Old 19th February 2010, 22:25   #16
sreejeshmp's Avatar
Thanked: 571 Times
First we finish with the external patch work with body on chassis (I believe that will help to get the proper shape while tinkering). After that will unbolt the body from the chassis and do the platform tinkering.
sreejeshmp is offline   (1) Thanks Reply With Quote
Old 19th February 2010, 23:34   #17
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
@Vinod what wheel rim size are you using for your 235 tyre?
Spike
SPIKE ARRESTOR is offline   (1) Thanks Reply With Quote
Old 20th February 2010, 11:39   #18
vinod_nookala's Avatar
Thanked: 411 Times
Spike
4.5J- standard jeep wheel rim
vinod_nookala is offline   Reply With Quote
Old 20th February 2010, 14:41   #19
Thanked: 757 Times
@Vinod 4.5J ,is for a designed section width of 157mm, for your tyre it should be 6.5J or 6J atleast
Spike
Old 22nd February 2010, 10:37   #20
Thanked: 411 Times
Spike
I know spike, but trust me no problem till date!! I may further change my Tyre soon in the interest of ease of steering and off road ability soon.
Old 26th February 2010, 16:12   #21
sreejeshmp's Avatar
Thanked: 571 Times
40% of the tinkering work done. The Mechanical work will start on next week Some WIP pics.
Old 2nd March 2010, 10:27   #22
sreejeshmp's Avatar
Thanked: 571 Times
The previous owner had put 10 leafs on front and 11 on rear. I want to remove the extra leafs put by him and keep as original (CJ500D) set up so please help.
1. Total no of leafs used on front and rear leaf set?
2. Which are the different leafs used in front and rear leaf set? (If possible, please give me the dimensions)
My mechanic advised me to keep 8 on front and 10 on rear but I am decided to go for the Original OEM set up.(I think the mechanic is not sure which one to remove!)
Old 3rd March 2010, 10:18   #23
mail2abhi83's Avatar
Hi There,
Looks like the previous owner wanted to raise the GC, experts, is it ok to have extra leaves, for what I know, this should affect the C&P configuration. Please enlighten.
Regds
Abhi
mail2abhi83 is offline   Reply With Quote
Old 4th March 2010, 20:09   #24
sreejeshmp's Avatar
Thanked: 571 Times
Body removed from the chassis, Mechanical work will start tomorrow.
Old 4th March 2010, 21:02   #25
Thanked: 66 Times
You are absolutely right in deciding to go back to the original setup. Exrtra number of leafs will increase body roll and will affect handling adversely. For the correct number of leaves contact UBS Sir or Behram Sir
Ashley Nair is offline   Reply With Quote
Old 6th March 2010, 19:30   #26
sreejeshmp's Avatar
Thanked: 571 Times
Old 10th March 2010, 08:00   #27
sreejeshmp's Avatar
Thanked: 571 Times
tinkering work is at final stage . And Purchased all most all the body and chassis nut & bolt bushes etc.some WIP pics.
Old 12th March 2010, 21:23   #28
sreejeshmp's Avatar
Thanked: 571 Times
Ok NO help from Bhpians
I decided to go head with 8 leafs on front and 9 on rear with a 4" and 4.5" bend.
Jayettan The senior patch worker correcting the leaf spring bend.
The Scorpios 16" tire fits perfectly on the stock rim.
Old 16th March 2010, 20:10   #29
sreejeshmp's Avatar
Thanked: 571 Times
A minor change on the grill, Head light fittings changed to willys MB type.
Attachment 309167
Old 17th March 2010, 22:33   #30
JeepCaptain's Avatar
Thanked: 468 Times
Sreejesh, All the best with your restoration. Contact Arka, Dhabar Behram or Spike Arrester by PM if you need technical help.
After the flood of SWB Jeep restoration stories, good to see some MWB Jeep restorations aswell.
Shibu
JeepCaptain is offline   Reply With Quote
Mahindra 500D 1986 Model - Restoration Thread mail2abhi83 4x4 Vehicles 30 16th May 2013 14:59
1988 Mahindra CJ 500D 4WD Diesel Jeep aravind kannan 4x4 Vehicles 19 24th February 2013 17:27
Mahindra 4WD vs Modern 4WD Samurai 4x4 Technical 137 19th February 2012 19:46
conversion of 500D jeep engine into DI vipinmohan Modifications & Accessories 1 29th July 2010 17:24
CJ 500d for sale in Hyderabad bblost Shifting gears 0 24th April 2008 18:29
