Closed Thread
Old 18th February 2010, 22:20   #811
Thanked: 524 Times
Originally Posted by Blue Thunder View Post
With bore 90 mm and stroke 94 mm
(22/7) * (90/2) * (90/2) * 94 = 598.24 cc (per cylinder)
598.24* 4 = 2393 cc
Ah. Now all is clear.
Sutripta
Sutripta is offline
Old 19th February 2010, 00:49   #812
What a post, DKG! It rang a bell in my mind about an article that I had read some time back; been searching that for abt half an hour. Feel like worth sharing.
The Hindu : New diesels and `The Scorpio'
BTW, I've have read that the 2.2 dicor employs an aluminum head. Not sure about the block though; heard both versions.
VINUMON is offline
Old 19th February 2010, 01:50   #813
getsurya's Avatar
Thanked: 118 Times
DKG,
Very good post, puts things in the right perspective. Appreciate it.
getsurya is offline
Old 19th February 2010, 06:04   #814
headers's Avatar
Thanked: 349 Times
Originally Posted by MileCruncher View Post
Also why is the peak torque band of the Storm engine so narrow 1800-2200 RPM and what is the redline of the engine. The tacho has no marking
Press on it baby! - Guess the Storm redlines at 4600 RPM. Its definitely upwards of 4000-4200.
On the lighter side - There is no redline on the Tacho as you can't redline a Storm
headers is online now
Old 19th February 2010, 06:39   #815
Thanked: 456 Times
@ Spike: Why is the liner in the NEF Engines not a press fit ? And what is a wet liner? I thought all liners are surrounded by water jackets having water dummies
Wet liner means the liner is in direct contact with the coolant/water in the water jacket. Liner is not surrounded by the block casting material. Wet liners are open deck engines.
Dry liner has engine block casting material supporting the liner from all sides. Liner doesn't come in direct contact with the coolant, instead its the engine block casting that comes in contact with the coolant. Liner has to be press fitted into the block.
Sankar is offline
Old 19th February 2010, 07:18   #816
DKG
DKG's Avatar
Thanked: 612 Times
I agree with what you state, except your blanket junking of CI.
Sutripta I assume you mean Cast Iron for CI?
If so I have nothing against the material. So many of the worlds legendary engines were built using it. My inline 8 Packards are all CI and a virtual delight in refinement
But in the 30's mfgs started switching to aluminium pistons and heads and eventually blocks.
All I meant is when the whole world has switched to aluminium does it make sense for a present day mfg to opt for this material whose weight disadvantage has serious implications on fuel economy and handling?
Its a bit bewildering that engineers would opt for cast iron in a new engine family.
We all know the Tata's have stumped the engineering world with the Nano. But CI in engines today? Not very sure about it making sense.
DKG is online now
Old 19th February 2010, 10:11   #817
vinod_nookala's Avatar
Thanked: 332 Times
DKG,
Very well put together thoughts. I am no engine expert and hence every convincing argument makes me think otherwise.
Your point is very well taken that designing an all new engine is a bit feat! I also believe that certain inherent characteristics of a successful engine can be used to build the base but calling it a CDRI'ed version of an old engine would be a mistake in my opinion. Enough and more changes have happened to justify enough to call it new!
Aluminum isnt the best of the materials. CI has it advantages and the biggest of them being it is cheaper and easier to manufacture it. If you see the percentage of aluminum in M&M engines have increased over the years. The latest 2.2 M hawk is an example. The choice of material depends upon volumes the vehicle is likely to do and the cost at which manufacturer wants the vehicle to be offered to public
M&M engines surely have been an evolution of their past engines (common that's how every body learns) but at this stage say with 2.2 Mhawk or even current much more improvised CRde 2.5/2.6 it wouldn't be justified to plainly call it CRDied version of a 1970's engine IMO.
p.s- The current 2.2 Dicor and the 2.2 M hawk both displace identical displacements 2179cc, run twin cam shafts and have almost identical weights, power and torque ratings and has been developed by AVL Austria in association with the respective manufacturers. So, do you guys think they both are same design and based on peugeot 2.1 litre block?
vinod_nookala is offline
Old 19th February 2010, 10:19   #818
Thanked: 456 Times
Is the 2.2 MHawk an all aluminium construction or is it an iron block with aluminium head?
Sankar is offline
Old 19th February 2010, 10:20   #819
ex670c's Avatar
Thanked: 870 Times
Default Correction
Originally Posted by SPIKE ARRESTOR View Post
Hi Arka, i have some pictures for you, the pictures are arranged in the following order 1. Piston NEF 2. Block XD3p 3. Block NEF 4. Crankshaft Xd3P 5. Crankshaft NEF 6. Piston XD3P 7. Conrod XD3P 8. Conrod NEF
@Dear Fellow BHPians there are many more things which i cannot disclose in this forum, hope these pictures must have given you the answer for the ongoing debate.
Spike.
598.24* 4 = 2393 cc
Hi Guys,
@ SPIKE Thanks for showing the pics, what about the oil cooler and the minimum lubrication specs I had asked before.
@ Blue_Thunder and Sutripta thanks for correcting me and conforming that for 2498cc 4 cyl. with a 94mm bore the stroke has to 90mm; and even if we inter-change the bore or stroke the displacement will change.
Arka
ex670c is offline
Old 19th February 2010, 10:47   #820
headers's Avatar
Thanked: 349 Times
Aluminium is a great material if sufficiently treated to withstand the internal stresses that a Diesel Engine has to offer. But the cost of manufacture goes up and one needs volumes to justify that!
And NOT all engines can have aluminium blocks.
Old 19th February 2010, 10:53   #821
DKG
DKG's Avatar
Thanked: 612 Times
Of the new CRDi diesels made by Fiat,Merc, BMW,VW, Toyota and Nissan which engine doing duty in cars or SUV's has a cast iron block? I was under the impression, and I could be totally wrong, that none of the modern diesels are based on cast iron blocks.
DKG is online now
Old 19th February 2010, 10:54   #822
Thanked: 129 Times
Gurus, probably a dumb question, but do they make diesels with Aluminum blocks?
And wasnt' the Indica (v1) engine in house design from Tatas?
BaCkSeAtDrIVeR is offline
Old 19th February 2010, 11:18   #823
headers's Avatar
Thanked: 349 Times
One other reason why the World is switching over to Al is POLLUTION
And Deepak, You are not talking Rhino, Ambassador..get the drift
CI pollution treatment is more cumbersome than Al.
Old 19th February 2010, 11:41   #824
star_aqua's Avatar
Thanked: 72 Times
TATAs are more indigenous and they try to be. but all they could manage till BSII and tried their best for BSIII. did not succeed much hence they have to approach the technology providers or partners to proceed. Here M&M was smart enough to know the consequences prior to others. compare the indica dicor 1.4 enigine with the fiat MJD engine and you will notice how different they are. the dicor engine looks like it is fully messed up. which i meant the placement of egr, intercooler, turbo and their connections and lot more things. you can make out it is an in house design.
NEF is the term used by IVECO of FIAT group when they totally rebuilt the engines with latest technology for EU4, EU5 and US EPA 10. Same term is used by M&M.
star_aqua is offline
Old 19th February 2010, 12:30   #825
Jaggu's Avatar
Thanked: 1,087 Times
I still cant understand this engine debate, what's the big issue? Whatever be the engine, will they reduce the price of the Thar, if its not NEF? Will they offer a cheaper engine option?
I guess not
At the end of the day its a niche seller's market, the Thar.
Jaggu is online now
Closed Thread
Mahindra Thar Launch on 21st December 2010. Update: Price on Page 2! GTO 4x4 Vehicles 668 5th January 2011 16:04
The Mahindra Thar (for export only) vinod_nookala The International Automotive Scene 47 24th May 2010 18:11
