Old 19th March 2009, 02:38   #31
Infractions: 0/1 (5)
great work AK . Even i am looking for a jeep for the last few months. will be glued to this thread.
4x4 loaded is offline   Reply With Quote
Old 23rd March 2009, 03:22   #32
Alfa_Kilo's Avatar
All the mechanicals have been overhauled and the chassis is ready to accept the body. The only thing remaining is the exhaust pipe.
PS: Avoid painting the chassis 'chemical sludge' blue.
Alfa_Kilo is offline   Reply With Quote
Old 23rd March 2009, 03:28   #33
Thanked: 23 Times
Looks good, how far are you with the body ?
Any reason why you should not paint chemical blue ? I think a few of us have our chassis painted black. But if you ever get a leak then a blue or green chassis can aid in finding the source.
Also those two tubular pieces on either side are they the side step bars ?
bigman is offline   Reply With Quote
Old 23rd March 2009, 03:33   #34
Alfa_Kilo's Avatar
Good point.
But it looks like old plastic decaying in the sun at a landfill site.
Old 31st March 2009, 00:15   #35
Alfa_Kilo's Avatar
I installed the tub today. It must be said that the body is very poorly designed, especially the mounting points. It also has too many moisture traps welcoming rust.
The transmission
Old 31st March 2009, 00:30   #36
Thanked: 247 Times
Nice nerf bars. What color have you decided on? Hope to see the final product soon.
cheers
vishwas
vishwaschettri is offline   (1) Thanks Reply With Quote
Old 31st March 2009, 00:45   #37
Alfa_Kilo's Avatar
The colour is matt off-white. I got the body painted off the chassis so that paint would reach the areas normally covered by joints and panels.
Old 31st March 2009, 12:44   #38
vinod_nookala's Avatar
Thanked: 417 Times
Alfa kilo,
What kind of body beds are you using? Also what are the parts that you have changed in the transfer case?
vinod_nookala is offline   Reply With Quote
Old 31st March 2009, 13:09   #39
Alfa_Kilo's Avatar
Originally Posted by vinod_nookala View Post
Alfa kilo,
The military 550 has thicker body mounting bushes compared to the civil version, and these bushes are shared with the pickup. I am using a pickup kit on my vehicle.
The 550 has 15 mountings including one for the grill and two bushes which are not bolted down.
I changed all bearings, oil seals and speedo pinion in the TCase. I also added a transmission handbrake and PTO.
Old 31st March 2009, 13:57   #40
Thanked: 417 Times
Alfa kilo,
Whats the cable running around your transmission?
Old 31st March 2009, 14:22   #41
Thanked: 23 Times
I know it is only visual but the blue side bars stick out like a sore thumb with the white tub. Do you plan to paint them black or any other colour ?
Old 31st March 2009, 16:06   #42
Brutus's Avatar
Thanked: 46 Times
Alfa kilo,
Thats the clutch cable.
Brutus is offline   Reply With Quote
Old 31st March 2009, 20:50   #43
Alfa_Kilo's Avatar
Yeah, I'll get it done black. The blue has turned out to be quite bad.
Old 1st April 2009, 12:08   #44
Thanked: 4,752 Times
Dear Vinod - ref your query in post 40 above, the cable is the clutch cable developed for RHD vehicles providing a direct connection to the clutch fork without using the old clutch cross shaft. As the original fork for RHD vehicles was on the right side of the transmission, the clutch cable radius was reducing so LHD fork was used for RHD application and standardized. It was developed for the Armada and deployed across models. However, now everything is obsolete as all vehicles have hydraulic clutch actuation.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   Reply With Quote
Old 1st April 2009, 14:26   #45
Alfa_Kilo's Avatar
Somehow I trust the cable links more than hydraulic clutch actuators. I have always had bad experiences with the oil line being torn off and pistons failing.
MM550XD to Sarbloh 550 Jaskirat 4x4 Vehicles 20 7th October 2011 20:18
Wheel Alignment Data for MM550XD Jaskirat 4x4 Technical 4 5th September 2011 10:38
MM550xd 5 doors??!! 4x4 loaded 4x4 Vehicles 10 24th April 2009 19:10
