| LinkBack | Thread Tools | Search this Thread |
| | #406 |
| Senior - BHPian | ^^ Offroad-Maniac, thats the turbo's intercooler. And the BLACK ONE IS THE 1st Proof of a RHD THAR - Yipeee ![]() ![]() |
| | #407 | |
| Senior - BHPian Join Date: Nov 2009 Location: Deutschland
Thanked: 473 Times
| Quote:
Tejas- your point is well taken, but what makes you say that if he is testing, he will not upsize, my understanding says that it is only when you try different combinations (read testing) you come out with the ideal solution, i am just speculating, only the man himself knows the truth. Spike | |
| | #408 | |
| Distinguished - BHPian ![]() | Quote:
Anyways, hope the car can be inspected / tried out soon and put and end to speculation once and for all. | |
| | #409 | |
| BHPian Join Date: Aug 2008 Location: Thane-Mumbai
Thanked: 30 Times
| Quote:
may be while booking it, sales person will ask, "Sir, you can tick below options :" 1. FFRA (DANA 44) 2a. LSD 2b. Lockers 3. Ultra Low T-Case (4.16:1 4. Snorkel 5. Hard Top 6. SFA (DANA 44) 7. Others.... Please let there be more trailers.. Last edited by offroad_maniac : 13th January 2010 at 19:24. | |
| | #410 |
| Senior - BHPian | |
| | #411 |
| Team-BHP Support ![]() | offroad_maniac, we really don't need ABS in Thar, not unless it can be switched off for offroading. ABS will play hovoc in slippery conditions of OTR trails. Since the rear is DANA 44 with 30 splines, we have many options for full lockers, like OX, ARB, etc. |
| | #412 |
Thanked: 30 Times
| Its just something I can make out with Brake wala hint. Else, we should get optioned as stated. may be discount rate as I think Mahindra has tie up with some reputed company which makes good suspension parts & Lockers (ARB I think.. not sure). |
| | #413 | |
Thanked: 473 Times
| Quote:
Dear Offroadmaniac- That is not a radiator, it is a FMIC (front mounted intercooler) similar to the ones you see in Bolero VLX (hidden behind the front bumper). It is a device used to cool hot compressed gases which have undergone a adiabatic compression process, this is achieved isobarically (under constant pressure conditions, this is one reason why the pressure drop delta around the intercooler must be minimum). Simply put it is a heat exchanger. Guys do you see anything different in this pic Regards, Spike Last edited by SPIKE ARRESTOR : 13th January 2010 at 20:51. | |
| | #414 | |
| Senior - BHPian Join Date: Mar 2006 Location: goa
Thanked: 42 Times
| Quote:
power and Lighter ---- Mhawk engine. Transmission ---- Auto-box Axle-------------- Full floating, LSD, diff lock option. Rampover angle----- Lift kit. So when is the picture realizing ?? ![]() Waiting for this one. Last edited by dinar : 13th January 2010 at 21:03. | |
| | #415 |
Thanked: 42 Times
| @ DHABHAR.BEHRAM,is there additional strengthening added to the fender as compared to the older vehicle? |
| | #416 |
| Senior - BHPian | The engine bay is quite full...must have been quite a job shoe-horning the Scorpio engine into the engine bay of the Thar. in-cab bonnet opener ![]() . instead of the older type (which I actually like) ![]() . |
| | #417 |
| Distinguished - BHPian ![]() | To add: no insulation on the bonnet/hood internally. Support to hold open the bonnet as opposed to going and resting all the way back on the windshield. I have not seen a scorpio engine in detail so i won't know any changed details between the two. EDIT: The mHawk has the intercooler on the top. So i guess that engine is to be ruled out. Last edited by Tejas@perioimpl : 13th January 2010 at 21:56. Reason: see edit |
| | #418 |
| BHPian Join Date: Aug 2007 Location: Bangalore
Thanked: 30 Times
| | #419 |
| Senior - BHPian Join Date: Jul 2008 Location: Back from Exile
Thanked: 193 Times
| the engine and its bay looks quite neatly packed. i think the IC could be placed somewhere else to protect it from stone, but i can see a wire mesh on the front grill (of the thar with bonnet open) to protect it! no wiremesh on the RHD black thar and the silver LHD to protect the IC? wipers on the RHD black thar look out of place, i guess since its a test vehicle! the styling of the Thar reminds me of this> |
| | #420 | |
| Senior - BHPian | Quote:
It will also make lots more different if the wheels that are making its way to Thar to be the nagative offset steel rims, the kind of ones used in Australian Mahindra Jeeps Last edited by trammway : 13th January 2010 at 22:38. | |
Similar Threads | ||||
| Mahindra Thar Launch on 21st December 2010. Update: Price on Page 2! | GTO | 4x4 Vehicles | 668 | 5th January 2011 16:04 |
| The Mahindra Thar (for export only) | vinod_nookala | The International Automotive Scene | 47 | 24th May 2010 18:11 |
