Closed Thread
Old 2nd July 2009, 11:57   #16
trammway's Avatar
Thanked: 210 Times
Not bad, I know where to source this oil filter from. Thanks for the info.
trammway is offline
Old 9th July 2009, 07:51   #17
trammway's Avatar
Thanked: 210 Times
To cut the long story short here is the update on my CJ3B restoration work.
Jobs that are completed:
Complete break overhauling done
Clutch plates have been replaced
New battery has been put on place
Getting the oil filter replaced with original style Fiat old type oil filter
Engine water jacket aluminum manifold has been replaced (Technically called Elbow)
The gearbox has been overhauled, replaced 2nd gear and synchronizer rings with bearings
Load gearbox levers have been put on place
Brand new front propeller shaft has been installed (MSL make)
Still the front axles are missing and trying to get hold of brand new MSL 22/34.5 axle with 10/19spline
The Petrol CJ3B on my stable has been named as "Navigator"
Accessories for external looks have been collected and the list of collected items were:
1. Gun carrier
2. Front Grill black out lights
3. Pick axe
4. Body side handles
5. Jerry can
6. Jerry can stand, goes on the rear tail gate and the stepney will be moved to left side of the jeep
7. Small amo box to be fixed on the right side above rear wheel as first aid box
8. Large sized amo box to be fitted in the rear side of both the front seats as tool box
9. Head light protection grill
10. two shackle rings for the front bumper
11. Old type rear tail lights
12. Insect protection mesh for the front grill
13. Rubber pads for the clutch and break pedals
Parts that are getting sourced
1. Tail gate with Jeep written on it
2. Windshield with push open type glass frame
3. Dash board small indicator lights and aluminum plates
4. Gear lever knobs original type
5. Side view mirrors that goes on the body front side with a rod
6. A spiral pipe manual air horn
7. Emergency break assy with drum, carrier plate, break handle and cable etc.
8. Original military type Scissor top fittings
9. Right hand mudguard blackout light
10. 7.00x16 NDMS tyres (5 nos)
11. Tow hook for trailer old type
12. Small shawl
13. Rear Bumper protectors
Pending tasks
1. Tinkering
2. Painting
3. Canvas top
4. Electrical adjustments
5. Carburetor overhaul with new packing kit
trammway is offline
Old 9th July 2009, 10:23   #18
Amar82's Avatar
Trammway,
Is there a place where you can buy all these old jeep accessories? If they were collected separately , its a lot of effort.
Amar
Amar82 is offline
Old 9th July 2009, 10:31   #19
trammway's Avatar
Thanked: 210 Times
Actually, most of them are available in Chennai expect the original ones which I need for restoring the body/cosmetic items.
So, the cosmetic front and some utility items such as tail gate, windscreen etc. are sourced by Mr.UBS. Without his guidance and encouragement I don't see any Jeep in my house.
I'm getting from Mr.UBS and few from Ooty and some from local Army scrap vendor. There couple of mechanic items that I sourced from local Mahindra Parts Dealer. Yet my required parts not completed and still search is on the swing.
trammway is offline
Old 9th July 2009, 10:44   #20
desertfox's Avatar
Thanked: 527 Times
Your entire wish list of parts is available in Mayapuri market in Delhi.
desertfox is offline
Old 29th July 2009, 23:25   #21
trammway's Avatar
Thanked: 210 Times
Yes, But I'm from Chennai and sourcing each and every part from Mayapuri is practically impossible. However with some TBHPians help, I could source many items for both of my Explorer and Navigator jeeps.
Now the updates:
1. Tail gate with Jeep written on it - Mr.UBS helping me getting it.
2. Windshield with push open type glass frame - Already sourced brand new.
3. Dash board small indicator lights and aluminum plates - Got it
4. Gear lever knobs original type - Got it
5. Side view mirrors that goes on the body front side with a rod - Naren from Rajastan is helping me sourcing it
6. A spiral pipe manual air horn - Got it
7. Emergency break assy with drum, carrier plate, break handle and cable etc. - getting it from my home town, should be with me in a weeks time
8. Original military type Scissor top fittings - Mr.UBS helping me getting it
9. Right hand mudguard blackout light - Naren from Rajastan is helping me sourcing it
10. 7.00x16 NDMS tyres (5 nos) - Not reached upto this level
11. Tow hook for trailer old type - Got it
12. Small shawl - Got it
13. Rear Bumper protectors - Not available at this point
Now the Jeeps engine bay mechanical works have been completed. The minor things that were changed are 1. Water Jacket replacement, 2. Original type oil filter has been installed, 3. Brand new water hoses have been put into place.
Tomorrow my Navigator will have a good radiator that I have removed from my Explorer today. I have already scrapped the current petrol jeep's radiator as I purchased a new four core radiator for my Explorer. I hope the petrol engine will have good cooling with three core radiator itself.
All the missing four wheel drive components such as front axles, crown pinion and drive shaft have been installed.
Additionally our Swastikvijay helped me getting a free wheeling hubs from Bangalore and they are alreayd on the transit with the help of MM440(Jammy Anand).
Issue:
When I about to drive the Jeep back to home after the mechanical preparation I found an issue with the front differential and the jeep could not good smooth. My mechanic suspects mis-matched front and rear differntial ratio.
Tomorrow we will work it out to make the jeep run smoothly with four wheel drive.
One more thing I wanted to know is about a pipe that is popping out from the delco assy and one more pipe kind of outlet which is next to the oil filter (I mean the small pipe that is coming out from the dip stick tower)
trammway is offline
Old 29th July 2009, 23:34   #22
V-16's Avatar
Thanked: 848 Times
Congrats trammway on the new member to the 4X4 family. Have fun with it.
I need front and rear black out lights for my CJ-3B. Can someone help me source it form Mayapuri?
V-16 is offline
Old 31st July 2009, 00:45   #23
trammway's Avatar
Thanked: 210 Times
can some one tell me what is this part in a military jeep?
trammway is offline
Old 7th August 2009, 22:09   #24
renegade's Avatar
Thanked: 36 Times
hi,i think the small pipe which is coming out of the distributor,it might be of a vacuum governour for automatic advance/retire firing which is connected to the carb,i am assuming this.nice jeep though.
cheers
mandeep
renegade is offline
Old 8th August 2009, 09:47   #25
DKG
DKG's Avatar
Thanked: 958 Times
You needn't assume, you are 100% correct. It is a vaccum advance mechanism and the pipe connects to (usually on most old cars) the base of the carb working off inlet manifold vaccum.
When the diaphragm in that circular device ruptures or the pipe is left disconnected initial acceleration is compromised. Usually the point system distributors used the vaccum advance upto a partcular rpm and then at higher rpm the centrifugal advance mechanism within the distributor ( usually a pair of metal lobes under the pointplates ) took over to advance the timing.
DKG is offline
Old 23rd August 2009, 01:33   #26
trammway's Avatar
Thanked: 210 Times
Thanks pals for clearing that doubts.
Since the recent OTR at Nagalapuram, My explorers engine work and other jeep related stuffs are taking huge toll on my time I have not really done anything up for the CJ3B expect collecting few more parts that may be required during the restoration. Here are they:
Some of the items I recently collected for CJ3B was actually sourced and given to me by Jeep Guru Mr.UBS, and my sincere thanks to him for helping me on this CJ3B project, The most notable thing here, he just didn't source them for me, also he carried these items along with him on the train from Calcutta to Chennai during his last visit here. Here are the stuffs came all the way from Calcutta:
trammway is offline
Old 23rd August 2009, 09:38   #27
renegade's Avatar
Thanked: 36 Times
that is awesome trammway,i really liked the tail gate.i remember i picked one up for myself few years back from punjab at dirt cheap price.good going,if you can pursue mr.ubs for koenig king R100J pto winch,nothing like it.
cheers
renegade
renegade is offline
Old 23rd August 2009, 10:37   #28
trammway's Avatar
Thanked: 210 Times
cheers
renegade
Hi Renegade,
The PTO winch is an optional accessories and I would like to keep as low as possible requests to Mr.UBS as I know his helps are required by many Jeepers alike me in this country.
Actually I was going through my PTO related searches and still thinking of ideas to use what I have with me.
In fact the PTO winches uses the same PTO drive unit that Mr. UBS sir given to me. I have just looked at several PTO attachments that works with this unit. This picture here is taken from internet and the copyrights of this image goes to its original owners.
trammway is offline
Old 23rd August 2009, 13:43   #29
beetle_boy's Avatar
Thanked: 58 Times
Default Congrats
Hi Sir,
First of all congrats on ur new buy and the name suits your jeeb.
Restoration work is very fast and the list shows there is a progress everyday. Please help me also in getting a jeep.
Thanks in Advance
beetle_boy is offline
Old 23rd August 2009, 21:53   #30
renegade's Avatar
Thanked: 36 Times
cool stuff trammway,i am sure your jeep would be a scorcher.
renegade
renegade is offline
Closed Thread
My Jeep Bride - Mahindra Willys Petrol CJ4A ( CJ3B sibling ) - Ground up restoration abheekg 4x4 Vehicles 68 9th September 2016 11:49
Queries about my two Mahindra 550s and a '71 Kaiser Willys melsingh 4x4 Technical 4 29th November 2010 23:20
1969 CJ3B but not quite the same anymore gsferrari 4x4 Vehicles 9 5th June 2010 17:22
Project "Gravel Pit", a Universal(kaiser) Cj3B Built Brutus 4x4 Vehicles 14 7th January 2010 12:54
whats better than an original cj3b?? two original cj3b's. 0333 4x4 Vehicles 33 5th March 2009 11:15
