Closed Thread
Old 13th January 2010, 08:56   #376
arjunrudra's Avatar
Thanked: 13 Times
The THAR . Dont know, it looks way to bling for me. I think my jeep looks way better than the thar.
arjunrudra is offline
Old 13th January 2010, 09:21   #377
Samurai's Avatar
Thanked: 14,541 Times
Deepak, GC is a misnomer to be used here for rampover angle calculation.
Technically GC is the height of the lowest point, generally the lowest point of differential.
But the GC value we need for rampover calculation is generally the clearance at the mid point of the wheelbase. As shown by Jaggu in post #366. That point is generally 1 foot above the ground.
BTW, I didn't calculate the rampover angle of 33 degree for the CJ340. It is printed on the CJ340 brochure along with pictorial description.
Actually my CJ340 has even more rampover angle than the stock CJ340, since it has been raised, and runs on bigger tyres.
Samurai is offline
Old 13th January 2010, 12:00   #378
Rocky_Balboa's Avatar
Thanked: 61 Times
Samurai,
Would it be possible for You to post the pictorial description here.
TIA
Rocky_Balboa is offline
Old 13th January 2010, 12:34   #379
Samurai's Avatar
Not a problem, here you go:
Samurai is offline
Old 13th January 2010, 12:36   #380
vinod_nookala's Avatar
Thanked: 411 Times
What does M&M manual say for MM540 DP interms of break over angle?
vinod_nookala is offline
Old 13th January 2010, 13:06   #381
starter's Avatar
Thanked: 272 Times
Default Mm540
Here you go with the MM540 specification Vinod!
It says 27.
starter is offline
Old 13th January 2010, 13:25   #382
ex670c's Avatar
Thanked: 1,799 Times
Default Gravity
Originally Posted by DKG View Post
Noakh toot gayee to kya karoge? Sharpner bhi leke jaana padega. Iss liye kabhi kabhi pen aur sensible option hoti
Translated: You need to carry a sharpner with a pencil like some spares and a mechanic with the good old Jeep just kidding guys !
Hi DKG,
In SPACE you forgot, gravity or the lack of it.
Simple Pencil
Arka
ex670c is offline
Old 13th January 2010, 13:35   #383
Thanked: 61 Times
Thanks Samurai.
Comparing the pic You posted against Jaggu's, isnt there a difference at the the actual angle is calculated. Not that it would make a big difference, but just trying to understand.
Starter, the TBhp logo has overtaken the bottom of the pic. Can You please post another one.
@Jaggu, Thanks for the clarification. I re-read the 4x4forum and it said close to 90deg is ideal. Just curious to know if 90deg angle can ever be achieved. Maybe the Bowler Wild Cat!!
PS: I am getting more curious and interested, since my wifey gave a green signal to buy a Thar sometime next year. Yippeeeeeeeeeeeeee
Old 13th January 2010, 13:54   #384
starter's Avatar
Thanked: 272 Times
Hey Rocky,
Sorry about that. I edited it a little bit in mspaint and uploading it now.
Hope, this is better.
Cheers,
Deepak
OT: Gypsy might also be in this range or maybe slightly better. I do not know, Experts might comment. Gypsy has a WB of 2375 (2430 for 540) and GC of 210 (200 for 540), just in comparison to the below picture of 540.
starter is offline
Old 13th January 2010, 14:20   #385
MileCruncher's Avatar
Thanked: 356 Times
I know this might be the wrong place, but can someone please why one shouldn't drive a 4x4 on tarmac and why does this damage the transdfer case. Then what about All Wheel Drive cars?
MileCruncher is offline
Old 13th January 2010, 14:23   #386
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
Default ROA for MM550
i believe it is 20 deg in the specification sheets.
SPIKE ARRESTOR is offline
Old 13th January 2010, 14:25   #387
Spitfire's Avatar
Thanked: 692 Times
Infractions: 0/1 (7)
Here you go: http://www.team-bhp.com/forum/4x4-te...ng-thread.html (Stupid Questions on offroading thread)
Spitfire is offline
Old 13th January 2010, 14:26   #388
Samurai's Avatar
Check here: https://www.team-bhp.com/forum/4x4-t...ml#post1450245
Samurai is offline
Old 13th January 2010, 14:28   #389
Spitfire's Avatar
Thanked: 692 Times
Mmy 2 cents: Shorter the wheelbase higher will be the rampover angle. Or if you go SPOA.
Look at the thread which shows flying jeeps, thats one expensive way to not bother about rampover angles
Spitfire is offline
Old 13th January 2010, 14:32   #390
Thanked: 757 Times
Default Reason
Dear Milecruncher- a 4WD vehicle with drive engaged to both wheels should not be driven at high speeds on tarmac because this may lead to undue stresses in the driveline (called as driveline windup), in this condition some weak link in your driveline will give up due to these stresses, this can also result in oil leaks from the axles or driveline components. This happens because the front wheels and the rear wheels while going around a turn must have different angular velocities, this is achieved through a centre differential placed between the two axles, which takes care of this change in speed, AWD cars i believe have this arrangement, gurus please correct me if i am wrong.
Spike
Closed Thread
Why I won't buy a Thar... booked Thar! desertfox 4x4 Vehicles 740 2nd April 2015 22:28
Taking the Thar to the 'Thar'. 2000 kms, 3 childhood friends & an epic roadtrip Vroom barabar! Travelogues 30 25th March 2013 18:42
Mahindra Thar Launch on 21st December 2010. Update: Price on Page 2! GTO 4x4 Vehicles 668 5th January 2011 17:04
