Old 25th September 2009, 12:43   #226
gonewithwind's Avatar
Originally Posted by NIP View Post
Any base to this statement ? ALL Gypsies are petrol btw. Have you driven a King ?
I have only driven one Gypsy,that is a king MPFI 2009 model. I think all kings get 13 to 15 on the high way like mine do.May be it deffer gypsy to gypsy. What I
meant to say here is that new Gypsies give better mileage.
gonewithwind is offline   Reply With Quote
Old 25th September 2009, 14:49   #227
krishnathanthri's Avatar
Thanked: 41 Times
Originally Posted by IndrojitSircar View Post
The re build looks nice man!
Originally Posted by praveen4554 View Post
Krishna,
Beleive it or not . i was glued to computer to complete the full thread about your restoration,
Nice restoration , 100 days of effort - ultimate pay off
seriously i always adored gypsy ..but only thing i hated was they suck petrol .
Which part of bangalore you live ? seriously wanna look @ the RED BEAST!
Originally Posted by gonewithwind View Post
New Gypsy king sucks petrol only like any other hutch back cars.
This myth about pertrol consumption is probably related to MG410 not MG 413.
IndrojitSircar & praveen4554: Thanks. Yes it sucks petrol like water. Right now I am running it in petrol. I have a gas kit too but there is no gas tank, as the earlier owner was using gas Cylinder. I will use it once I service the gas kit and fit a gas tank. I am planning to go for 35Kg Capacity (Wagon R) type.
Price of gas per/kg is Rs30. Mileage will be 6 Km I heard.
Right now in petrol Rs 50/Ltr and am getting 8-9/Liter.
krishnathanthri is offline   Reply With Quote
Old 27th September 2009, 17:59   #228
Rossi's Avatar
Thanked: 7 Times
Hey Krishna, the restoration has come out well.
The Pleasure of driving the Gypsy will go away with Gas. I would recomend getting it tuned by a proper tuner & be soft on the acclerator for a decent mileage.
Just my two bits.
Rossi is offline   Reply With Quote
Old 16th October 2009, 18:19   #229
RuffRyder's Avatar
Hey Krishna,
Wanted to check with you about the soft top that you got done from Mysore.. can you give me the details of the same..my roof caught fire..
RuffRyder is offline   Reply With Quote
Old 20th October 2009, 09:38   #230
Thanked: 41 Times
Default soft top
Originally Posted by RuffRyder View Post
Hey Krishna,
From Agrahara Circle go towards Agrahara Police station, then take first left after Cycle brand Agarbathi building. You can see a board XXXXX Cushion and top woks. (Sorry, I am not able to recall the name of the shop). It’s the only Cushion workshop in that road. Let me know if you need more info.
Krishna
Old 20th October 2009, 09:58   #231
Gypsy-Boy's Avatar
Hey Krishna
I had gas on my king (the kit is still there but disconnected - and its for sale!!!) I have done OTR's and long drives on gas. I used to get a mileage of about 10(city) -12(Highway) KMPL.
The power drop was marginal in normal driving conditions.
I switched to petrol as I use the gypsy to ferry around about 1 ton of load and under these extreme conditions i used to have a serious drop in mileage (used to get about 6kmpl)
The kit I have is a BRC kit.
Please do not use the home gas cylinder as its illegal and risky.
GB
Do PM me if you have any more questions
Gypsy-Boy is offline   Reply With Quote
Old 20th October 2009, 11:02   #232
Thanked: 62 Times
Hi Krishna,
Congrats on the outset of getting such a great job done. Just sometime back I had come across a white 4x4 in a similar condition with a lot of rust on its underbody and I did not take it, wish I had done it and now would have been a proud owner of one...
Anyways, I wanted to comment on your quote above: if you compare the figures that you have quoted, the price per km on gas will be Rs. 5 and on Petrol is around 5.5 @ 9kmpl. So just for the 50 paise savings you will be going on to gas, which will lead to a host of other problems. And as Rossi said, please get it tuned up properly and go a bit easy on the accelerator, and you will have no regrets..
an_and is offline   Reply With Quote
Old 20th October 2009, 11:20   #233
Thanked: 41 Times
Originally Posted by Gypsy-Boy View Post
Hey Krishna
Originally Posted by an_and View Post
Hi Krishna,
GB: I saw your gypsy parked in Indranagar last week. The Front bumper is removed.
I have a kit fitted already, I am looking for a gas tank only. Preferably 35ltr. Wagon R type. What is the capacity of your gas tank and will you sell only the tank?
an_and: I have replaced my old Carb with a mikuni carb, Now the milage problem is solved i guess. Also changed the fuel supply, so that excess fuel goes back to the fuel tank.
I didnt check the milage after the alteration. Will check it soon.
Krishna
Old 21st October 2009, 09:34   #234
Gypsy-Boy's Avatar
Krishna
Hey Krishna
The front bumper went for painting but liked the look and have left it as is, and I stay in Indiranagar.
Do give me a call, and lets see if we can work something out for the tank.
GB
Old 26th October 2009, 16:16   #235
Thanked: 41 Times
Default 4x4 Issue resolved
Originally Posted by rmonie View Post
Krishna,
What you should check is the shifter sheet - which is an "O" ring at the base of the shifter. This needs to be replaced depending on use. The common indicator for replacement is the shifter getting stuck or being hard to shift across 2W /4H/ 4L. I went through the same problem as well!
Check out this link Suzuki Samurai Transfer Case Shifter Bushing Repair
Originally Posted by Gerardfdz View Post
The simple solution used to be - 1) ensure the wheels are straight, then rock the vehicle back and forth
Seeing a gypsy brings tears!
Originally Posted by Jaggu View Post
I started working out the 4x4 box on a weekly basis, in all the ratio's (for short while atleast) and after a month or so, this problem went away on its own. Not makhaan shift but typical hard shifts that you can expect from this vehicle.
Originally Posted by dwaraka View Post
Krishnatantri,
We all have experienced this problem.
Originally Posted by chargerman View Post
same thing happened to me the day i went to take delivery of my gypsy from the painters place!! it got stuck in N, it takes 10 mins of how dwarka explained to get it back running again, use it regularly it becomes fine!!
Hi all,
Since many days I was spending time on fixing others small problems in my Gypsy.
Recently I managed to get a Carb, this solved the engine getting off in low RPM.
This Saturday I got some interior work and also fitted the Music System. Sunday I Asked the mechanic to replace the Star joint (Front Shaft) and fit it. I also told him about the 4x4 lever getting stuck specially when shifting back to 2WD. He looked like an expert, he fitted the lever and tried shifting the Gear, and it was working all fine. I took it for a trial, went around 200Ft then I tried shifting back from 4WD to 2WD and there it goes, stuck again.
I walked down and asked the mec to check it again.
Later another mec was called, within 2 min he said, the problem is due to the lever sitting below the expected level and hence getting stuck and this needs shifter sheet (bushing) to be replaced. It was replaced and now its working fine.
Rmonie had said the same in July. The problem could have solved long back. I was lazy to go and get this work done. Anyways now its all fine. Thanks for all you people.
Biggest problem was, the earlier owner has changed the original gear lever to some other.
Old 9th November 2009, 14:45   #236
Thanked: 41 Times
Default Interior Pictur
Hi All,
I never posted the interior picture of my gypsy, So here it goes
Picture with all the lights on
Krishna Thanthri
Old 9th November 2009, 17:17   #237
Thanked: 57 Times
This is the best gypsy ive seen on Bhp. Have been following this thread since creation. Got time to post today . A spidey setup will rock this IMO.
I always dreamt of owning one.. lets see, some day.Mera number bhi aayega.
livyodream is offline   Reply With Quote
Old 21st December 2009, 11:17   #238
Thanked: 41 Times
Default Quick update
Hi all,
Its been long i have updated this tread.
Recently I have fitted a 5ft long CB antenna(With Spring) in my Gypsy.
Pic's will follow soon
Krishna
Old 21st December 2009, 13:46   #239
MexXxentric's Avatar
Thanked: 11 Times
N-E-A-T job.
you could have put new galvanized screws for the door handle
Hi All,
Krishna Thanthri
MexXxentric is offline   Reply With Quote
Old 18th January 2010, 10:23   #240
Thanked: 41 Times
Default CB Antenna
Pics after the CB Antenna Fitting..
2lac+ kilometers m800 engine rebuild project. SirAlec Modifications & Accessories 75 24th June 2013 17:36
My Gypsy rebuild - Stage 2 Anil Vincent 4x4 Vehicles 122 21st April 2011 11:43
My Gypsy Rebuild - Bushranger Ashish B 4x4 Vehicles 69 20th October 2010 08:31
