Closed Thread
Old 12th March 2010, 07:33   #1111
MileCruncher's Avatar
Thanked: 356 Times
Originally Posted by offroad_maniac View Post
Thats what I have said in last line.
Just wanted some info regarding Axle Capacity
What is wrong with Thar drive ratio? Can you shed some more light with the figures? I thought the torque figure was better than all the Jeeps so far.
What I meant in my post was higher the gear ratio, more is the available torque. Lets take an example of a normal gearbox which generally has the following gear ratio's
1st Gear- 4:1
2nd Gear - 3:1
3rd Gear - 2:1
4th Gear- 1.5:1
5th Gear - 1:1
As you can see (the above is for illustration only) the First having the higher gear ratio has the maximum amount of torque available. Similarly with the higher drive ratio you one will have higher torque availability in a similar speced engine.
May be Spoke can explain this better
@Behram Sir: Many thanks for the pictures. look forward to seeing them in the showroom soon.
MileCruncher is offline
Old 12th March 2010, 08:47   #1112
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
Smile
Originally Posted by MileCruncher View Post
@offroad:
So with the THAR final drive ratio, even in 4L, you will not get the amount of torque which a MMXX0 will generate.
Can you compare and shed some light on the torque and power band of a MM540XD and Thar? that would help.
Who is this bloke "Spoke"?
@Vinod, this is the White one i was talking about, hope you liked it, attaching one more pic.
Spike
SPIKE ARRESTOR is online now
Old 12th March 2010, 09:24   #1113
Thanked: 356 Times
Will dig out the details and explain. Please give me some time.
Spoke/ Spike/ Spark Arrestor - All the same to me
Spike
Do I see Bridgestone Dueler H/T tyres on the Thar? In that case we can expect it to get stuck in sand very easily
Old 12th March 2010, 09:40   #1114
DKG
DKG's Avatar
Thanked: 958 Times
Great pictures of Thar. But remember even Aishwariya Rai needs to dress up and do some make up to look ravishing . Pass these pictures of Jeeps in Hyderabad to your design/accessories department and have them create a full lineup of accessories that will make the Thar looks drop dead gorgeous like these CJ5's from Hyderabad dressed up as Wranglers
We seriously need to dispel with the "nightsuit" look of the utterly drab 540's.
Now we must focus on increasing the desirability quotient. The Thar must necessarily look a fun, trendy vehicle.
DKG is offline
Old 12th March 2010, 09:53   #1115
Samurai's Avatar
Thanked: 14,546 Times
1st Gear- 4:1
2nd Gear - 3:1
3rd Gear - 2:1
4th Gear- 1.5:1
5th Gear - 1:1
So far I follow you. But I am still waiting to see how MM540 has have more torque than Thar in any given gear.
Samurai is offline
Old 12th March 2010, 10:10   #1116
jeepster's Avatar
Thanked: 985 Times
Originally Posted by jeepster View Post
behram sir
excuse me for asking this
will there be any possibility to get OKBJ Axle instead of IFS?
waiting for answer
jeepster is offline
Old 12th March 2010, 10:11   #1117
DKG
DKG's Avatar
Thanked: 958 Times
To help achieve this objective M&M must offer
1. Range of trendy metallic finishes apart from solid colours
2. Choice of atleast three alloy wheel options
3. Roll cage
4. Jerry cans, winches, spot lamps, GPS, Stereo, aircon
5. Suggest you dump those dated rectangular side lamps for something smarter
6. Clear glass headlamps
7. Removeable hardtop
8. Stanley leather(imitation) seat cover set
BTW if none of the above is possible may I request you please study a army spec 550 and simply replicate all those small elements that make the 550 look so gorgeous. Even that will do !!
DKG is offline
Old 12th March 2010, 10:29   #1118
ex670c's Avatar
Thanked: 1,799 Times
Default Axle Rating
MM550XDP:
Front: Ratio= 4.88:1 Capacity: 907 Kg
Rear: Ratio= 4.88:1 Capacity: 1134 Kg (SFRA)
Thar Axles (As released on European Site)
Front: Ratio= 4.3:1 Capacity: 1100 Kg
Rear: Ratio = 4.3:1 Capacity: 1700 Kg (SFRA)
OKBJ 57" Front Axle is rated around 1400kgs approx
FFRA 53" is 1800Kgs approx
The Old MM540DP/XD had a 2 piece SFRA 19 Spline.
The Newer vehicles are 1 piece SFRA 30 Spline.
The Axle Rating for a Standard Differential i.e Dana 44 or Ford 9 is determined by
I) Differential Strength
1) Dia of Crown Gear : Dia of Pinion Gear
2) Type of carrier Open (2 pinion) Closed (4 pinion)
3) Carrier & Pinion Bearings
II) Axle Strength
1) Length or Housing/Arms
2) Length of Axles
3) Diameter of Axles
4) Strength of UJ/CV Joints
Experts please add anything I have missed.
Arka
ex670c is offline
Old 12th March 2010, 10:34   #1119
ex670c's Avatar
Default Insect Guard
Dear all - As database of my 1000th post on Team BHP, I take this opportunity to finally present to you, photographs of my dream vehicle, the Mahindra Thar. We have put our auto-passion, our heart and our soul into this project. Please help us to ensure that the vehicle succeeds in the marketplace. We promise you that we shall try and incorporate whatever is possible out of what you, as our most esteemed customers, want.
Hello Sir,
Congratulations on creating your Dream Vehicle.
BTW, why is the front tipping down?
Give us a REAL JEEP, and we will make it a commercial success for you.
Arka
PS - Please add the Insect Screen/Chaff Guard, makes the vehicle look much better.
ex670c is offline
Old 12th March 2010, 11:01   #1120
Thanked: 356 Times
Not on any given gear but specifically at 4L. I'm trying to dig out the data to prove my point but I may be wrong too.
P.S: The torque curve of a TDI / IDI engine is much more flatter and more widespread over the rev range vis-a-vis a CRDe engine which has a slightly peaky torque curve, slightly high up the rev range.
Old 12th March 2010, 11:21   #1121
Samurai's Avatar
Fine, the TC ratio for MM540 is 2.46 and for Thar is 2.48. Small difference, but Thar scores here. Thar has 247Nm vs MM540's 117Nm. It will take some really crazy gear ratio to rob the torque advantage from Thar.
Samurai is offline
Old 12th March 2010, 11:41   #1122
Thanked: 16 Times
Talking yeeeeehaaaaw
Thank you TeamBHP moderators & support staff for this wonderfully rewarding journey.
Please accept my best personal regards,
Behram Dhabhar
I want my Thar...i want my thar... who...wchich dealer for Delhi and NCR, is there a hard top option? I think success depends on the initial lot being bang on. Hell, I'll buy it anyway, just to whistle on my derive to work and overtake the pilgrims enroute.
Thank you so much and I wish you the greatest success ever.
Chaunfa
chaunfa is offline
Old 12th March 2010, 11:43   #1123
Thanked: 356 Times
But that 117nm starts at 1200~1500 RPM whereas the 247 NM is somewhere closer to 2200 RPM. So the engine may actually be producing about 120~130 NM at 1200 RPM (Can be verified if we get the whole torque curve of the NEF CRDe). There is no denying the fact that the NEF CRDe is much newer technology but at certain revvs, the advantage may be just miniscule. The above statements are based on my own driving experience of the NEF CRDe and TDI engine.
Old 12th March 2010, 11:56   #1124
Samurai's Avatar
Thar: 247NM@1800-2000R.P.M (according to Mahindra Thar website)
MM540: 120Nm @ 2000 rpm (and not 117, my mistake)
Yes, torque curve would help settle the matter.
Samurai is offline
Old 12th March 2010, 12:00   #1125
adc
adc's Avatar
Thanked: 2,100 Times
Behram Dhabhar
White looks good and the specs are right for as a trail tourer - will name it ETT - exotic trail tourer!
So when and how much [the factory model pictured] - is what needs to be posted soon.
adc is offline
Closed Thread
Why I won't buy a Thar... booked Thar! desertfox 4x4 Vehicles 740 2nd April 2015 22:28
Taking the Thar to the 'Thar'. 2000 kms, 3 childhood friends & an epic roadtrip Vroom barabar! Travelogues 30 25th March 2013 18:42
Mahindra Thar Launch on 21st December 2010. Update: Price on Page 2! GTO 4x4 Vehicles 668 5th January 2011 17:04
