Old 25th June 2010, 21:07   #271
Thanked: 136 Times
What the! That is bad!
Were you able to find out why the seize happened in the first place?
HappyWheels is offline   Reply With Quote
Old 28th June 2010, 10:32   #272
krishnathanthri's Avatar
Thanked: 41 Times
Originally Posted by gypsy1989 View Post
Hope your engine work's going on fine. I was just curious to know as to how much the Mitsubishi Mirage seats cost?
Mirage seats cost me 7K after exchange of my old seat which was not sliding/Reclining. These old seats were valued 1k.
mitsubishi mirage = mitsubshi lancer in india, If you get it for 4-5k its good else you can go for recaro lookalikes going at 8k plus, very comfortable.
Here Recaro lookalikes doesn’t come so cheap, they cost around 12k for low quality and 14k for a slightly better quality ones. They look good but not very comfortable.
Mitsubishi mirage is a two door car hence the left seat has 3 knobs.
1. Recline
2. Slide
3. Recline + slide
The third knob is used for rear seat access.
Driver side seat includes Height Adjustment too.
I am not sure if these features are available in Indian Lancer's.
Originally Posted by Zorro4X4 View Post
You can do an Engine rebor three times. The stock pistons are size 0, you can get this rebored to size 1/2/3 (Oversize), after which you need to replace the block. But another solution is to send the block to Lathe and get it redone to size 0 (Stock).
Saturday I towed (using Ambassador) my gypsy to the Garage and by evening I got to know that, this will be the first bore ie .10 Over size.
I was pretty surprised, I thought this will be second or final bore looking at the age of the vehicle.
Joshguy/Happywheels: Oil level was low. I don’t know why I ignored the warning. .
Anyways this was an eye opener. From now onwards I will be careful.
krishnathanthri is offline   Reply With Quote
Old 28th June 2010, 10:53   #273
Thanks Pramod And Krishna,
I have been thinking of changing the seats in my Gypsy and somehow I was under the assumption that it wouldnt be this costly.But I do love the look of the seats you have put Krishna.
gypsy1989 is offline   Reply With Quote
Old 28th June 2010, 17:57   #274
Desmosedici's Avatar
Thanked: 408 Times
too bad Krishna but dont sell your Gypsy dude, you have done it up so well and taken pains. change the engine if you want to but dont sell man.
Desmosedici is offline   Reply With Quote
Old 29th June 2010, 09:35   #275
pramodkumar's Avatar
Thanked: 858 Times
1. Recline
2. Slide
3. Recline + slide
The old Mirage were 2 door, the fifth generation onwards they started having 4 doors and the indian lancer is more closly related to a mirage (97-2002) than the JDM lancer. Any way this is OT. Recaro/sparco look alikes are very cheap in Delhi as far as i can remember the lowest quote i got was 8k and that too 1 year ago(taiwan make). Every body has a "uncle in gelf", you can get this as low as 2k per seat in saudi, another bhpian yogi might be importing one. Recaros are indeed comfortable, they have good back and lumber support, not sure of the ones available here though. Since you are reboring get the water jacket also checked, you might endup wasting money if it has a crack.
Pramod
Old 2nd July 2010, 10:05   #276
MexXxentric's Avatar
Thanked: 11 Times
Pramod
Look-a-likes are just for looks. They got very bad ergonomics.
Better to have recaro/ sparco original
MexXxentric is offline   Reply With Quote
Old 2nd July 2010, 17:23   #277
Shall I assume that original Recaro's are not available in Bangalore?
Amit
Old 2nd July 2010, 19:32   #278
Thanked: 858 Times
Amit
They are available.
Pramod
Old 3rd July 2010, 00:10   #279
Kandisa's Avatar
Thanked: 425 Times
...Recaros are indeed comfortable, they have good back and lumber support, not sure of the ones available here though.
Yeah the original Recaros (& APCs too) are really comfortable but NOT the replicas or the look alikes! They are just for sheer look and just pathetic from ergonomics point of view. Recaro replica in gypsy will be a perfect combination if someone is looking for a slip disk or similar syndromes....!!! IMHO its better to go for a pair of 2nd hand good comfortable bucket seat (easily available within 7-8k) rather than spending 16 k on a pair of those replicas.
Kandisa is offline   Reply With Quote
Old 6th July 2010, 10:30   #280
Thanked: 858 Times
very true.
Krishna, i think you should make a trip up north to mayapuri, the 1.3 carb engines from the army gypsis are sold 6-7k a piece+ a king gearbox should really transform your gypsy. Your current engine + GB can easily be sold later to someone locally.
Pramod
Old 6th July 2010, 11:06   #281
Thanked: 41 Times
Pramod
Taking off from office, Going to mayapuri, Hunting for good engine (with my limited knowledge on Engine's) getting the engine checked by some Mech. Getting the engine to Bangalore. Instead of all these, I choose to find someone here in south, who can guarantee the spares even though the price is at a higher side.
So I enquired in blore/Mysore the cost of king Engine (Carb) + 5 speed Gb + king Transfer case = 45K.
Now add fitting charge + Bigger radiator + over hauling the engine.
I guess the cost will easily go up till 55K.
keeping all this in mind I choose to Rebore my existing Engine and use it for 1 or 2 years and later decide. May be by then MPFI engine will be easily available.
As of now the Engine work is complete, I told the mech to change the Clutch plate, Spark plug, Fan belt Etc. It should be read for test ride in another 2-3 hours. This is the first bore done on this Engine ( .1 size)
I will go and get her back to Blore tomorrow.
This weekend i will be in Garage, fixing Custom Offroad Bumper and Transfer case guard.
Looking forward to see her in New Avatar. Pics will follow soon.
Krishna Thanthri
Old 8th July 2010, 09:56   #282
Thanked: 41 Times
Default Small Update
Hi All,
Today i will get delivery of my Gypsy.
And ya i have bought snorkel too. Just got the order confirmation.
[COLOR=black]Special thanks to ARKA and My brother-in-Law Amit who ordered the snorkel online and will be getting it from UK very soon.
[/COLOR]
Krishna Thanthri
Old 12th July 2010, 14:24   #283
Thanked: 41 Times
Indicator and other lights are yet to be fitted.
Krishna Thanthri
Old 12th July 2010, 17:55   #284
karizma9292's Avatar
Thanked: 209 Times
Krishna now your gypsy looks menacing after the bumper transformation . How much did you say you paid for those HELLAS?
karizma9292 is offline   Reply With Quote
Old 12th July 2010, 18:14   #285
Thanked: 63 Times
nice bumper dsign
xtreme power is offline   Reply With Quote
2lac+ kilometers m800 engine rebuild project. SirAlec Modifications & Accessories 75 24th June 2013 17:36
My Gypsy rebuild - Stage 2 Anil Vincent 4x4 Vehicles 122 21st April 2011 11:43
My Gypsy Rebuild - Bushranger Ashish B 4x4 Vehicles 69 20th October 2010 08:31
