Old 26th July 2009, 15:34   #136
Gerardfdz's Avatar
Thanked: 60 Times
In this condition (ie all stripped down) is the best time to solve your water under the dash problems - if you have -that is!
Rgds!
Gerardfdz is offline   Reply With Quote
Old 26th July 2009, 15:38   #137
Gerardfdz's Avatar
Thanked: 60 Times
Originally Posted by Parm View Post
i 2nd that opinion!
235s will be too wide for OTRs! stick to 215s.
As said - 235 are too wide!
to me the best are 205! Less strain on the steering/ rack& pinion, tie rod knuckles etc!
Height marginally reduces, hence better stability/body roll.
Rgds
Old 27th July 2009, 01:05   #138
Amar82's Avatar
Originally Posted by headers View Post
Go for 215/75 R15 for offroad as they are stock and the best for articulation - unless you wanna mod your suspension setup!
i 2nd that opinion!
What are the best tyres for offroad on stock gypsy?? Does everyone vote for Geolanders??
Originally Posted by Gerardfdz View Post
Rgds!
What is this issue??? Can anybody elaborate on this??
Amar
Amar82 is offline   Reply With Quote
Old 27th July 2009, 09:13   #139
headers's Avatar
Thanked: 459 Times
Amar82:
1. I have used Pirelli Scorpion AT 215/75 R15 and they are good
2. I have used Michelin LTX-AT 235/75 R15 and they are OK.
Have not experienced Geolanders but the take is that BF-Goodrich is great !
3. The second issue is that while your gypsy is stripped down, you can seal the firewall for any water leakages etc!
Old 27th July 2009, 10:43   #140
Amar82's Avatar
Amar82:
Now i am being completely naive, What is firewall??. Is it the metal wall that separates engine and the cabin?
Amar
Old 27th July 2009, 11:11   #141
renegade's Avatar
Thanked: 36 Times
hi amar,gypsy is looking stunning,great work mate.
mandeep
renegade is offline   Reply With Quote
Old 27th July 2009, 13:31   #142
Thanked: 21 Times
Amar
Basically yes its the area between engine bay and cabin (behind dash). Protects you from the heat (and fires) in the engine area. Remember to get some insulating heatlon type material installed as well to cut down on noise and heat getting into the cabin area.
bigman is offline   Reply With Quote
Old 28th July 2009, 10:30   #143
Amar82's Avatar
mandeep
Thanks mandeep.
Today I had a conversation with the mechanic and i told him this issue(water coming under dash) with the Gypsy's. He said he will fix all the vents before putting the engine. However, Gypsy engine is very quiet so there is no sound issue's but i will ask if we can put some insulation material for AC to be more effective.
Should the insulation material be on the cabin side or the engine side??
Amar
Old 4th August 2009, 11:07   #144
Amar82's Avatar
Today i went for some shopping for my Gypsy , the list of items bought are specifically for leh trip:
1) Tire Repair Kit.
2) Radiator sealant
3) 44 piece tool kit(Emergency repair kit).
4) Cables to tie lugguage.
Here are some pics
Old 4th August 2009, 12:40   #145
Thanked: 21 Times
Don't forget a good quality tow rope as well, always been dubious about the ones sold in our local town in India. Might be the case you can buy better quality rated tow rope in bigger cities like LDH.
Old 4th August 2009, 12:44   #146
Amar82's Avatar
Totally forgot about tow rope Satnam, will check out some stores tomorrow. I was looking for some tape to cover hose pipe leaks, couldn't find one.
Old 5th August 2009, 00:58   #147
Thanked: 595 Times
get a hunting knife too or you can just buy a hockey from LDH to keep in the gypsy, just in case!
sleeping bags?
Parm is offline   Reply With Quote
Old 5th August 2009, 02:10   #148
Thanked: 21 Times
Try a local motor spares shop or ebay. Duck Pipe & Hose Repair Tape is a common one found in shops in the UK. It may be distributed in North America as well.
If you can't find it then there are alternatives on ebay :
vehicle hose repair tape:eBay Motors (item 200369501196 end time Sep-01-09 11:33:31 PDT)
A Maharadja hockey stick with carbon fibre shaft makes a decent security device as do those metal baseball bat type steering wheel locks (although the locks themselves are pretty poor).
Old 5th August 2009, 11:15   #149
Thanked: 226 Times
Amar,
How much is the Airman tyre inflator? Is it available easily in the country? What make?
dwaraka is offline   Reply With Quote
Old 5th August 2009, 11:21   #150
Thanked: 226 Times
Amar,
Do not go for 275. Max is adviced for 235 on alloys. Beyond that you will find the steering very hard and tyre will be touching the springs and body. Turning radius reduces drastically. Especially for ladakh, you need less than 235 size where curves are very sharp and narrow.
Edmund : My car's Rebuild Maruti 800 Edmund Technical Stuff 505 16th January 2014 13:18
My 'CLASSIC' Rebuild!!! SYJ 4x4 Vehicles 52 28th December 2010 23:05
Gyspy Engine Overhaul / Rebuild jealousdiamond 4x4 Vehicles 13 2nd February 2010 12:23
Xtreme Power's Spoa'd Custom Crawler(Gyspy No.2) xtreme power 4x4 Vehicles 22 4th January 2010 23:17
Turbo Rebuild help ananthkamath Technical Stuff 11 2nd October 2005 10:58
