Old 19th January 2010, 11:16   #46
ex670c's Avatar
Thanked: 1,821 Times
Default Thank You
Thank You guys, for your comments.
wrt. 7.00X16 = Only the commercial 14 ply tyres are available.
Old 19th January 2010, 19:23   #47
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
huh,speechless i am, what an awesome looking jeep..
SPIKE ARRESTOR is offline   Reply With Quote
Old 12th May 2010, 14:23   #48
ex670c's Avatar
Default Updates
Hi Guys,
Got the following work done on the CJ3B.
1) Serviced all 4 Brakes
2) Serviced and Grease Packed the Hubs.
3) Serviced and Steering System
4) Fitted all missing Grease Nipples
5) Cleaned all the Breathers (Front Diff/Rear Diff/G-Box/T-Case)
6) Changed one UJ on the Rear Prop Shaft.
7) Skid-Plate from ex-army CJ3B
8) Spike-Arrestor (Tension & Compression)
Arka
Old 3rd August 2010, 20:48   #49
Thanked: 226 Times
Originally Posted by JeepMkd View Post
It's always great to hear (read) such a story. I'm following
And gives pickup and drop for kids in the block Also, brings grin on onlookers.
dwaraka is offline   Reply With Quote
Old 14th March 2011, 13:11   #50
ex670c's Avatar
Default Re: Silent, But Violent
Hi Guys,
The following work has been done on my CJ3B.
1) New Top - SRF Tuf-Top Synthetic Material
2) Engine Tuning (Carburetor/Tappets/Timing @ Electra Performance)
3) New Fuel Pump
4) New 4-Core Radiator
5) Paint Touch Up
6) Upholstered the Seats
Arka
PS - Pics will follow shortly
Old 14th March 2011, 13:44   #51
headers's Avatar
Thanked: 464 Times
Originally Posted by ex670c View Post
Hi Guys,
3) New Fuel Pump
5) Paint Touch Up
Arka
Hey Arka,
Why does your old jeep go to Electra for tuning? You want to go FAAASTT ?
Old 14th March 2011, 14:11   #52
genesis's Avatar
Thanked: 309 Times
Hi Guys,
3) New Fuel Pump
5) Paint Touch Up
Arka
@Arka:Which fuel pump did you put in and how much did the part cost?
genesis is offline   Reply With Quote
Old 14th March 2011, 14:12   #53
petrol_head's Avatar
Thanked: 51 Times
Originally Posted by headers View Post
Hey Arka,
lol... Arka too is now on the 'I wanna go FASTTT' bandwagon but man that thing was fast a couple of weeks back - chennai-mahabs-chennai. The downside - 5 kmpl (ok ill shut up before arka jumps at me now)
It pulls like a locomotive from stand still (had a few sedans running for cover)
petrol_head is offline   Reply With Quote
Old 14th March 2011, 15:07   #54
ex670c's Avatar
Hi Soumya,
Fuel Pump PTN Rs750.
@Vijay 19L = 90Kms
Pulls like a "Locomotive and Sedan's run for cover, sounds like it was misfiring
Arka
Old 14th March 2011, 15:37   #55
Jaggu's Avatar
Thanked: 8,685 Times
19L = 90Kms
Arkasan i want to drive the beast, when i next see it! And can you please share your insights to DwArF's locomotive vibration in the thread below Propeller angle any inputs?
Old 14th March 2011, 16:15   #56
ex670c's Avatar
Hi Jaggu,
You can drive it anytime you are in Chennai.
If the Vibrations is at idling check the following.
i) Engine Idling Speed (600-700Rpm)
ii) Engine Bed/T-Case Bed especially the circular bed which has bolt running through it.
if it is too tight the engine will vibrate on idling
if it is too loose the engine will shudder when switched off.
Also check the Spike Arrestor.
While running the vibrations can be caused by
i) Front Prop-Shaft -- No FWH
ii) Misaligned cross-member (Check if you have the MM540 Type Spacer)
iii) Misaligned Prop-Shaft (UJ not in Phase)
iv) Play in the Differential Pinion
v) Play in the Splined Yoke
vi) Loose Leaf Spring Bolts
Arka
Old 14th March 2011, 16:40   #57
Jaggu's Avatar
Thanks Arka, my replies in DwArF thread, so that info is one place. And yes i will drive your violent one when i visit next.
Old 14th March 2011, 23:28   #58
Frankenstein's Avatar
Thanked: 300 Times
Got a chance to drive Arka s violence, this JEEP is really powerful. All the while i felt it was in low range. I felt the torque to be 30%more than the stock hurricanes.
PS, Some how i felt the engine does not rev much, i mean compared to the other hurricanes and even mine .
Arka, throw that FFE and get the original muffler .
Frankenstein is offline   Reply With Quote
Old 15th March 2011, 10:40   #59
ex670c's Avatar
Hi Franky,
The Current Tuning is very aggressive for speeds up to 40-50Kmph, hence the low FE.
Previously it was tuned for 50-60Kmph, @ 9Kmpl
The revs may not be evident for few reasons, Valve Clearance/Timing and 28" 6.00X16 Tyres .
If I remove the FFE, I will have to go back to the SOLEX M34PBIC .
Arka
PS - Please get me an original muffler which I can replicate
Old 17th March 2011, 12:53   #60
Thanked: 300 Times
Arka how does tappet clearance matter here?
I felt your timing is slightly advanced , right?
You can give me the webber and always go back to the solex or carter YF.
I am removing my original jeep muffler , it is not in its prime anymore, ill give it to you as a sample.
Scorpio petrol muffler will make a hell lot of difference in the NVH of the hurricane.
Resale Value - The Silent Killer ajmat The Indian Car Scene 81 6th March 2018 10:02
Scary experience with rowdy & violent bikers. A-Star damaged ciddharth Street Experiences 44 21st December 2012 15:44
"violent" VW Ads ajmat The International Automotive Scene 7 17th May 2006 14:54
The most silent diesel sedan (under 12 lac category) DCEite The Indian Car Scene 33 21st May 2005 07:45
