 differential is off-set to the right.
So I had the Bolero Differential Axle Tubes switched around.
The First Batch of Pictures -
LSD
Differential Housing and switched tubes
Inner Oil Seal
Pinion Yoke replaced the Companion Flange.
Old 5th February 2009, 12:21   #40
Thanked: 416 Times
so, now you have a right offset diff?? What is the length of bolero rear axle? 53inch?
I thought MM550 NGCS came with 53 front and 51 rear. 57 inch of your isnt too broad?
Old 5th February 2009, 12:39   #41
ex670c's Avatar
Default Ngcs Mm550
Hi Vinod,
I was under the impression that the NGCS was 53" Front and 53" FFRA.
Arka
Old 5th February 2009, 12:48   #42
ex670c's Avatar
Default 1 piece FFRA
The New 1 Piece FFRA.
Pictures of
1) Drum 139.7 PCD
2) Hub 139.7 PCD
3) Comparison of the Spindles
4) FFRA Assembly
Old 5th February 2009, 13:50   #43
Thanked: 416 Times
Now you will have clean rear rims without oil stains!!:-))))
Old 5th February 2009, 14:41   #44
fk7
fk7's Avatar
Thanked: 142 Times
i can see that you have army rims, what tyres are you putting on those?
FK
fk7 is offline   Reply With Quote
Old 6th February 2009, 11:01   #45
ex670c's Avatar
Default Tyres
FK
MRF Sand Grip 7.50X16 for Sand and Rocky terrain
MRF NDMS 7.00X16 for Muddy Terrain.
I'm looking out for good Mud-Terrain (Maxxis/BFG) in 235-85-16/245-75-16/255-85-16
The Jeep - MM540XD Transformed! dhanushs 4x4 Vehicles 65 26th October 2017 20:26
My Jeep Story Continues! Now, the MM540XD dhanushs 4x4 Vehicles 197 3rd October 2013 20:04
Problems after converting MM540XD 2WD to 4WD HJ13 4x4 Technical 44 27th January 2012 16:41
To upgrade or not to upgrade? Steeroid Tyre & Alloy wheel Section 22 20th June 2007 19:13
Audio system upgrade for Octavia Ambiente cruise_control In-Car Entertainment 7 14th September 2004 17:46
