Old 15th June 2010, 23:46   #76
Amazing outcome sreejesh. That is how a LWB can look appealing.
Pranav
NDMS is offline   Reply With Quote
Old 16th June 2010, 04:24   #77
Thanked: 58 Times
Very Nice Man . congrats ans all the best with your jeep
davids4x4mm550 is offline   Reply With Quote
Old 16th June 2010, 06:56   #78
MileCruncher's Avatar
Thanked: 357 Times
The jeep is looking real nice except the Scorpio RVMs which are standing out. Classic type RVMs are still available and I would suggest using that. Else use Bolero type which is used in Major / Commander as well.
BTW when does she break her teeth in an OTR?
MileCruncher is offline   Reply With Quote
Old 16th June 2010, 09:51   #79
sreejeshmp's Avatar
Thanked: 574 Times
Thank you thank you.
The RVMs are from TATA ACE ,I searched for the CLASSIC type mirrors in calicut but no luck. Once I got one definitely I will change.
This weekend I am going to Nelliampathi(Palakkad,Kerala) for a small off road trip.
sreejeshmp is offline   (1) Thanks Reply With Quote
Old 22nd June 2010, 15:55   #80
sreejeshmp's Avatar
Thanked: 574 Times
On the way to Nelliampathi.
me and my jeep
My Brother
Old 22nd June 2010, 17:23   #81
Kandisa's Avatar
Thanked: 436 Times
Excellent makeover There are few really beuatiful 540 types of jeeps on the forums, but 1st time seeing such a nicely done longer wheelbase jeep.
Kandisa is offline   Reply With Quote
Old 22nd June 2010, 18:59   #82
starter's Avatar
Thanked: 314 Times
+1 to that Kandisa.
Sreejesh, really a fantastic job.
Had i seen your Jeep a few months earlier, i would've probably bought a Major
Cheers,
Deepak
starter is offline   Reply With Quote
Old 5th December 2010, 23:29   #83
svsantosh's Avatar
Thanked: 1,424 Times
why is this page in the book familiar?
svsantosh is offline   Reply With Quote
Old 6th December 2010, 00:42   #84
jeepster's Avatar
Thanked: 1,013 Times
please give us more hints to find it.
jokes apart congrats for the picture.
jeepster is offline   Reply With Quote
Old 6th December 2010, 19:33   #85
sreejeshmp's Avatar
Thanked: 574 Times
Thank you santhosh, I am honored.Please please tell me the name and month of the magazine.
Old 6th December 2010, 19:38   #86
svsantosh's Avatar
Dont curse me if I am wrong, had at least 10 books to pass time in a resort, must be Autocar, Dec10 issue. Guys who subscribe, please help me out here...
Old 14th June 2012, 07:46   #87
Thanked: 63 Times
Default Re: Mahindra CJ 500D 4WD Rebuild
Originally Posted by sreejeshmp View Post
The Putty work is going on and it takes more time.
I got the Lamda free wheeling hub. But my mechanic don't know how to fit that. So I have to do it myself. I am not able to get a clear picture of the installation from the Fitting Instructions from Lamda.
in the Instructions 4th point says "INSERT CIRCLIP on axle shaft" Do we have to buy new sirclip for that or it will be there inside the OEM front hub ?? Please help me
What are those align Marks (instruction no 7)? is they are inside the cover assembly ?
dear sreejesh ,I am going through same problem in the installation of the free wheeling hubs.
My mechanic ,didnot know the what FWH are ,and how to install them.
In your third picture ,you are seen locating the allign marks .
Moreover ,the fourth instruction of inserting circlip on axle shaft is troubling me too.
My doubt is where exactly to set the circlip and should i buy a new one or its provided.
Secondly ,do i need to open and detach the cover of FWH from the body and tighten the body first
regards
praveen singh
blueblooded is offline   Reply With Quote
Old 14th June 2012, 17:12   #88
sreejeshmp's Avatar
Thanked: 574 Times
regards
praveen singh
Dear Praveen,
The Sir clip is on the axle.
I will try to give the steps.. this is what I did, I did it myself .
1. Remove the OEM hubs from the from axles
2. Check whether the Sir clip is there or not.If there remove it from the axle (If not get the same there is no problem if you didn't put the sir clip but it may make sound/or its not the proper way)
3. open the cap of the FWH using proper allen key(only open while the FWH knob in open position)
4. Normally the the alignment mark on the FWH cap will be in correct alignment .
5.fit the FWH on to the axle and put the Sir clip
6.Better use new TVS bolts with spring washers and tight it.
7.fit the Cap on to the Base of the FWH (No need for grease) tight the Allen bolts.
for testing: Jack up the front diff and rotate the wheels at this point the front joint should not rotate.. repeat on both the wheels.
then rotate the knob on the FWH to lock position (If the knob is tight then turn the steering wheel left and right and then keep the wheel straight it will make the knob free) then again rotate the wheel this time the from drive shaft should rotate... don't forget to keep the gearbox neutral. do the same test with 4WD gear engaged for a confirmation .
Hope this helps you.
sreejeshmp is offline   (3) Thanks Reply With Quote
Old 24th February 2013, 09:20   #89
Thanked: 38 Times
My friend Rahul and I have a CJ500d Jeep 1988 for weekend fun and OTR in Vellore Tamil Nadu. We love the B275 international engine and the T18 transfer case.
Is it possible to just change the gearbox to a 4/5 speed GB and retain the same engine and transfer case.
Will using M&M's KMT 90/ BA10/ NGT GB be a straight fit?
Will the length of the propeller shafts have to be modified and the hand lever position changed.
Which of these will need a customised adaptor plate?
How much will these used GB's cost in Chennai / B'lore ?
Are used 'Warn Overdrives available in India'? Has anyone used it?
Is Arka (ex670c) there? we need your expert opinion please mail us at remhoby@gmail.com
drsamuelk is offline   Reply With Quote
Old 24th February 2013, 19:50   #90
Thanked: 63 Times
dear drsamuelk, you can very well retain the original B275 engine and T-18 transfer case with the KMT 90 4 speed gear box .This is the very combination I am using with my 1986 MM CJ500D.Here I take the liberty of much abused saying that B275 is a bullet proof engine .
In that case there would not be any need for any adapter plate as the the KMT 90 4 speed is straight fit to B275 engine.GO ahead with your modification and keep us posted for progress and queries
regards
praveen singh
Mahindra 500D 1986 Model - Restoration Thread mail2abhi83 4x4 Vehicles 30 16th May 2013 14:59
1988 Mahindra CJ 500D 4WD Diesel Jeep aravind kannan 4x4 Vehicles 19 24th February 2013 17:27
Mahindra 4WD vs Modern 4WD Samurai 4x4 Technical 137 19th February 2012 19:46
conversion of 500D jeep engine into DI vipinmohan Modifications & Accessories 1 29th July 2010 17:24
CJ 500d for sale in Hyderabad bblost Shifting gears 0 24th April 2008 18:29
