Old 28th June 2009, 10:56   #121
Amar82's Avatar
Originally Posted by rhandle View Post
I guess gods here would even make a M800 best off-roader, plonk 4wd set, diff locks, 35" wheels, toyota engine and voila! So why not Bolero!
I really liked this ...wanted to attach a pic that i found on net
Amar82 is offline   Reply With Quote
Old 29th June 2009, 14:17   #122
BolBolero's Avatar
Thanked: 262 Times
Question
Originally Posted by ex670c View Post
Well the Bolero uses the DANA 44.
with a 28" Tyre (6.00x16) = 8.00" i.e 203mm
with 31" Tyres (7.50X16) = 8.00 + (3"/2) = 9.5" = 241mm
with 33" Tyres (33-12.50-15) = 8.00 + (5"/2) = 10.5" = 266mm
Arka
Hi Arka,
A few clarifications needed on the above post.
1. Will changing tyres to the above sizes, have any bearing on the handling of the vehicle?
2. What about the speedo/ odometer readings, will they remain accurate?
3. I am presuming the rims remain the same?
4. Will they fit in the existing wheel well or will some modification have to be done?
5. Will the turning radius remain the same - lock to lock?
6. Will it be SAFE?
Gautam.
BolBolero is offline   Reply With Quote
Old 30th June 2009, 13:35   #123
ex670c's Avatar
Thanked: 1,799 Times
Default Tyres
6. Will it be SAFE?
Hi Gautam,
1) The Handling will get affected, while the contact patch increase; road grip, the additional height (taller) tyre will reduce Wheel Down force (Behram Dabhar). This can be compensated by lowering the Diff-Ratio.
3.73:1 to 4.27:1 or 4.88:1 to 5.38:1
2) There will be an error is the diff-ratio is not lowered.
New Tyre Dia. / Old Tyre Dia. = error X current speed = Actual speed
3) You can use the Same Steel Rims up to 10.50" width.
4) I do not recommend wheel Spacer.
5) For 57" Track Solid Axle the Turning Radius will reduce on account on Tyre Section width coupled with Tyre Diameter. Will reduce mariginally, the stoppers behind the steering knuckle have to be adjusted.
6) Depends on what tyre you use and how you drive
Arka
Old 30th June 2009, 13:53   #124
BolBolero's Avatar
Thanked: 262 Times
@ Arka,
thanks for the detailed info.
Gautam.
Old 14th August 2009, 02:17   #125
The Wolf's Avatar
Thanked: 58 Times
Arka, which engine you reckon would be the best transplant for the underpowered existing mill on a 4x4 Bolero??? The idea is to get a powerful engine which is fairly straight fit (including the gbox) and isnt ripping once pockets off. Scorpio engine- hard to find and expensive, what other alternatives can be considered keeping in mind the final objective of
OFF-ROADING!!!!!!!!!!!!! Would there be any option under 50K, all expense covered??
Now, if the engine department is taken care of, all that stays pending is tyre set up, which isnt too difficult I believe.
p.s:Pardon my ignorance, you keep mentioning about changing the diff ratio, well how exactly is this done? By changing the drive gear itself? If yes, are custom ratios easily available?
The Wolf is offline   Reply With Quote
Old 20th August 2009, 00:39   #126
The Wolf's Avatar
Thanked: 58 Times
Default Knocked me out...
Bit offcontext but just thought i'd share this amazing prado video...the damn thing knocked me out cold!!!
Im sure the driver knows what he is doing really well here!!! I almost thought for a sec that the cars gonna go dead cockroach. Cant believe such a civil car achieving managing such feat, with relative easy if I may...
Old 20th August 2009, 13:04   #127
Thanked: 91,878 Times
Wait for Mahindra to release a 4x4 variant of the 2.5 common-rail. That's your best bet. Factory install = Only way to go. Especially since the common-rails come with their own nuances (weight, size, gearbox mating ability etc.). Pretty much the only reasons I opted for a Bolero 2.5 IDI in my Classic, and not the Scorpio engine.
Old 21st August 2009, 01:52   #128
The Wolf's Avatar
Thanked: 58 Times
Looks like I forgot to paste the link...here it is...
What’s the best Off-roader under 10L? EDIT : Bought a Gurkha! hisunil 4x4 Vehicles 133 24th September 2011 09:57
Help regarding a vehicle for Mobile Soil Testing Lab jeepster Commercial Vehicles 36 25th December 2010 23:22
Spied – 2010 Mercedes Benz C250 CGI on Indian soil. EDIT : Maybe not after all Sudan_NFS The Indian Car Scene 10 14th May 2010 20:47
Ideal Indian Off-Roader ex670c 4x4 Vehicles 38 4th April 2010 11:57
Off-roader/on-roader dwaraka Introduce yourself 9 14th November 2006 23:48
