Old 1st July 2009, 19:10   #46
Ricky_3007's Avatar
Thanked: 21 Times
Hey kaushik,
I am sorry for hijacking your thread for th info. on my jeep.
Tarkesh
Ricky_3007 is offline   Reply With Quote
Old 2nd July 2009, 12:03   #47
KSM-Vtec's Avatar
Thanked: 440 Times
Originally Posted by Ricky_3007 View Post
Hi Kaushik,
Nice to see your thread. Great going man and lucky one as well that you are able to drive your Gypsy. I am very happy for you. All the best and start restoring it ASAP. We really want to see it in new "Avtaar".
Have fixed up the issue of registration? What have u done? Pls do let me know.
Tarkesh
Hey Sandy,
Can you pls let me know about the history of my jeep below were the markings on my jeep. I mean which dept used it and what does this markings/numbers mean?
I only know that the Jeep is from North Vehicle depot and used by Army in Jammu headquarter.
Basically there is 1 Gun like marking and there is no painted as"265" on rear ring.
Pls see the pics as well.
Tarkesh
Well the registration work is still going on. Will surly let you know once its done.
No problem the information you have asked for will help all of us!!
KSM-Vtec is offline   Reply With Quote
Old 2nd July 2009, 19:12   #48
Bazius's Avatar
Originally Posted by KSM-Vtec View Post
This is what i am talking about -
Attachment 150866
Thats for the A/C thats what an army driver told me.
Bazius is offline   Reply With Quote
Old 3rd July 2009, 10:10   #49
Gypsy-Boy's Avatar
One of my friends has the same switch installed to prevent theft of the vehicle
looks the same - its an engine kill switch
The army driver may be pulling a fast one on you.
GB
Gypsy-Boy is offline   Reply With Quote
Old 3rd July 2009, 10:14   #50
KSM-Vtec's Avatar
Thanked: 440 Times
That switch controls all the electricals not the engine or a/c in specific. It has more then 8 positions for various combinations.
GB
Old 3rd July 2009, 12:21   #51
pranavt's Avatar
Thanked: 274 Times
Congrats on buying a Gypsy Kaushik. Hope to see it at a meet-up soon!
Old 3rd July 2009, 13:04   #52
Blue Thunder's Avatar
Thanked: 335 Times
Post
...Water Leakages
(This is giving me a nightmare, lot of water dripping under the dashboard and from the rear door)....
Welcome to one of the best-kept secrets about the Gypsy !!!
The usual workaround : add extra rubber beading in the door. Usually, it leaks from under the dash, if the A/c equipment has been mounted, and the A/c guys didnt seal the holes for the coolant liquid pipes properly.
...Air conditioner Installation
(Sanden 507 Compressor & Superking Blower)...
Check if you can get a single roof mounted unit : i think it should be more effective/space-saving than the blower under the dash.
...•A/T Tyres
(Yokohama Geolander A/T 235/75/15)
•Alloy Wheels
(Not immediately, will the above tyres fit & run on the stock rims without any issues??)
Tyres : my vote would go for the Geolandars
Rim : you can mount 235/75/15 on stock Gypsy rims : headers has done that. But please check with him regarding the effect on steering lock-to-lock.
Blue Thunder is offline   Reply With Quote
Old 3rd July 2009, 17:19   #53
KSM-Vtec's Avatar
Thanked: 440 Times
Thanx a lot Bro!!! will get the gypsy for sure..
Well i am trying my best, hope i can workaround the problem completely.
BTW is there any sort of beading under/around the bonnet??
Old 4th July 2009, 11:44   #54
swastikviji's Avatar
Thanked: 158 Times
Hi Kaushik here is the pictures of Brake booster installed in my Gypsy.
My Army Spec "Demon Gypsy": Project Complete-001.jpg
My Army Spec "Demon Gypsy": Project Complete-002.jpg
My Army Spec "Demon Gypsy": Project Complete-004.jpg
My Army Spec "Demon Gypsy": Project Complete-006.jpg
swastikviji is offline   Reply With Quote
Old 4th July 2009, 11:58   #55
Sha
Sha's Avatar
Vijay where is carb? . Engine bay looks very neat still I have n't serviced my Gypsy.
Sha is offline   Reply With Quote
Old 4th July 2009, 19:43   #56
KSM-Vtec's Avatar
Thanked: 440 Times
Thanx a lot for the pics Vijay!!!
Am really stuck up with the water leakage issue, juts don't know what to do about it.
Old 5th July 2009, 12:01   #57
Thanked: 158 Times
Hi Shakir they still not received spares for carb,
Old 5th July 2009, 12:27   #58
Sha
Sha's Avatar
have you orded full set or only spares. it will take 10 days vijay to get spares.
Old 5th July 2009, 12:35   #59
Thanked: 158 Times
Ordered only Spares, MUL has only that Aisin carb its not good as we experienced , if spares wont solve that riching problem i will go for weber or mikuni new carb.
Old 5th July 2009, 23:11   #60
suzuki san's Avatar
Thanked: 345 Times
Hi KSM - Vtec,
I know exactly how you feel.
I have had two Gypsy's myself and both of them leaked - especially under the dashboard and usually directly onto my foot which was on the accelerator. As someone else on the forum said - one of the Gypsy's best kept secrets!!!!
I tried everything possible and finally the one thing which helped was to block off the vents which are under the front windscreen (just behind the bonnet). That helped quite a bit. If you choose not to do this then make sure the drains from this section which come out inside the engine bay (on the firewall) are not choked. Leaves etc. go into the grille/vent under the windscreen and block the drains thus causing the water to leak into the cabin.
Don't bother with extra beading around the doors or silicon around the front windscreen. It won't help. Been there, done that!!!!
Hope the above helps.
SS
suzuki san is offline   Reply With Quote
It's a 'Jeep' Thing!" - Army Spec MM550 - Restoration in Bangalore - PHASE 1 COMPLETE hgnishanth 4x4 Vehicles 252 2nd January 2018 11:52
wanted to get some info about an army spec Mahindra mm550 sabret00the SUVs, MUVs & 4x4s 70 4th February 2016 22:47
My MM550 Army Spec Restoration Project papaboost 4x4 Vehicles 31 18th September 2013 22:01
Project MM550 Xd Army Spec jeepsan 4x4 Vehicles 38 22nd March 2013 16:09
