| LinkBack | Thread Tools | Search this Thread |
| | #796 |
| Senior - BHPian | I think this engine discussion needs it's own thread. let me throw another spanner in the works. The low revving CRDe D2 engine that comes on the Xylo D2, is that based on the DI Turbo MDI3200T engine? |
| | #797 | |
| Distinguished - BHPian ![]() | Quote:
Hi Spike, As 1) The Bore X Stroke are same as the XD3P. M&M has been making this engine since 1993/94 they have all the machines and tools, do you think they are just going to throw this away. The XD3P we designed to be Turbocharged from its inception, even if the NEF CRDI requires a different Piston/Crank-Shaft/Con-Rod the Forging is similar . And M&M has a lovely facility in Igatpuri? to make the XD3P.2) The NEF engine weights are similar to the Peugeot XD Series. The B275 Family i.e MDI3200TC and SZ2600 weigh 270-325 Kgs. The XDP4.9/XD3P weigh 194Kgs approx. 3) Even uses the Peugeot Type Oil-Cooler. ![]() 4) The Block has been cast similar to SZ2600/MDI3200 to i) Retain familiarity ii) Reduce re-finishing on the raw casting iii) Similar Engine Mounts/Bell-Housing/Starter Motors iii) Mislead people into believing this is a whole new FAMILY of engines. 6) Ford/Caterpillar/M&M were licensed to make the XD3P. Is there any other 4 Cylinder Diesel Engine which Displaces 2498cc? For a 2498cc engine. If is Bore 94mm then obviously the stroke has to be 90mm Only other way is to have Bore of 90mm and a Stroke of 94mm. What is the Bore of the NEF TCI 2.49L or NEF 2.49 CRDi? The NEF 2.49L CRDe is The XD3P CRDI. Though the NEF does not physically resemble the XD3P, because there will be legal implications. However the rotating assembly assembly has been directly copied from the XD3P, which M&M has considerable experience manufacturing since 1993. It looks like a MDI/SZ family, revs Like a Peugeot, weighs as much as a Peugeot. Spike a few Direct question 1) What is the minimum Oil Pressure for the MDI3200TC? 2) What is the minimum Oil Pressure for the NEF 2.49 CRDe? 3) What is the minimum Oil Pressure for the XD3P? If you guys (M&M) are really that smart I hope along with the Oil Cooler, you have used the Peugeot Lubrication System, which is one of the best in the world. Regards, Arka | |
| | #798 | |
| Senior - BHPian Join Date: May 2006 Location: Greater Chennai
Thanked: 327 Times
| Quote:
Guess Peugeot is an old story so any similarities to that family will NOT be referred to / entertained / answered. BTW - Spike - NEF stands for New Engine For ? Next Engineering F?? ![]() | |
| | #799 | |
| Senior - BHPian Join Date: Jul 2007 Location: Dharamsala
Thanked: 297 Times
| Quote:
N=new E=engine F=family And stop calling me Spike! ***************************** | |
| | #800 |
| Senior - BHPian Join Date: Nov 2009 Location: Deutschland
Thanked: 464 Times
| @Headers good one, no more answers for engines from now on, lets keep this thread for Thar only, engines we can discuss elsewhere. Spike |
| | #801 |
| Senior - BHPian | |
| | #802 |
Thanked: 327 Times
| | #803 |
Thanked: 464 Times
| Hi Arka, i have some pictures for you, the pictures are arranged in the following order 1. Piston NEF 2. Block XD3p 3. Block NEF 4. Crankshaft Xd3P 5. Crankshaft NEF 6. Piston XD3P 7. Conrod XD3P 8. Conrod NEF @Dear Fellow BHPians there are many more things which i cannot disclose in this forum, hope these pictures must have given you the answer for the ongoing debate. Spike .P.S.- Arka are you a lawyer by any chance? No offences meant please. Last edited by SPIKE ARRESTOR : 18th February 2010 at 18:26. Reason: pictures got mixed up after uploading |
| | #804 |
| Distinguished - BHPian ![]() Join Date: Jul 2009 Location: Kolkata
Thanked: 518 Times
| | #805 |
| Senior - BHPian | ^^^ Volume of cylinder = φr²h ![]() With bore 94 mm and stroke 90 mm (22/7) * (94/2) * (94/2) * 90 = 624.83 cc (per cylinder) 624.83 * 4 = 2499 cc Last edited by Blue Thunder : 18th February 2010 at 20:50. Reason: added smiley ! |
| | #806 |
| Distinguished - BHPian ![]() | Guys something for you all to chew on. For generations the Rover group lived off an old Buick V8 which served as the basis for their Range Rover and Rover cars.They kept tweaking it for ever. I think they still do !! Rolls Royce for all they once could do could never make an engine so they lived off a GM powerplant till BMW lent them some V12's Jaguar for all the brilliant cars it made over the century couldn't go beyond their classic slant six and V12 and had to sell out to Ford and got a breather of new V8's from Ford Bentley had to do with a blown version of the same 6.7 litre V8 that did duty in Rollers and never made an engine after 1930's !! Now they live off W 12's from the VW stable. BTW even that W12 is two V6's of the Corrado series mated together ! The world's largest company mated two old V6's to make a W12 ! Economics at work! What I am trying to say is its not a joke to design and build a brand new engine. It costs hundreds of millions of dollars. What are the chances M&M or Tata's have designed stuff ground up? to justify calling their engine a totally brand new engine? REMOTE CHANCE !! If the engine has a cast iron block its some old dog worked on and given a new face. If its brand new why is it not an aluminium block. The economics don't work out guys. A new car designed from ground up costs close to a billion dollars. I don't think any Indian company has the guts to sink that kind of money into a model they can't be sure will sell in millions to justify such expense. Just the reason why M&M decided to tango with Renault for the Logan. Sad they had a tough time to even market the car. BTW how many more cars will the fabulous multijet from Fiat do duty in? Looks like every hot hatch in India will eventually have a Fiat engine !! Except for the Nano I can't think of anything which is completely a fresh slate design. But even there I guess some chopping of the Indica block may be a possibility ![]() For all the monopoly PAL and HM enjoyed could they ever design an engine let alone a new car? Giants like Daimler, Chrysler, Nissan and GM and so many others kept fusing companies to find economies of scale because its just not plain viable to design stuff exclusively for a car. You simply don't get the kind of volumes you need to justify a total redesign. Just within the VW group there's large scale component sharing between Audi, VW, Seat and Skoda to make it all viable So lets not waste more time debating this issue because it really is highly unlikely that M&M designed a brand new block and opted for an outdated material ie cast iron for a brand new engine family !! Having said this I do sincerely believe that Indian engineers are second to none and if given the mandate they can deliver a new engine family ![]() Last edited by DKG : 18th February 2010 at 21:18. |
| | #807 | |
Thanked: 518 Times
| Quote:
However, the ?? remain! Regards Sutripta (PS. BT, that was a fast edit) | |
| | #808 | |
| Senior - BHPian | Quote:
Ok, here goes, With bore 90 mm and stroke 94 mm (22/7) * (90/2) * (90/2) * 94 = 598.24 cc (per cylinder) 598.24* 4 = 2393 cc ![]() Last edited by Blue Thunder : 18th February 2010 at 21:29. | |
| | #809 | |
Thanked: 518 Times
| Quote:
Saw your post after I had made mine. Edited mine to add my thoughts to what you had said, but ran over the 20 min time limit. Effort down the drain. In short, I agree with what you state, except your blanket junking of CI. I feel that MM should come out with a CATEGORICAL OFFICIAL statement saying "Our new engine, the NEF, is wholly an inhouse clean sheet design with nothing borrowed or adapted from any existing design". Because that is what is being implied. Otherwise it doesn't matter. For the record, I don't think it is based on the XD3. Just gutfeel. Were the KOEL RET3 and RET4 copied/ adapted from any other design? Your post can form the starting point of an interesting thread. Know this is not the thread for it, but no one has any comments/ insights to the mHawk/ 2.2 Dicor. Regards Sutripta | |
| | #810 |
| Senior - BHPian | @ Spike: Why is the liner in the NEF Engines not a press fit ? And what is a wet liner? I thought all liners are surrounded by water jackets having water dummies Also why is the peak torque band of the Storm engine so narrow 1800-2200 RPM and what is the redline of the engine. The tacho has no marking ![]() Last edited by MileCruncher : 18th February 2010 at 22:05. |
Similar Threads | ||||
| Mahindra Thar Launch on 21st December 2010. Update: Price on Page 2! | GTO | 4x4 Vehicles | 668 | 5th January 2011 16:04 |
| The Mahindra Thar (for export only) | vinod_nookala | The International Automotive Scene | 47 | 24th May 2010 18:11 |
