| LinkBack | Thread Tools | Search this Thread |
| | #1 |
| BHPian Join Date: Dec 2009 Location: KA-19
Thanked: 29 Times
| Hello Everyone, I would like to share with you all, an ambitious jeep restoration story. I am a die-hard Bulletier for the past 20 years. I love long distance rides on my bike solo or with friends. I do not own a four wheeler yet. The very thought of going in for a jeep as the first four wheeler might seem a little strange here. I found this jeep which is a 1984 Mahindra International 4WD, 3 speed and a long wheelbase one through a mere co-incidence. I was actually looking to upgrade my bike to a 500cc standard Bullet when the Jeep Bug bit me. It not only bit me hard, but also swallowed my craving for a Bullet 500cc along with it. My idea of having a Jeep is simple, I would be using it as my family vehicle for a travel not more than 50-60 kms. I am more than willing to drive it over a long distance say about 350 kms or so. Since its a long wheelbase jeep, ride quality should not be that bad I guess. I have read most of the Jeep Gurus in this forum still, against all odds, will be keeping this jeep as a family vehicle. It has a working 4WD and gears shifting smooth as Butter. Yes, you may ask why 4x4 then? Well, You know the answer. Nobody likes to own a Peep (As Mr. Arka would call it and I second his opinion) Since its a long wheelbase jeep, off-roading may be difficult but may not be totally over ruled. I will not be trying off-roading immediately. It will happen in due course with guidence from all Guru's on this forum. This jeep was being used to ferry God's Idols during festivals like Navarathri etc, hence the top portion had been removed completely. There was a platform seated at the back of the jeep to mount the Idols during the processions. I was told that this jeep has been serving the Gods for the past 7-8 years this way! and, during the non festive season it remains parked near a garage in my town withering the all season weather! The very first day I saw this jeep with no wiring, no radiator and diesel tank cap and, was not started in the last 6 months. The owner of the jeep happens to be the owner of the garage said that the engine is in excellent condition and did not require heating to start. When this statement if his was challenged by one of my friends who was accompanying me, the owner of the jeep brought a battery from some other vehicle, connected it and just used a screw driver to short the starter terminals (not recommended though). To all our astonishment, jeep started at the very second crank, without a heater and, with 6 months old diesel that was in the tank without a tank lid. More surprising to me was that there was absolutely no trace of smoke be it black or white! The engine rumbled with the typical Inter signature sound and I was the happiest one to see him come alive!! I have absolutely no plans to touch the engine and gearbox combinations. Before I take you all through the pictures let me tell you that the jeep has done approximately 10k on the Odo after the engine overhauling. The total mileage is not known though, should be close to 175k. So, there was no engine work needed, gear box and the transfer case is in excellent condition (the 4WD was not being used and it was disconnected). The body of the jeep needed extensive surgery I thought. The chassis were in good condition so sand blasting was overruled. The Mechanic did not suggest me to get the anti rust treatment done. The rust on the body except certain places seemed to be only surface rust. I must admit that the gauge of the metal is real thick. All the pictures are taken from my cell phone camera. Please bear with the picture quality. Last edited by Jaggu : 18th January 2010 at 22:19. Reason: Removing [Font] tags, please avoid copy paste from external font editors and use Preview before Submitting posts. Thanks |
| | #2 | |
| Senior - BHPian Join Date: Oct 2005 Location: NA
| Quote:
![]() Come on load the rest of the photos up so we can see what your Jeep looks like now. | |
| | #3 |
| Senior - BHPian Join Date: Feb 2008 Location: T H R I S S U R
Thanked: 414 Times
Infractions: 0/1 (5) | Congrats for the buy MR. rattler , Kudos to you. Nowa days many people are getting bit by the Jeep bug after reading and seeing Jeep restoration stories in TBHP , the same thing happened to you and me. You showed the guts to do it , i really appreciate it ![]() You are very lucky to own a Gods Chariot. While restoring , instead of trying to patch the tub , you can go and get a brand new Tub. Are you planning to get a power steering ? Are you planning to increace the wheel base ? Are you planning to shorten the chase length ? I will be glued to this thread. Kudos !! |
| | #4 |
Thanked: 29 Times
| | #5 |
| BHPian Join Date: Aug 2008 Location: Thane-Mumbai
Thanked: 30 Times
| Congrats Rattler.. You are now a JEEP Owner. must be a proud feeling. Chassis looks clean in 2nd last shots, however since you are into restoring it, better go with scrapping all the rust off & paint it with some new weather resistant paint. As it has a C-Section chassis, there wont be any difficulty cleaning & painting it. same goes for body. (I am not sure if you have already done the changes , coz the date on the pics shows June-09 so the jeep must be ready by now then) If not, next thing you can do is change the tires, check for the leafs & shocks. as you have already mentioned about the engine, then better stick with it w/o any changes. All the Best with restoration. |
| | #6 | |||
Thanked: 29 Times
| Quote:
Best regards, Sudhir. Last edited by Jaggu : 18th January 2010 at 23:18. Reason: Please avoid Quoting entire large posts in reply, Thanks | |||
| | #7 |
| Senior - BHPian | Congrats Rattler. I too have a 1982 LWB Jeep (or Peep) with the Inter engine and 3 speed gearbox. It was a 4x4 but the previous owner removed it. I have to install that again. You can find the pics in this thread - http://www.team-bhp.com/forum/4x4-ve...army-jeep.html (Just bought an ex-army Jeep) Waiting for the rest of your pics. Last edited by BlackPearl : 18th January 2010 at 23:11. |
| | #8 | |
Thanked: 29 Times
| Quote:
Best regards, Sudhir. I am back with more pictures. Please note that this jeep is being restored to be used as a family vehicle so, I have got a few alterations done enabling the front and rear passengers an easy ingress and egress. Over to pictures. Last edited by Jaggu : 18th January 2010 at 23:35. Reason: Back to back posts, use Multi Quote (Quote +) or EDIT the original post instead. Thanks | |
| | #9 |
| BHPian Join Date: Apr 2009 Location: Pune
Thanked: 97 Times
| | #10 |
Thanked: 29 Times
| Hi JD, The reason behind the long restoration period is none other than the man power issue. It is so common in this part of the state and one has to really have loads of patience to pursue his/her project. Best regards, Sudhir. |
| | #11 |
Thanked: 29 Times
| Hi, I am back with a few more pictures of my Jeep. The long side panels of the jeep gave me just enough space to provide a door on the left hand side for the rear passengers. With a long running board and front facing bench seat at the rear, passengers will not have to struggle during ingress and egress. |
| | #12 |
| Senior - BHPian | Somehow I think the bull bars mar the beauty of the CJ front. |
| | #13 |
| BHPian Join Date: Dec 2009 Location: Indore
| Hey Rattler, That's a good paint job and I must say you have a good taste. Is this a 650 or 750 DI? Please share the cost breakdown involved with vehicle purchase, painting, soft top etc. Regards Pranav |
| | #14 |
| Senior - BHPian | Wow, a pretty rare model I say. It is not a CJ500. Tooo long for a MWB. What is this model guys? Looks more on the 650/750 category. Nice job on the restoration... Which place in KA is this? |
| | #15 |
Thanked: 29 Times
| Hi Beejay, Thank you for your opinion. I just thought that the Bull bar with body colored paint would look okay. Of course, the long wheelbase jeep looks still longer!! I am going to fix two large head light domes, sourced from an old 1210 D truck. Probably they will be peeping through the Bull bar windows!! Best Regards, Sudhir. |
Similar Threads | ||||
| Restoration of a LHD Willys Jeep | Ravi Kapur | Post-War | 15 | 8th December 2012 10:20 |
| Tale of 2 Gypsies : The story of my Ex Army Gypsy Acquisition and Restoration | abheekg | 4x4 Vehicles | 19 | 15th August 2009 09:34 |
| Jeep --- The untold story. | egangsta | 4x4 Vehicles | 48 | 18th June 2009 15:08 |
| My lil Jeep Story | desideep | 4x4 Vehicles | 15 | 16th June 2009 03:23 |
| Jeep restoration | VJV | Modifications & Accessories | 1 | 24th February 2009 11:24 |
