Old 16th April 2009, 17:40   #61
ex670c's Avatar
Thanked: 1,821 Times
Default Correction
Originally Posted by ex670c View Post
For the Maxx Series
Front Solid Axle - 57" Track
Rear Solid Axle (FFRA) - 59"Track
Bolero
Front Solid Axle - 57"Track
Rear Solid Axle - 54"Track (FFRA & Semi-Floating)
CORRECTION
Maxx Series LX Festiva/Festara/Maxxi Truck/Underslung/Overslung
Front - 57"
Rear - 59" FFRA
Bolero
Front - 57"
Rear - 53" FFRA
Savari/Utility/Pikup
Front - 57"
Rear - 53"
Marshal 2000/2000 DLX/Royale
Front - 57"
Rear - 53"
MM ISUZU (I suspect the same for the post 2004 NGCS MM550XD)
Front - 57"
Rear - 53"
Some of the MM550XD(pre 2004)/Pikup/Utility/Bolero Invader comes with a Dana 44 3/4 Floating (Semi-Floating) Axle with 30 Splines.
Rest of them are Dana 44 19 Spline FFRA.
Old 16th April 2009, 18:07   #62
vinod_nookala's Avatar
Thanked: 416 Times
CORRECTION
Front - 57"
Rear - 59" FFRA
Bolero
Front - 57"
Rear - 53" FFRA
Front - 57"
Rear - 53"
Front - 57"
Rear - 53"
Front - 57"
Rear - 53"
Bolero Invader rear axle is 59" i think or may be 57". The front and rear track match very closely unlike every other M&M vehicles. The rear of Invader is overslung inverted leaf. This is soft but has not so good articulation.
vinod_nookala is offline   Reply With Quote
Old 17th April 2009, 01:00   #63
Alfa_Kilo's Avatar
CORRECTION
Front - 57"
Rear - 59" FFRA
Bolero
Front - 57"
Rear - 53" FFRA
Front - 57"
Rear - 53"
Front - 57"
Rear - 53"
Front - 57"
Rear - 53"
The only 30 spline are the army MM550XD with rear TRAK-LOK LSD. Rest are all 19 spline. The only other 30 spline 44 in India is the LSD version of the Safari rear axle.
Semi floating is different from 3/4 floating. All D44 are either semi or fully floating. 3/4 floating is rare these days, but used to be common on old car rear axles.
There is a workshop in Delhi (branded MAIN) which makes jugad 30 spl axles for jeeps, but their stuff is expensive scrap metal. They measure their tolerences in inches instead of microns.
Was the MM ISZ 1.8 NGCS?
Alfa_Kilo is offline   Reply With Quote
Old 17th April 2009, 10:29   #64
ex670c's Avatar
Look around some more M&M Vehicles and Tata vehicles.
M&M Bolero Invader, Bolero Camper - They are all Dana 44 -30Spline.
TATA - 207
3/4 Floating is a term applied to the 1 piece Semi-Floating Axles which was introduced in INDIA with the Dana 44 -30 Spline.
In a 3/4 Floating 1 piece axle the Wheel Bearing is held by a Backing plate & 5 HT Bolts, unlike the regular Castle Nut and cotter pin.
Arka
Old 17th April 2009, 10:46   #65
Alfa_Kilo's Avatar
TATA - 207
Arka
3/4 floating has two bearings at the wheel end, one supporting the hub and the other supporting the axle/halfshaft. All semifloaters have only one bearing at the wheel end, flanged or tapered axles.
Old 17th April 2009, 10:53   #66
ex670c's Avatar
Thanks for the Information, any pictures or Diagrams of this setup will greatly help in understanding this design.
Old 17th April 2009, 11:32   #67
Alfa_Kilo's Avatar
Correction. Threequater floating need not always have two bearing at the wheel end. If there is only one bearing, it supports the hub rather than the axle. The axle takes up the torsion load along longtudenal and vetical axes.
FF - Pair of bearing betwwen the hub and axle tube take all loads except torsion along the axle axis.
SF - The one bearing between the axle tube and axle/halfshaft takes up all linear forces, while the shaft takes care of all bending forces. (In many SF types, the transverse linear forces are transmitted between taper roller bearings throught the axle shafts via a floating thrust block in the diff.)
3/4F - The bearing/s (between hub and axle tube) take up all linear forces and the axle shaft absorbs torsion along all axes.
You will have to google for pics.
Old 18th April 2009, 02:55   #68
4x4addict's Avatar
Thanked: 2,669 Times
No Difference.
The Rear Differential is off-set Left in the Bolero Series and Centered in the MAXX series.
To replace the rear diff for my 540 with a wider track. Is it better to use one from Bolero 4WD or the Pik up?
4x4addict is offline   Reply With Quote
Old 19th April 2009, 10:48   #69
ex670c's Avatar
Semi floating vs Full-Floating
30 spline vs 19 spline
Either ways you will have to switch the arms, for MM540 you need a right off-set differential.
Old 19th April 2009, 13:17   #70
Thanked: 655 Times
If I remember correctly, Tini has a NGT gearbox with a borg Warner transfer case. He will then need a left offset rear differential.
jyobeb is offline   Reply With Quote
Old 19th April 2009, 18:13   #71
4x4addict's Avatar
Actually Arka had clarified a point earlier that mine is not the Borg Warner Tcase but the Splicer with the shift patter changed to shift in a single line similar to the Borg Warner unit.
I also confirmed with my mechanic that the off set remains the same as for the standard 4WD 540, so I guess I will have to do pretty much the same thing Arka has done by swapping the tubes around. My only concern is that I currently have the 4.27 crown/pinion and the Bolero 4WD with the XD3P probably comes with the 4.88 (i.e) same as the MM550 and if the Bolero has 30 splines, I will not be able to use the axles as I don't know if I can get the 4.27 ratio with the 30 spline axles. I guess I will have to buy the 4.27 ration crown/pinion with 30 spline. I am hoping this ratio maybe available from the Mahindra Bolero 4WD with the DI engine.
Old 19th April 2009, 18:44   #72
Brutus's Avatar
Thanked: 45 Times
Yuo got the semi floating 30spline axle right? my Bolero is full-floating and it has 19 spline axles. A Dana44 is called so becasue of the differential pumkin housing. Only the carrier housing is different between the 2 ratios because of the carrier breaks( one carrier housing can manage ratios below a certain ratio and the other above it, and this is called carrier break. If there are lots of ratios, then there will be lots of carrier housings too. One carrier, usually manages about 2-5 ratios, depending upon the model of the differential)though even the side gears too are designed for 30 splines and 19 splines respectively, but they have the same external measurements. Keep the stock carrier inside your original differential, enabling you to keep the same crown/pinion, but change the spider/side gears to the other axle type, simple. Only the LSD carrier would be different. If i'am wrong, someone please correct me.
Brutus is offline   Reply With Quote
Old 29th June 2009, 10:51   #73
ex670c's Avatar
Default Final Upgrades
Hi Guys,
Its customary for me to Upgrade the MM540XD before TPC, every year.
I feel, that the MM540XD, has been upgraded enough, barring a few bolt on kits, then I want to rebuild another JEEP.
The Upgrades.
1) Rear Dog-Clutch LSD. aka Auto-Locker (Lock-Right 2413)
2) Snorkel - Britpart NRC6920 Dome
3) un-restricted exhaust - like the NGCS MM550XD, a little bit more flushed in.
4) Extended Body Beds. - Like the Armada Grand/Bolero NGCS Series
Arka
Old 29th June 2009, 11:57   #74
Thanked: 416 Times
Hi Guys,
The Upgrades.
Arka
Wonderful arka!! Now please post some pics of installation etc etc...
Old 29th June 2009, 22:23   #75
joshguy's Avatar
Thanked: 92 Times
Hi All,
I didnt understand a bit of information in this thread But hope to know all these soon.
By the way arka i ve been seeing both your jeeps almost every day at your home (i suppose thats your house,near icici mahalingapuram) and hope to meet you some day
OFF TOPIC: I am a gypsy lover and i want to know if it is possible to make the gypsy's suspension softer by any means?
joshguy is offline   Reply With Quote
The Jeep - MM540XD Transformed! dhanushs 4x4 Vehicles 65 26th October 2017 20:26
My Jeep Story Continues! Now, the MM540XD dhanushs 4x4 Vehicles 197 3rd October 2013 20:04
Problems after converting MM540XD 2WD to 4WD HJ13 4x4 Technical 44 27th January 2012 16:41
To upgrade or not to upgrade? Steeroid Tyre & Alloy wheel Section 22 20th June 2007 19:13
Audio system upgrade for Octavia Ambiente cruise_control In-Car Entertainment 7 14th September 2004 17:46
