Old 22nd July 2009, 14:17   #1
vikrantj's Avatar
Thanked: 370 Times
Default Info on Bolero mods
After looking at the cool 4X4s in the forum, it got me wondering if a Bolero 4X4 SLX version can be SPOA'd or is there something stopping it. What else can be included in the modifications of Bolero?
Thanks and Rgds
Vikrant
vikrantj is offline   Reply With Quote
Old 22nd July 2009, 14:33   #2
ex670c's Avatar
Thanked: 1,838 Times
Default Bolero Mods
Hi Vikrant,
1) Locker at the Rear Diff & LSD (or Locker) in the Front Diff with Free-Wheeling Hubs (Mandatory)
2) Taller Tyres - Lower Diff-Ratio 31" & 4.27 & 33" & 4.88:1
3) SPOA with Traction Bar
This would be my order of preference.
Arka
PS - What engine does the Bolero have?
Old 22nd July 2009, 14:40   #3
vikrantj's Avatar
Thanked: 370 Times
4X4 SLX has a XD3PU engine . 68bhp@4000rpm. But if feel torque is lower 137nm@2000rpm. Will that be sufficient for a off-roading activity ?
Old 22nd July 2009, 15:11   #4
ex670c's Avatar
Default Torque
XD3P in MM550XD = 76bhp@4600rpm 15.5kgm@2000rpm
MDI3200TC in Bolero = 68Bhp@3200rpm 18Kgm@1400rpm
You can definitely use the XD3PU Bolero, but it is less torquey than the above engines.
Use the vehicle for a few months, then decide if you want to change to the Military MM550XD Delphi FIP .
Old 22nd July 2009, 15:53   #5
vikrantj's Avatar
Thanked: 370 Times
Arka,
One stupid question Diff lockers disable the diffrentials ability to detect resistance thus the wheels which have a good traction get hugh torque , but wouldn't such mechanism hamper vehicle's movement say turning on good traction surface or atleast make it harder. Are diff locks automatically/manually disengaged when on a good traction surface ?
Rgds
Vikrant
Old 22nd July 2009, 17:48   #6
ex670c's Avatar
Default Auto-Locker aka Dog-Clutch LSD
Arka,
Rgds
Vikrant
Hi Vikrant,
Selectable Lockers can be locked.unlocked on demand and when unlocked function like a regular diff.
The Auto-Locker (Lock Right Part No 2413) Are locked in a straight line and unlock while turning, you can hear the click and bang!!!
They increase the vehicle's turning radius and make the steering a bit stiff.
Selectable Lockers USD1000
Auto Locker USD350
Its the price which makes the Auto-locker a clear winner.
Also the Auto Lockers have lesser moving parts and are more robust in construction.
Arka
Old 22nd July 2009, 18:04   #7
yzfrj's Avatar
Thanked: 120 Times
Have a look at this post and do look around this thread.
http://www.team-bhp.com/forum/modifi...ml#post1347355 (Yet another modded Bolero!)
Bilstein is really good according to the thread.
Again I'm not sure if it will "ruin" the 4x4 charm.
I figure good damping is always good on or off the road.
I might be wrong.
There are some modded Bolero pics, I'm not sure if this is what you are looking for.
yzfrj is offline   Reply With Quote
Old 14th March 2011, 19:13   #8
vak
Thanked: 43 Times
Default Your opinion on 31-10.5-15 tyre for bolero
I bought a brand new Bolero DI 4wd, the OE tyre is Ceat Formula One of 215/75-15 size. I am planning to put 31-10.5-15 size tyre. My driving involves 80% on road and 20% offroad, so I have decided on Yokohama Geolander AT-S.
I have a few doubts
1. Will 31-10.5-15 tyre fit the Bolero without any modification? OE wheel rim is 6j. What about 245/75-15 size?
2. I am planing to fit longer shackles, will this affect on road handling.
Vinshad Aziz
vak is offline   Reply With Quote
Old 14th March 2011, 20:00   #9
SPIKE ARRESTOR's Avatar
Thanked: 862 Times
Default Re: Offroad Rims/Tyres Thread
Hi Vinshad,
1. For 31-10.5-15, 6J is not recommended, you will have to use wider rims which will cause fouling with wheel housing.
2. On road handling will deteriorate with longer shackles. Roll will increase.
Spike
OT- Any reason for selecting the LWB Bolero 4WD?
SPIKE ARRESTOR is offline   Reply With Quote
Old 14th March 2011, 20:29   #10
headers's Avatar
Thanked: 464 Times
Longer shackles will make the vehicle unsafe and difficult to drive on road unless suitably modified with other suspension mods.
Please do NOT do it. The Stock OEM bolero DI has a decent suspension setup that withstands a good amount of use and abuse
Old 14th March 2011, 20:40   #11
vak
Thanked: 43 Times
Hi Vinshad,
Spike
I thought a LWB Bolero is more practical than a dedicated offroader like Thar. I booked my vehicle in August, 2010 and it took more than 6 months for delivery. I had an option of switching my Bolero for Thar and the sales person was more than happy to give me Thar than Bolero. Because there were more than 7 booking for 4x4 LWB Bolero which was pending.
I thought of fitting longer shackles because at the front the upward suspension travel of the axle is virtually nil as the axle is hitting the bump stop even in an unloaded condition. I asked the technicians, they said it is normal in Bolero DI 4wd. I have checked an old Bolero DI 4x4 and is in same condition.
Please check the pictures of the left and right bump stop. Nobody is in the vehicle and is in an unloaded condition.
I have found two solutions for this. Please suggest which is better.
1. Fitting of longer shackles, which will lift the vehicle and there can be upward suspension travel.
2. Recambering of the front leaf springs.
Vinshad Aziz
Old 14th March 2011, 21:50   #12
Thanked: 862 Times
Originally Posted by vak View Post
I thought a LWB Bolero is more practical than a dedicated offroader like Thar. Because there were more than 7 booking for 4x4 LWB Bolero which was pending.
I asked this not because of Thar, there is a SWB Bolero with MDI engine available - Bolero LX BS-III, I hope you are aware.
Yes, I know this (please refer my signature below), there is a reason why it is provided.
IMHO, a decent 16" wheel will be more than sufficient for your use. Trust me! Get a decent set of tires and you are ready.
Will again change the ride characteristics, not recommended.
Spike
Old 15th March 2011, 00:37   #13
jeepster's Avatar
Thanked: 1,047 Times
hi Vinshad,
5 mm of suspension travel.
my 98~99 armada has more room for leaf-springs to travel.
Name:  DSC03644 Medium.JPG
Name:  DSC03646 Medium.JPG
please check if the leaf-springs are not faulty.
Spike
basically you are saying to be happy with stock 5 mm suspension travel.
note:
from last 3~4 years i have lost faith in new mahindra products.
post of Vinshad just confirmed it for me.
raju bhai i am with you.
jeepster is offline   Reply With Quote
Old 15th March 2011, 07:10   #14
Thanked: 825 Times
Exclamation Re: Offroad Rims/Tyres Thread
This is very confusing , the travel should have at least 1.5 inches of travel
BTW have you checked the bushings ? or shackle length ( If a correct length of shackle is fitted & not the wrong one ? )
Originally Posted by jeepster View Post
hi Vinshad,
Dadu you seem to have lost the RH bump stop .( rubber )
please check if the leaf-springs are not faulty.basically you are saying to be happy with stock 5 mm suspension travel.
Right , also Spikes reply is more confusing
note:
Cool down Dadu , you haven't experienced the late 80s ,this is far superior
OK , but I have just commented ,then how can you agree before even I say something ?
Ahh , now I Understand , you are referring to that Thar post
Sudarshan
Sudarshan is offline   Reply With Quote
Old 15th March 2011, 07:35   #15
jeepster's Avatar
here some pictures of Armada shackles. (1998~99)
when compared with 2008 bolero the rear shackles are smaller by 1 1/2 inch.
so with current stock shackles of bolero DI i will gain around 12/16 inch (approx 2 cm).
Bolero XDP Engine Vs Bolero DI Turbo Red Liner What Car? 34 30th September 2015 21:37
My new Bolero Di 4x4 and its Mods vak 4x4 Vehicles 57 28th September 2014 20:24
info needed for baleno mods premdiv Technical Stuff 3 14th June 2006 18:46
