Old 24th July 2009, 17:27   #106
vinod_nookala's Avatar
Thanked: 411 Times
Originally Posted by Alfa_Kilo View Post
The Lockers, strictly speaking are not differentials, as they do not distribute power between the two wheels. The locker 'unlocks' one (outer) wheel during a turn and lets it spin faster (effectively freewheeling) than the crown gear. It makes the vehicle one wheel drive during a turn, hence the understeer (inside rear wheel pushing against the turn). On a slick surface, like ice, when the inner wheel overcomes grip, there could be very violent (spectacular for some) transition from understeer to oversteer.
A locker on the front axle may make turning very difficult offroad.
Very useful input buddy!!
vinod_nookala is offline   Reply With Quote
Old 24th July 2009, 22:56   #107
khan_sultan's Avatar
Thanked: 3,466 Times
Hey Arka,
Somehow missed updates to the thread here and saw it recently. So you enjoying the locker :-)
Originally Posted by ex670c View Post
3) The trick is not to power out of a turn, but to coast into is with a steady foot and ease out after exiting the turn.
or
take the turn with the clutch depressed, but that way when you disengage and apply power the lockers -- LOCK UP .
A minor adjustment that should take care of the 'clunk clunk' noise most of the time. However, this also means that people who don't have experience driving a locker enabled vehicle will find it strange driving it -- especially in traffic/turning. Be careful with who drives your vehicle as it may lead to undesirable results
khan_sultan is offline   Reply With Quote
Old 25th July 2009, 12:21   #108
ex670c's Avatar
Thanked: 1,799 Times
Hi Shahnawaz,
The JEEP is now Point-and-shoot, anyone manages every climb, that is if they manage to point her right .
The Difference in OTR driving with a rear LSD vis-a-vis an autolocker.
1) LSD prefer a slower approach otherwise they open.
2) Lockers you can get aggressive
Arka
Old 14th September 2009, 12:07   #109
ex670c's Avatar
Default Tpc09
Hi Guys,
I upgraded the radiator to a 4 core system just before TPC09, as there were overheating issues.
Finally I realized that the head gasket was blown as the compression would leak into the water jacket and boil the water, and had to replace that before the event.
some pics from TPC09
Old 14th September 2009, 12:24   #110
Thanked: 411 Times
Arka,
Do something about your fender, wheels are fouling big time spoiling tyres and body work. Go for positive offset new rims. I know it is expensive to change PCD and all, but worth it as this is your daily drive. This will further bring the track to NGCS MM550 XD standards, will better ride quality and solve articulation issues.
Old 14th September 2009, 13:38   #111
ex670c's Avatar
Default Fenders
Originally Posted by vinod_nookala View Post
Arka,
Hi Vinod,
Postive Off-Set wheel-discs will not make too much of a difference, wrt fouling the fenders, but the suspension will improve.
The NGCS true to its name has different suspension and the front anti roll bar to prevent this kind of articulation.
I have added an box channel under the fender to prevent it from getting torn.
Arka
Old 14th September 2009, 13:51   #112
Thanked: 411 Times
Default Tyre tear?
Hi Vinod,
Arka
Arka,
Which is stronger tyre or the fender? What will you do for tyre not getting torn?
Positive offset rims will provide room for additonal travel, surely they will touch but they will only under extreme ariculation. Anyway you need to change rims to avoid fouling even with a NDMS 6.00/7.00-16. You are highly unlikely to go for smaller tyre even if you pickup an exclusive off road set. They are touching outter fender (near indicator) hence the need to change rim. Your's is now fouling just with about 50% of reserve articulation! Check the last picture you have posted. Plus rubbing of tyre will add to the brakeing effect, loosing momentum.
p.s- Cost effective solution could be jacked up body beds. What say?
Old 14th September 2009, 21:11   #113
joshguy's Avatar
Thanked: 92 Times
Arka,
Hi What is positive/negative offset rims? i have heard of them but have no idea what it is.
joshguy is offline   Reply With Quote
Old 14th September 2009, 21:20   #114
rjstyles69's Avatar
Thanked: 791 Times
here you go
Offset (wheel) - Wikipedia, the free encyclopedia
Old 15th September 2009, 12:07   #115
joshguy's Avatar
Thanked: 92 Times
Thanks for the info
Old 2nd November 2009, 12:56   #116
ex670c's Avatar
Default Ramp Travel & Articulation
Hi Guys,
Last Monday (26-10) Headers, HotRod & Sanjay David, met up at IGNITE to test Headers suspension upgrades on his MG413W.
Did a few test on my MM540XD and Sanjay David's MM540.
We did not take any measurements neither did we deflate the tyres.
Arka
PS - more pics to follow
Old 2nd November 2009, 13:04   #117
rjstyles69's Avatar
Thanked: 791 Times
arka 1st pic,its clearly visible that the tires fouling with the wheel fenders. Am sure it would be bothering for a fact that he metal scrapping thru the rubber isn't a good sight . What do you plan to do about it ?
Old 2nd November 2009, 13:08   #118
Samurai's Avatar
Thanked: 14,536 Times
Arka, why the tame street tyres? BTW, is it legal to split the license plates like that?
Old 2nd November 2009, 13:18   #119
ex670c's Avatar
Default License to Flex
There is nothing simple that I can do.
The Forward Traction is hardly affected with the front LSD and Rear Locker.
The Fenders don't cut into the tyres as the re-tread is 12ply.
To tame the Streets , I have never been stopped for the No. Plate yet.
Besides I have 2 more sets for Sand & Mud.
Old 9th November 2009, 14:25   #120
ex670c's Avatar
Default Some more on the Ramp
some more pics, including Headers MG413W, and Sanjay David's MM540.
The Jeep - MM540XD Transformed! dhanushs 4x4 Vehicles 65 26th October 2017 20:26
My Jeep Story Continues! Now, the MM540XD dhanushs 4x4 Vehicles 197 3rd October 2013 20:04
Problems after converting MM540XD 2WD to 4WD HJ13 4x4 Technical 44 27th January 2012 16:41
To upgrade or not to upgrade? Steeroid Tyre & Alloy wheel Section 22 20th June 2007 19:13
Audio system upgrade for Octavia Ambiente cruise_control In-Car Entertainment 7 14th September 2004 17:46
