4x4 Vehicles Jeeps, Gypsies, Gurkhas, Jongas et al
Thread Tools
Old 22nd January 2009, 11:46   #46 (permalink)
harjeev's Avatar
Here are some of the NIOC OTR pics and I took some pics of the inside of the 550. Will post soon
Picasa Web Albums - Harjeev - OTR on 20/12/...
Picasa Web Albums - Harjeev - OTR 03012009
Picasa Web Albums - Harjeev - OTR 14122008
__________________
2007 Tata Safari 2.2 VTT
2000 Ex-Army MM550
1985 Ex-Army CJ3B
1963 WILLYS CJ3B
Wishlist
2011 Gypsy 1.3 MPFI
harjeev is offline   Reply With Quote
Old 22nd January 2009, 18:19   #47 (permalink)
4x4addict's Avatar
Infractions: 0/1 (7)
Harjeev,
Those are some great pictures. Looks like you guys had a great time.
4x4addict is offline   Reply With Quote
Old 31st January 2009, 13:15   #48 (permalink)
Hi All,
Update Time!!!!
Firstly sorry for late updation.
Last week during Republic day weekend , I was there in Kolhapur for 3 days and happt to see my Jeep work was going on well. Following things happened in the last week.
1) Engine dismantled fully - Cleaning started for all parts of engine with diesel.
2) Body Tub taken out from Chasis - Body Tub work is going on -
Floor cleaned and weilded sheet if damaged any portion
B pillar roof support repaired to its original position which was damaged because of Crain Ropes
Front grill repaired and Fenders were being repaired
Entire Chasis cleaned with diesel and detergent with wire gauge throughly and with water in servicing centre
Avadhut (our head technician) dismantled front wheels and removed all thicked grease from knuckle,bearing. Axles removed and cleaned with diesel
Brake assembly also removed and cleaned .New Shock abs set purchased for front
3) FIP given to Lucas TVS for caliberation - will get it today after caliberation
4) Engine/Head/piston given for job work and caliberation - Engine /Head/piston is ready . Only it took time because the cylider sleeves are more thick than any other vehicle
5) Leaf springs work going on - will change only if any cut or damaged. But looks like no cut anywhere.When I was there the dismantling of Front suspension started in my presence only.
6) Starter and alternater has gone for overhauling
This weekend I can not go to see the progress due to work commitments but next week again I will go and check the same. Till that time I am expecting following work to be completed
a) Engine assembling - Will try to start the engine after assembly
b) Complete Chasis/Wheel/Brake work including the painting and antirust coating on Chasis
c) Complete Body work with all repaires - will check if body alignment can be done keeping body tub on chasis
d) Will try to paint underbody with antirust.
Lets see how much I can complete .
Again I am requesting all of you to give your feedback on the progress and also post some pics inside 550 to come to a conclusion for look of the Jeep.
Tarkesh
__________________
I always did what I wanted!!! I bought Jeep 4X4 - My Childhood Dream !!!!
Ricky_3007 is offline   Reply With Quote
Old 31st January 2009, 16:46   #49 (permalink)
harjeev's Avatar
great to see your work going on in full swing. Keep it up.
When do you expect to start the engine and what color do you plan to paint the Jeep with
__________________
2000 Ex-Army MM550
1985 Ex-Army CJ3B
1963 WILLYS CJ3B
Wishlist
2011 Gypsy 1.3 MPFI
Old 31st January 2009, 17:13   #50 (permalink)
fk7
fk7's Avatar
Hi Harjeev,
Please do not forget to post the interior pictures
FK
fk7 is online now   Reply With Quote
Old 31st January 2009, 17:42   #51 (permalink)
Hi Harjeev,
I am expecting to start engine in next week only , may be on next saturday or Sunday . Till the time Avadhut will aeemble the engine and if he works faster then it may start before also(in that case I will not be there to hear that sweet sound) Lets see if it happens early also I have no issues.
I am planning the Army color only - Olive Green But Super Glossy . I may just tinker(bit darker) the shade to avoid exact resemblence with Army Jeep but not much. I want to retain the same shade as Army Green .
I forgot to mention I am planning to put set of Bucket seats in front and Innova middle seat(Flat seat for 2 - Not Bucket one) in the rear. I am searching for nice set of bucket seats for front . My brother has got a link of CR-V front seats but the negotiations are on.
BTW You were talking about some soundproofing in your thread , can you pls explin it? Also post some interior pics of 550
Tarkesh
__________________
Old 11th February 2009, 17:42   #52 (permalink)
Hi Freinds ,
Just a small question about the Gear box /differentials ratios for both - normal and 4x4 gear box for my 550.
How will I know that the ratios are correctly adjusted on gear box. Is there any tool for it or any caliberation has to happen for this?
I am sorry if I am not able to ask the question correctly.
If needed I will give the exact gear box and diff nos.
Pls help.
Tarkesh
__________________
Old 12th February 2009, 10:16   #53 (permalink)
susan3004's Avatar
Hi Tarkesh,
I have posted many pics of army M&Ms of different threads. Let me know if anything in more specifics is required.
susan3004 is offline   Reply With Quote
Old 12th February 2009, 14:17   #54 (permalink)
Originally Posted by susan3004 View Post
Hi Tarkesh,
Hi Susan,
For pics - I need specific interior pics of 550 probly Army ones.
For Gear box and Diff - I am confused.
Tarkesh Telvekar
__________________
Old 12th February 2009, 15:08   #55 (permalink)
simply_sunny001's Avatar
A question for Ricky and Major
is Olive green color allowed on civilian jeeps ?
And what about the jeeps auctioned off from army ? Can we retain the same color ?
Also,can we have the camouflage color scheme which i have seen on army gypsies ?
__________________
2006 Tata Safari 3.0 L
2005 Enfield Bullet Electra 350
2004 Maruti Zen
simply_sunny001 is online now   Reply With Quote
Old 12th February 2009, 15:33   #56 (permalink)
Hi Sunny,
Not exactly the same Olive green color but bit tinkered so
I think camouflage is not allowed.
Tarkesh
__________________
Old 16th February 2009, 14:07   #57 (permalink)
Question Heater Plugs
Hi All,
My work of engine start up is stuck up due to unavailability of proper Heater Plugs.
The MICO Heater Plug which is available in market is having following no on it
MICO India - 0250 200 056 888
Pls help guys what is the exact Heater Plug no for Army Spec 550 ?
I am eagarly waiting to hear the first cranc .
Tarkesh
__________________
Old 16th February 2009, 14:12   #58 (permalink)
harjeev's Avatar
Originally Posted by Ricky_3007 View Post
Hi All,
Tarkesh
The heater plug though important, I think that the engine should be able to be started without it too?? Wont it???
__________________
2000 Ex-Army MM550
1985 Ex-Army CJ3B
1963 WILLYS CJ3B
Wishlist
2011 Gypsy 1.3 MPFI
Old 16th February 2009, 15:05   #59 (permalink)
Yes you can start a diesel set even if the glowplugs are not functioning. I used to own a VW Golf which was started a few times by the RAC when the glow plugs needed replacing. They used to spray some sort of starter air spray down the air intake whilst cranking the engine continously. Eventually it would start and I could drive down to the local auto repair place to get new glowplugs fitted.
If say 2 glowplugs are gone you can turn the ignition on and off a few times and it may start.
If you are really stuck then there are a few sellers on ebay although shipping to India etc may slow down you restoration by a few weeks. My father is flying over next week so if you can find some on ebay or a UK retailer I can ask him to carry to India and post to you.
bigman is online now   Reply With Quote
Old 16th February 2009, 15:18   #60 (permalink)
Thanks Harjeev and Bigman,
I will try . But can you pls help me in getting the exact no of Heater Plug because the mentioned plug is not fitting into the engine and as per the Spare part dealer the Part no should be different as this is army spec engine.
Pls help me in this as anyways I would require these new set of heater plugs .
You guys can probably see your heater plug nos and let me know as you also have same 550XD - XD3) engine (mine is 1999 model)
Tarkesh
__________________
Thread Tools
Project MM550 Xd Army Spec jeepsan 4x4 Vehicles 33 14th October 2009 11:17
For all those looking for MM550 Army jeeps.. Randhawa 4x4 Vehicles 128 4th October 2009 14:21
wanted to get some info about an army spec Mahindra mm550 sabret00the SUVs, MUVs & 4x4s 67 20th August 2008 02:03
MM550 Army 4x4 Jeeps 4x4addict 4x4 Vehicles 43 2nd January 2008 11:27
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
