Old 15th March 2011, 09:02   #16
Samurai's Avatar
Thanked: 15,950 Times
Default Re: Offroad Rims/Tyres Thread
Originally Posted by SPIKE ARRESTOR View Post
I asked this not because of Thar, there is a SWB Bolero with MDI engine available - Bolero LX BS-III, I hope you are aware.
What is this Bolero SWB model? I don't see it documented anywhere. What is the wheelbase of this SWB model, and it is available in 4WD?
Originally Posted by Sudarshan View Post
OK , but I have just commented ,then how can you agree before even I say something ?
He is referring to some Raju Bhai, not you.
Old 15th March 2011, 09:11   #17
SPIKE ARRESTOR's Avatar
Thanked: 862 Times
This is the precise reason for my post, I knew people may not be aware of this model. WB is same as Bolero SLX / Storm, (105.5 " IIRC), it is available in 4WD with DI engine without PS & AC (IIRC)
Raju bhai is none other than Sudarshan Vaidya Sir
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 15th March 2011, 09:30   #18
Thanked: 825 Times
Talking Re: Offroad Rims/Tyres Thread
Ahh , finally the discussion is at a right place , Thanks samurai .It must be a tiring work for you support team ( keeping all the action & show together & also under control )
Raju bhai is gentleman when he is Sudarshan Vaidya ( Is he ? )
Anyway , jokes apart
Spike bhai please explain this 5 mm front suspension travel , its very confusing .
Sudarshan
Sudarshan is offline   Reply With Quote
Old 15th March 2011, 18:06   #19
vak
Thanked: 43 Times
[quote=SPIKE ARRESTOR;2278508]This is the precise reason for my post, I knew people may not be aware of this model. WB is same as Bolero SLX / Storm, (105.5 " IIRC), it is available in 4WD with DI engine without PS & AC (IIRC)
Dear Spike,
I enquired at TVS, they said they dont have any information on Bolero LX 4wd with Di engine. They also said if you want 4x4 in Bolero with Di engine then the only option is Bolero DI 4wd.
PS: Shackle at the rear of a 4wd Bolero is shorter than that of a 2wd Bolero like SLX or SLE. The leaf spring design is also different, I believe it is to cope with the additional torque generated in 4wd low. I will give you the exact measurements and pictures of the shackle once I reach home, I am travelling right now.
vak is offline   Reply With Quote
Old 15th March 2011, 20:01   #20
Thanked: 862 Times
I am somewhat surprised to hear this, I saw a few of them last month also. Let me check again.
Spike
Old 16th March 2011, 13:56   #21
offroad_maniac's Avatar
Thanked: 41 Times
Default Re: Info on Bolero mods
HI Spike,
With LX 4WD Bolero, are you referring to 4WD Invaders?
Same wheelbase as Bolero SLX but with reduced rear overhang?
But the chassis is different?
BTW, Invaders/ Strikers has rear SPoA setups?
Also below site does not contain all the required info about mentioned model, so these models are specialyy made for Govt? Police etc??
offroad_maniac is offline   Reply With Quote
Old 16th March 2011, 20:35   #22
jeepster's Avatar
Thanked: 1,047 Times
i think he is referring to 4x4 invaders.
invader has smaller WB than bolero & also has longer overhang.
yes chassis different . (due to WB , overhang & shorter body)
no, invader/striker have SPuA setup. (spring under axle)
all mm pickups using SFRA axle have SPoA setup.
all mm pickups using FFRA axle have SPuA setup.
its a specially planned publicity scheme by mahindra to misguide buyers so they can invistagate & learn more about their products. (some times with a little help from consumer court.)
rgds,
Nikhil
jeepster is offline   Reply With Quote
Old 16th March 2011, 20:53   #23
Thanked: 862 Times
No, I am talking about a Bolero. WB is~ 93.5" IIRC
Invaders Yes! not sure of Strikers though.
Possible, but I am sure, coz I've seen them
No!
Invader has SPoA setup at rear.
Good one, let me propose this!
Spike
Old 16th March 2011, 22:28   #24
vak
Thanked: 43 Times
rgds,
Nikhil
Dear Jeepster,
I have seen many MM pickups with SFRA having SPuA setup. I shall try to get some pictues next time I go for service of my Bolero. SPoA comes in Flat bed MM pickups.
Vinshad Aziz
Old 20th March 2011, 21:09   #25
vak
Thanked: 43 Times
Default Pictures of Bolero 4wd Shackles
Dear All,
Please check the pictures of the front and rear shackles of my Bolero 4wd. The rear ones are shorter than those in a 2wd Bolero and the Leaf spring design is also different.
I also did a small articulation test to determine whether fitment of bigger tyre like 31-10.5-15 will require a negative offset wheels or may be wheel spacers. The result is yes, because there was only one inch clearance inside the wheel arch at the rear with the OE tyre. And under extreme articulation bigger tyre will definitely touch the inside of wheel arches.
Old 20th March 2011, 21:41   #26
jeepster's Avatar
thanks for the pictures.
IMO you can add shackles 1 inch longer than stock. (front & rear respectively)
because your bolero is new you just have to buy longer shackles & fit them. (no bushings & removing u clamps stuff)
simple one hour bolt-on job.
if you dont like the on/off road handling of your bolero you can reverse back to old/stock set up any time.
rgds,
Nikhil
EDIT: i will be doing shackle overhaul tomorrow will up date on my thread. (with longer shackles)
Old 1st April 2011, 11:53   #27
vak
Thanked: 43 Times
rgds,
Nikhil
Not all MM pickups using SFRA axle have SPoA setup. Here are the pictures of a MM pickup using SFRA but with SPuA, and it is 4x4.
Old 8th April 2011, 10:35   #28
vak
Thanked: 43 Times
Default Info on Bolero mods
I have fitted my Bolero with Geolander AT-S in 31-10.5-15 size. I have slightly re-cambered the front leaf springs and gained a lift of one inch.
Overall, the result after tyre change is a gain of good ground clearance, now the under the diff clearance stands at 225mm.
Old 8th April 2011, 12:34   #29
Thanked: 862 Times
How much change in Camber resulted in 1" lift? Is there any change in ride? Any change to shackle?
Spike
Old 8th April 2011, 13:25   #30
powertrain's Avatar
Thanked: 384 Times
Is it just my P.C or are the pics not uploaded ??????
powertrain is offline   Reply With Quote
Bolero XDP Engine Vs Bolero DI Turbo Red Liner What Car? 34 30th September 2015 21:37
My new Bolero Di 4x4 and its Mods vak 4x4 Vehicles 57 28th September 2014 20:24
info needed for baleno mods premdiv Technical Stuff 3 14th June 2006 18:46
