Old 3rd February 2009, 20:50   #16
Thanked: 658 Times
how come your golden jeep is in such a condition. It was such a nice jeep.
Old 3rd February 2009, 22:10   #17
Alfa_Kilo's Avatar
Default Trak-lok LSD
Today I finished work on the rear axle. Replaced the OE crown and pinion with a lower ratio set.
I was planning to convert the rear axle to full floating type, and bought some parts for it in Mayapuri. The flanged axle shaft turned out to be an inch too short, had no oil seal seats and one of the spindles was slightly eccentric. I am retaining the semi-floating setup for now. Please be careful with any FFRA conversions carried out in that area.
The TRAK-LOK LSD
Adjusting backlash
@Siralec
The golden jeep was always rubbish. It was living on life support all these years. It is going to be scrapped now. It has an Isuzu engine and GB, which are impossible to fix as spares are not available, and it is a 2WD.
@Harjeev
I have seen the 'is born' series. It is quite interesting to watch. I will give the cost breakup one the vehicle is ready.
Alfa_Kilo is offline   Reply With Quote
Old 13th February 2009, 00:21   #18
Alfa_Kilo's Avatar
Default axles rebuilt
The axles have been rebuilt with new ring and pinion sets. All the bearings and oil seals were also replaced.
I will be runing on my 235/75R15 Michelin AT tyres initially as the tyres I have ordered will take time to arrive.
The transfer case and GB have been stripped. A PTO will be installed during reassembly.
Old 13th February 2009, 01:19   #19
Thanked: 21 Times
What shockers are you using ?
bigman is offline   Reply With Quote
Old 13th February 2009, 10:17   #20
Alfa_Kilo's Avatar
Stock Gabriel from a Mahindra spares shop. They are labelled as 'Jeep Taxi'.
Old 17th February 2009, 01:40   #21
Alfa_Kilo's Avatar
Default TCase
Output shaft and gears
Intermediate shaft and gears
PTO shaft
Old 2nd March 2009, 00:23   #22
Thanked: 245 Times
Any updates on the jeep front?
cheers
vishwas
vishwaschettri is offline   Reply With Quote
Old 2nd March 2009, 00:40   #23
Alfa_Kilo's Avatar
I am working on the engine these days. I will post pictures in ca few days.
Everything done except engine and electricals.
Old 2nd March 2009, 01:01   #24
Thanked: 245 Times
Great, nice to hear that. Waiting for the pics.
Remember you promised a break up of the costs involved. Please post a teaser if possible.
cheers
vishwas
Old 16th March 2009, 00:21   #25
Alfa_Kilo's Avatar
Default Engine rebuilt!
I finally finished work on the engine today. The block and crank machining took longer than expected and then I was out of station for a week.
The engine has go new liners, pistons, ground crank, bearings, cam shaft, rocker shaft, timing chain, valves etc.
The main GB has also been refurbished.
Oil pump
More updates tomorrow...
Old 16th March 2009, 08:39   #26
harjeev's Avatar
Thanked: 256 Times
Great going Alfa.
Yes like everybody I am waiting for the pricing details too.
Did you start the engine? If yes we would like to see the video too!!!
harjeev is offline   Reply With Quote
Old 17th March 2009, 13:11   #27
pole_position's Avatar
I have a feeling this ones going to be real good
Good Luck!!
pole_position is offline   Reply With Quote
Old 17th March 2009, 15:15   #28
DesertKing's Avatar
Thanked: 18 Times
Hi Alfa_Kilo, I am excited to know about your new workshop in Jaipur. I will surely meet you and your MM550 there. It seems to a great project. Pls keep update your thread. Posting some question which are in my mind..
33" tyres :: which rims and tyres are you planning to use (tyre size pls).
The fuel tank will be lifted :: pls post more detail on this. Seems good.
Snorkel air intake :: I always dreamed about it and hopefully I will take your help in future on this. \
replace the rear LSD with a differential lock :: Why???? I guess by fitting an LSD, you Jeep will perform better in soft sand and mud.
POWER STEERING :: pls do not forget about this.
DesertKing is offline   Reply With Quote
Old 17th March 2009, 21:53   #29
sat
Thanked: 59 Times
great going Alfa Kilo
sat
sat is offline   Reply With Quote
Old 19th March 2009, 01:05   #30
Alfa_Kilo's Avatar
Originally Posted by harjeev View Post
Great going Alfa.
I fired her up today, but could not tak a video as i work alone. I will give the pricing breakup once the vehicle is complete.
You are welcome to see my place when you are in Jaipur. I am installing 33-10.5R15 (actual dia 32.8") BFG MTs. I wanted 8.25R16 Michelin XZLs but they harder to locate than hen's teeth.
The stock LSD is worn to the point of practically being an open diff. A diff lock will come later...
I will NOT install a power assistance as it makes the steering too numb. I had a 540 with 235/75R15 tyres (at 25psi) and manual steering was perfectly OK for me then.
sat
Thanks.
MM550XD to Sarbloh 550 Jaskirat 4x4 Vehicles 20 7th October 2011 20:18
Wheel Alignment Data for MM550XD Jaskirat 4x4 Technical 4 5th September 2011 10:38
MM550xd 5 doors??!! 4x4 loaded 4x4 Vehicles 10 24th April 2009 19:10
