Old 15th July 2009, 21:43   #76
KSM-Vtec's Avatar
Thanked: 440 Times
Originally Posted by Jaggu View Post
Hope you are fan is blowing the air towards the engine and not pulling it? Try doing a radiator clean up job, otherwise install a bigger core radiator and things should be fine for normal drives. Offroading situations best to switch off the AC to avoid any hazzles.
Have the radiator work lined up for next week. Ya the fan pulls the air from outside onto the condenser & radiator.
KSM-Vtec is offline   Reply With Quote
Old 15th July 2009, 22:04   #77
Amar82's Avatar
Default Gypsy underbody condenser install
Originally Posted by rmonie View Post
Its probably easier & cheaper to put the condenser under the vehicle & will protect the condenser as well. Do you need a picture?
Rmonie,
I am thinking of putting the condenser underbody in my Gypsy. Can you post some pictures of the full install?
Amar
Amar82 is offline   Reply With Quote
Old 17th July 2009, 16:43   #78
KSM-Vtec's Avatar
Thanked: 440 Times
well the AC issue is not resolved as yet but in the meanwhile i am planning to go ahead with the tyre selection and break booster installation.
YOKO GEO 235 vs 215
My Army Spec "Demon Gypsy": Project Complete-02072009654.jpg
My current stock setup
My Army Spec "Demon Gypsy": Project Complete-15062009564.jpg
once the above is done ill get back to the AC issue and may also change the radiator.
Old 17th July 2009, 17:40   #79
harjeev's Avatar
Thanked: 256 Times
Hey Kaushik!!!
How much is the conversion from power assisted break's to power booster brakes costing you???
And what all is being changed apart from the booster cylinder???
harjeev is offline   Reply With Quote
Old 17th July 2009, 18:26   #80
abheekg's Avatar
Thanked: 173 Times
Default re : gypsy tyres
The 235's look huge. You sure you wont have any problem in turning the vehicle or clearance issues or issues with articulation of the wheels ?
How many working examples do we have here of people installing 235 size tyres and having no issues.
regards,
Abheek
YOKO GEO 235 vs 215
Attachment 160129
abheekg is offline   Reply With Quote
Old 17th July 2009, 18:36   #81
KSM-Vtec's Avatar
Thanked: 440 Times
regards,
Abheek
that is the question even i would like to ask. i am told that the 215 dosent create any problem, any 235 users here???
Old 17th July 2009, 20:58   #82
harjeev's Avatar
Thanked: 256 Times
Hi I dont know about 235's but I had 275's in my Gypsy long back and used to have hell lot of a problem with them!!!
I too like the 235's better
Old 17th July 2009, 23:39   #83
discoverwild's Avatar
Thanked: 1,169 Times
I have had only 215s and 205s on mine. First change was the 215s and when I changed that to 205s, it was almost like I had power steering.
I recently saw a Gypsy (1.0 Litre) with 235s, but the rims were narrow creating a balloon effect on the tires.
discoverwild is offline   Reply With Quote
Old 18th July 2009, 00:29   #84
KSM-Vtec's Avatar
Thanked: 440 Times
275 is way too big ...i am told that the 235's also touch somewhere. i too just luv the 235's
Old 18th July 2009, 03:18   #85
MexXxentric's Avatar
Thanked: 11 Times
got 235s in mine.
No need not work out your arms at Gym.
Go for 235 if you plan to have Power steering.
Iam going to get it installed.( the koyo make PS kit costs 8k)
the stock Gypsy steering box will wear out quickly with 235s
Go for 215s if you are happy with its look.a
MexXxentric is offline   Reply With Quote
Old 18th July 2009, 06:16   #86
harjeev's Avatar
Thanked: 256 Times
@Kaushik!!!
Checkout these pics (Composite Fibre Leaf Springs: Can they be used for off-roading?)of Khan's Gypsy!!!
The tyres he has on his Gypsy are definitely 235's or bigger and he has done SpOA and Composite Leaf's. You don' t have to go for Composite Leaf's at the moment, but doing SpOA shouldn't cost that much!!!
Old 18th July 2009, 10:09   #87
Gypsy-Boy's Avatar
Hey kaushik
I am running 235's on my King and there is absolutely no probs - On road and off road
GB
Gypsy-Boy is offline   Reply With Quote
Old 18th July 2009, 10:31   #88
Thanked: 226 Times
Kaushik,
I have the same model of Superking AC kit in my gypsy. Very effective one. Set up is almost the same. Where has it been fitted inside the gypsy
Mine is placed upwards inside the dashboard and the Vents connected to existing Blower holes on the face of dashboard. Virtually making the equipment invisible.
dwaraka is offline   Reply With Quote
Old 18th July 2009, 10:47   #89
Thanked: 226 Times
Kaushik,
I have fitted 235 Yokohoma Geolander AT/S on my gypsy with full metal body. I find it quite normal on road or off road. Infact road grip on highway has increased from 215 bridgestone.
Stalling, you will find it really hard to turn the wheels
Old 20th July 2009, 14:30   #90
KSM-Vtec's Avatar
Thanked: 440 Times
Tried the 235's and 215's last evening -
YOKO GEO 235's - the rear side of the front tyre touches the leaf spring on turning
Goodyear 215's - perfect, YOKO GEO 215's but not in stock
(there is this guy who has them but they are 10-12 months old, what should i do??)
Also it would be great if i could get a rough estimate on the pricing of the YOKO GEO A/TS both 215 & 235.
Originally Posted by dwaraka View Post
Kaushik,
Originally Posted by Gypsy-Boy View Post
Hey kaushik
GB
@Kaushik!!!
Originally Posted by MexXxentric View Post
got 235s in mine.
It's a 'Jeep' Thing!" - Army Spec MM550 - Restoration in Bangalore - PHASE 1 COMPLETE hgnishanth 4x4 Vehicles 252 2nd January 2018 11:52
wanted to get some info about an army spec Mahindra mm550 sabret00the SUVs, MUVs & 4x4s 70 4th February 2016 22:47
My MM550 Army Spec Restoration Project papaboost 4x4 Vehicles 31 18th September 2013 22:01
Project MM550 Xd Army Spec jeepsan 4x4 Vehicles 38 22nd March 2013 16:09
