Old 2nd March 2010, 11:16   #31
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
Default On being a JEEPer
Originally Posted by ex670c View Post
Hi Spike,
Since we did not have a Serving M&M employee, opening up the BOM for us, I decided to use the South African/Australian name.
Brush is also a term applied to shrubs/shrub land.
When you drive through brush, you brush aside the branches and they snap back on your radiator.
Congratulations on becoming a JEEPer .
Arka
Hi Arka Sir, thanks for the info, i didn't know that,you need not be a serving employee to find out things by opening BOMs, nor do i have any BOM for that matter, i don't work on BOMs, for your kind information my association with Jeeps is from the age of 5 (started driving when i was 11 and first drove a MM540DP when i was 12), so i was a JEEPer long time back, although i don't own one
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 2nd March 2010, 13:08   #32
headers's Avatar
Thanked: 464 Times
Spike
You drove without a valid Driving License - BAD BOY - wait till i tell ....!!
Old 2nd March 2010, 14:12   #33
ex670c's Avatar
Thanked: 1,820 Times
Default Stgh
Spike
STGH.
Spike, its an M&M Trend, Most M&M employees don't own JEEPs.
Arka
Old 2nd March 2010, 14:33   #34
V-16's Avatar
Thanked: 862 Times
Originally Posted by Spitfire View Post
No.
I am no expert. So open to confirmation.
As an aside, I am aware that the American chassis one came with coil springs at the rear.
Do you mean the Ford GPW and the Willy's MB?
Even the RCLs came with coils at the rear, that was because of the Recoiless Gun mounted on its back. I have since removed them for sake of ride comfort...whatever can be gained..
...my association with Jeeps is from the age of 5 (started driving when i was 11 and first drove a MM540DP when i was 12),
If you would have been caught at that time maybe your handle would have been SPIKE ARRESTED...just kidding.
My question still unanswered....Gurus?
V-16 is offline   Reply With Quote
Old 2nd March 2010, 15:00   #35
ex670c's Avatar
Default Rcl
No.
M38A1C used by the Indian & Pakistani Army.
http://www.m38a1.com/images/models/C_Model/38a1c_g.jpg
WarWheels.Net - M38A1C Jeep with 106mm Recoilless Rifle Photos.
Arka
Old 2nd March 2010, 20:41   #36
offroad_maniac's Avatar
Thanked: 41 Times
Here is one pic of a jeep chassis having Coils @ rear (Its from V-16's restoration thread):
Question is: Why does it have a SFRA, even when it is supposed to be under greater load with Heavy Machines + the Recoil force? So why not FFRA?
offroad_maniac is offline   Reply With Quote
Old 3rd March 2010, 12:29   #37
ex670c's Avatar
Default Ffra
Hi Offroad Maniac,
The FFRA (2 piece) version was introduced for the 48.4" Track for the Left Off-Set Differential in the 2WD CJ500-101.
Incidentally they are interchangeable while converting a 48.4" Right Off-Set SFRA to FFRA (done that on at least 10 vehicles in Chennai)
Why did the Army RCL not have FFRA -- "BOM" and subsequent changes.
Arka
PS - The Army Workshop did an interesting "FFRA" conversion for GS CJ3B to adapt a hub winch on the Rear Axle for the CJ3B.
Old 12th October 2010, 19:35   #38
Ram
Ram's Avatar
Thanked: 149 Times
On the one hand, if the rear propeller shaft is taken directly from the gearbox in a 2WD, you only need a differential centred in the track, as it is in all the US Jeeps.
On the other hand, if the rear propeller shaft is from the Spicer 18 transfer case, which is always right offset from the gearbox in a 4WD, you need a right offset differential.
Why would you ever need a left offset differential ?
Was it really left offset ?
Ram
Ram is offline   Reply With Quote
Old 13th October 2010, 11:16   #39
ex670c's Avatar
Default off-set
Ram
Hi Ram,
The Left Off-Set Differential was born out of necessity, Its easier to convert a Right Off-Set to Left-Off-Set vice-versa.
So that is what M&M Did when they launched the 2WD CJ4A/CJ4, in the 1960s.
I have done that to a Bolero 53" 1 piece FFRA to fit in my 1996MM540XD, works like a charm.
And if it was not Left Off-Set, we could not have converted 15+ CJ3B's to 2 Piece FFRA, since we are using the 4WD right off-set Diff Housing .
Arka
Techinical differences between Skoda vRS and 1.8TPI ? nanu28 Technical Stuff 22 9th December 2015 21:27
Huge differences in prices between cities Zappo The Indian Car Scene 36 28th October 2013 18:20
MM550 Army to Civilian Makeover by JeepCaptain JeepCaptain 4x4 Vehicles 160 17th May 2013 12:05
Differences between RE Electra X and the New Electra Twinspark bornin70s Motorbikes 18 17th May 2010 19:23
