Old 30th May 2010, 11:33   #106
Thanked: 652 Times
Default Power steering kit
Finally i have the power steering kit completed and ready to ship, since there are some risk involved with sending these items through regular cargo service waiting for a safe source of transportation.
Anil Vincent is offline   Reply With Quote
Old 1st June 2010, 15:30   #107
MexXxentric's Avatar
Thanked: 11 Times
Default congrats
Anil,
You have collected a neat set of parts.
You can get high pressure hydraulic hose available locally for plumbing the lines.
Better split the cargo and send part by part through ur friends.I send mine as 2 hand baggages
The mounting hole pattern on PS is mirror image of what we have on Gypsy.
Adapter plate will be the easy solution. There is a picture of adapter plate in my thread)
You might need a wedge type insert plate also to ensure alignment of the box spindle & column.
In my 416, we drilled required hole pattern on chassis, inserted sleeves & welded them on both ends to the chassis. Finally stud bolts were inserted & welded.
It was little bit hectic job.
The machine shop guy who did it claimed that he develop one more joint in his arm.
I didn't opt the adapter plate as my mech had reservations on this idea.
MexXxentric is offline   Reply With Quote
Old 1st June 2010, 17:42   #108
Thanked: 652 Times
Thanks Sreejith, definetly i will be bothering you while doing the installation.
We were searching for one particular design of alloy wheel, some what similar to what Khan Bhai has got on his Gypsy, finally found the same design and placed the order today. It is expected to arrive in another 45 days since the design & finish that we ordered has to produced. I am attaching the picture here, this is excatly what is ordered.
Last edited by Jaggu : 1st June 2010 at 22:40. Reason: Back to back posts, EDIT the original post instead. Thanks
Old 14th June 2010, 11:23   #109
Thanked: 652 Times
Default Photoshop trick
The alloy wheels will take again another 30 days to get delivered and i was anxious to see how it look like after installation. At last decided to do the installation in Photoshop first to see how it looks like ---
Last edited by GTO : 14th June 2010 at 18:59. Reason: Please read our rules. No more than 2 smileys per post please
Old 22nd July 2010, 11:28   #110
Thanked: 652 Times
Default Upgradation stage - 2
Finally after 6 months of garaged life Gypsy is moving to a workshop today for further upgradation mainly -
  • Power brakes installation
  • Power steering Installation
  • Suspension overhauling
  • Alloy wheel installation
  • Perfomance upgradation (Carb porting, FFE, K&N air intake)
Can any one help me with sourcing of PU bushing kits and 2 inch shackle kit for Gypsy.
Old 15th August 2010, 13:44   #111
Thanked: 652 Times
The vehicle is now with very capable hands - Mr. Raju at EKM, for the stage 2 upgradations, alloys arrived at workshop, will be installed after all the works are completed.
Old 16th August 2010, 08:50   #112
Thanked: 57 Times
Looks awesome !!
chopping the rear over hang will be a killer.
livyodream is offline   Reply With Quote
Old 19th August 2010, 17:57   #113
jeeva's Avatar
Thanked: 558 Times
Isnt that a Jonga in the background?
Where is this garage in EKM?
Shibu would be happy to see this
jeeva is offline   Reply With Quote
Old 19th August 2010, 18:10   #114
JeepCaptain's Avatar
Thanked: 468 Times
jeeva, That Location was identified by JC long back. Thanks for your PM.
I spent maximum of my time searching for scrap 4x4's and also mechanics and garages to restore them.
JeepCaptain is offline   Reply With Quote
Old 22nd August 2010, 13:49   #115
Thanked: 652 Times
Hi Jeeva, Shibu is an Encyclopedia for everything related to 4x4's.
Old 6th September 2010, 12:38   #116
Thanked: 652 Times
Default Few more upgrades
Here are a few more upgrades done on the Gypsy, tried to squeeze the maximum out of the the 1ltr motor
Old 15th September 2010, 11:52   #117
annu0706's Avatar
Great work anil
after fitting the alloys the gypsy looks killer.
annu0706 is offline   Reply With Quote
Old 26th September 2010, 17:39   #118
Thanked: 652 Times
Default Gypsy on the full swing... still to go further.
Great work anil
--- Thanks Annu.
Almost all the intended repairs are completed but the non stop monsoon is not allowing to take the vehicle for an offroad test due as there are some leak issue on soft top, we dosent wanted the recaros to be spoilt by the rain. Here are some pics takes while a small drive done at the beach road.
  • The recambered leafs allowed resonable articulation & safe guarded tyres from touching the body even with the -ve offset wheels.
  • With all the body & suspension bishes replaced the ride is absoultely smooth & noise free, no more squeaks & rattle noise any where from the suspension.
  • There is no more free play of steering with the new power steering steup, more over the steering is soo precise & smooth that it can now be parked at a very tight spot with only one finger on steering wheel.
  • Brakebooster installation has totally changed the way it used to stop before, adding more confidence to the driving.
  • All the existing oils were changed including a complete over haul of the gear box & transfer case, a broken gear, main shaft, & bearing for the transfer case are replaced along with all the oil seals using SGP.
  • The free flow air filter seems to have bought a 10% increase in perfomance with a smooth idling & engine start.
  • A/C is fully functional and provides proper cooling in minutes, the soft top require upgradation to make best use of the A/C. In normal running conditions it seems that A/C is not putting any considerable load on engine.
Let the pictures explain further -
Old 27th September 2010, 03:52   #119
Hey Anil , thats a nicely worked gypsy that you have. What was the total cost of the project?
poojanayak is offline   Reply With Quote
Old 28th September 2010, 16:04   #120
Thanked: 652 Times
Thanks Pooja, since all the repairs were affected over a period of time i haven't maintanied a proper expenditure figures but still altogether it is nothing less than 2.7 lacs including the vehicle.
Gypsy's Fate after Bharat Stage IV Amar82 4x4 Vehicles 126 1st August 2017 07:51
My Gypsy Rebuild Project krishnathanthri 4x4 Vehicles 326 26th June 2014 23:59
Gypsy on Steroids -- The SPoA Project. EDIT: Stage-2 Started now.. khan_sultan 4x4 Technical 239 3rd February 2011 15:06
My Gypsy Rebuild - Bushranger Ashish B 4x4 Vehicles 69 20th October 2010 08:31
