Closed Thread
Old 16th January 2010, 09:52   #481
Thanked: 595 Times
thanx for all the comments and replies on the matter of rear and front tracks being of smaller and bigger size, respectively.
but are there any drawbacks or flaws of this kind of set up on a vehicle?
Parm is offline
Old 16th January 2010, 10:38   #482
DKG
DKG's Avatar
Thanked: 929 Times
In a rear wheel drive car it seems to make sense to have a wider front track for steering stability. Imagine you pushing a wheel barrow with a wider front track. Now imagine you pushing a wheel barrow with a track narrower than your feet, chances are it will be all over the place and a nighmare to steer effectively.
Same way in a front wheel drive car it may make sense to have a wider rear track, so the rear tracks more efficiently (like a man pulling a kart)
I am just visualising a wheel barrow/man powered kart scenario. I wouldn't know more technically but logically it seems to make sense
DKG is offline
Old 16th January 2010, 11:08   #483
Tejas@perioimpl's Avatar
Thanked: 5,060 Times
Default Front track width vs rear
I have a book on automotive engineering. Quoting from there:
At basic level:
Wide track decreases load transfer which is generally good for getting grip on that end of the car.
One disadvantage is that you increase usually weight, because of longer A-arms, push- or pullrods, tierods and driveshafts. Also the moment of inertia in yaw is increased a lot, because it is dependent on the lever arm of your wheels.
At the rear of the car:
A narrow track can be an issue with the drive shaft. You need more angle for the same vertical movement of the wheel you would like to allow.
A shorter track at the rear is also helpful as during turning there will be lesser difference between the radius of curvature between the wheels, not causing the differential to lock to often.
Rear wheels closer tgether aids in traction, for example dragster rear tires are very close. Having the front track width wider than the rears also helps with being able to change direction more quickly. Why? Because: The front wheels will have to absorb all the load transfer... that means the outside front tyre will be much more heavily loaded (twice as much load transfer to the outside front tyre than an equivalent car with equal front and rear track).... and that will promote understeer.
Source: RaceCar Engineering
EDIT: infact we have a thread on teambhp on this which never came to any conclusion. Maybe we can continue discussion about this there.
http://www.team-bhp.com/forum/techni...-v-s-rear.html (the difference in track width- front v/s rear)
Tejas@perioimpl is offline
Old 16th January 2010, 13:51   #484
vinod_nookala's Avatar
Thanked: 411 Times
Hi guys,
Even i had problem initially with difference in the track of Bolero range of vehicles except for Invader.
The wider front track as Trammway said was to accomodate tighter turning circle. The rear was left just like that because-
If you put wider track rear axle, it may foul with body work due to articulation. This may require further investments to cut the body and the door line which is expensive. Invader was newly developed and has a wider and higher body. Plus due to inverted leaf over axle type suspension and commonality of parts i think the Maxx festerra rear axle was adopted.
Plus what ever tejas said holds good for handling purposes.
However this is a big draw extreme back off road specifically for competitions. Imagine if you have to cross a stream on log of wood. How would you accomodate 100+mm difference on a just two wood logs running parallely? Thats why which ever vehicle was developed purely for off road duty like LC, defender and Jeep warangler to name few will not have such wide difference in track.
Now the question is why cant invaders wider axle be adapted to thar? The reason is wider the axle the wider should be the spring points, i.e nearer to the ends of axle. Else there would be tremendous body roll if the springs are not stiff. (1985 to 1989 MM540 and first generation Maxx festerra's)
Thar according to me is developed under tremendous constraints considering market is very small. Expect all the revisions to happen (including MLD/LSD etc) as and when both export and domestic markets pick up. Demand of suitable rear axle width has to come from abroad. Till then who ever is doing logwood crossing and competition specific terrain have to satisfy with spacers.
vinod_nookala is offline
Old 16th January 2010, 16:11   #485
Jaggu's Avatar
Thanked: 7,681 Times
@vinod: It shouldn't be a BIG problem since the difference of approx 100 mm is shared between 2 sides, so one side will go in by 50 mm which is negligible right?
Jaggu is online now
Old 16th January 2010, 16:35   #486
Thanked: 2,132 Times
Originally Posted by Tejas@perioimpl View Post
I have a book on automotive engineering. Quoting from there:.....
Referring to IRS, I think.
Unclear as to what will promote understeer. Doesn't an understeering car not want to change direction?
Originally Posted by vinod_nookala View Post
Hi guys,
Agreed. Even in non extreme situations, the ability to make two tracks rather than four is a great advantage.
AFAIK, for a solid axle, roll stiffness is independent of track. Other things being equal, it will vary as the distance**2 between the spring mounting points.
Sutripta
Sutripta is offline
Old 16th January 2010, 16:49   #487
headers's Avatar
Thanked: 459 Times
A suggestion, have a properly rated winch as a dealer option to cross the log bridges.
headers is offline
Old 16th January 2010, 17:50   #488
Thanked: 411 Times
Default difference in track matters
It matters in such cases!
Old 16th January 2010, 17:55   #489
Samurai's Avatar
Thanked: 14,541 Times
We did such a log crossing in Kakkabe (Coorg) OTR, Gypsy to Telcoline did cross the bridge, although it looked very narrow, just enough for a Jeep.
Vinod, aren't you supposed to be on vacation now?
Samurai is offline
Old 16th January 2010, 17:59   #490
Jaggu's Avatar
Yes thats what i meant, the tyre width itself will take care of such variation unless its those thin NDMS thingies?
Jaggu is online now
Old 16th January 2010, 18:29   #491
Thanked: 66 Times
If I take this ' Done up ' Thar for a OTR.I need Arka's 1 ton just to pick up the plastics/lights/air intakes/some I don't know things etc etc I leave behind.
drjones is offline
Old 17th January 2010, 00:10   #492
Thanked: 595 Times
so this discusion about the front and the rear track measurments concludes that THAR will be getting bolero's front and rear tracks, to enable MM to keep the costs down!
so does that mean the export version of THAR also has a similar set up of the front and rear tracks as the Desi Thar or its different?
Could any one please comment on the front and rear tracks in the following photos i have attached?
Parm is offline
Old 17th January 2010, 01:08   #493
Thanked: 52 Times
What comments are you looking for buddy. Let the car be launched. The first & fourth pic are of the now old generation THAR, live axle.These too had the Track difference.
Why would M&M develop two different chassis, when it knows that THAR will be sold in very small number compared to other vehicles in the portfolio.
dinar is offline
Old 17th January 2010, 09:45   #494
headers's Avatar
Thanked: 459 Times
, he's just trying to keep this thread alive & kicking
headers is offline
Old 17th January 2010, 10:23   #495
There is a nice report / article in the Indian Express today. Here's the link.
The desert rider
VINUMON is offline
Closed Thread
Why I won't buy a Thar... booked Thar! desertfox 4x4 Vehicles 740 2nd April 2015 22:28
Taking the Thar to the 'Thar'. 2000 kms, 3 childhood friends & an epic roadtrip Vroom barabar! Travelogues 30 25th March 2013 18:42
Mahindra Thar Launch on 21st December 2010. Update: Price on Page 2! GTO 4x4 Vehicles 668 5th January 2011 17:04
