Old 10th August 2010, 20:38   #136
fazalaliadil's Avatar
Thanked: 624 Times
Originally Posted by JeepMkd View Post
I was on a vacation so now I see how much I've missed. It's great to see that you are making progress.
Hi JeepMkd,
That was a long vacation!
Not much has progressed on this project, due to various reasons or it would be out by now for on and off road tests, much before undergoing the cosmetic transformation.
Since you chopped off the oil sump to accommodate the front PS, how much did you lose in terms of oil capacity? I too will need to do the same as predicted by you, but plan to compensate the chop-loss. Or as Arka suggested a 540 oil pan could be the next alternative if it is compilable.
The KMT-90 GB was a direct fit except for the mismatch of the clutch/ pressure plate fastener holes...which was easily solved by new threaded holes in the pressure plate to suit the holes of the clutch plate.
How is your XD2 doing with the KMT-90?
Arka, Spike,
Please advice, which hand brake cables for this GB, KMT-90 (in pic.) and the 550 rear diffs. so that they dont hang about on the SWB 3B.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_7343.jpg
fazalaliadil is offline   Reply With Quote
Old 11th August 2010, 14:23   #137
JeepMkd's Avatar
The only trouble (if it could be called like that) was actually fitting the starter. As I presume, the Peugeot engine has a 220mm or 230mm wide clutch disc as opposed to the 240mm the Ford has. Therefore, the bell housing is slightly tighter and new holes (2 in total) were drilled and threaded to distance the starter off the engine block.
As of now (and it has been 12-13 years) there was no need to compensate for the oil loss caused by chopping the sump. The oil pressure is always constant, but if you feel unsure and if you can find a proper sump do the conversion. My dad chopped it because you already know that there is no way to find a Mahindra sump over here.
I'll finish the write up in my thread when I'll get pictures... the only thing I'm missing is a camera because I managed to lose mine.
JeepMkd is offline   Reply With Quote
Old 13th March 2011, 08:41   #138
Thanked: 624 Times
Default Re: CJ3B, 'The Dog 2' or 'The Pup': Should I ??
Dear All,
The XD2 was doing fine and was torquer on road but there was excessive engine noise that dampned all other sounds.
In short had to change that one and replace it with a XD3P (wip) photographs attached.
Also in all probability will fit an AC here, just a bit later.
Earlier all general work, GB, suspension etc. were completed.
Will update on Monday.
Request the moderators: To change the CJ 3B in the title of this thread to CJ 340.
Machined block.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-blok.jpg
Rotating while tightening.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-blok-2.jpg
Rotating flywheel during...
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0454.jpg
tightening of big ends.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0455.jpg
Thats my son familiarizing himself
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0465.jpg
and contributing.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0469.jpg
Alternator serviced and ready for disc brakes.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-alt.jpg
Starter serviced.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-sttr.jpg
Old 13th March 2011, 09:02   #139
svsantosh's Avatar
Thanked: 1,392 Times
Fazal sir, - your attention to detail on the paint on the engine shows what this is going to be. You didnt get a chance to share these detailed WIP pics on the white/orange/brown beauties, thanks for this thread.
A few questions.
1) You say this is a CJ340, did the 'door' to access the engine head from REAR come standard? I dont think so... looks like a AFM job, right?
2) But since it is there, gives me ideas to make one for myself, would come in handy while getting a 'oil-cooler' fit ask Arka, you may need one...
svsantosh is offline   Reply With Quote
Old 14th March 2011, 06:46   #140
Thanked: 624 Times
Hi Santosh,
I am fitting the oil cooler from the XD2 on this engine.
Arka Sir, has been my main reference source.
I don't think the rear access door was stock, but it was there when I bought this Jeep.
Old 14th March 2011, 19:40   #141
Thanked: 624 Times
The plan is to start the fully overhauled engine tomorrow.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0472.jpg
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0470.jpg
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0481.jpg
Old 15th March 2011, 13:37   #142
Thanked: 624 Times
Fired the engine today.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0484.jpg
Old 15th March 2011, 15:37   #143
mashmash's Avatar
Thanked: 117 Times
Congratulations... How many more tasks remain? AC, 4x4, body condition?
What is the weight difference between this engine and the original one? Does it cause any inconvenience or has it been taken care of?
Following this thread closely.
MaSh
mashmash is offline   Reply With Quote
Old 15th March 2011, 17:38   #144
Thanked: 11 Times
Its great to see the engine ignited. You have achieved the biggest milestone. As you have already mentioned that itís a super silent engine, please share us the Noise and vibration level with compare t other Indian version XDPs.
Srinivas
svpatra is offline   Reply With Quote
Old 15th March 2011, 22:23   #145
svsantosh's Avatar
OT - superb representation of saying 'engine running' with a PHOTO than a Video - only you can manage it (1st of course, now every one else will follow)
Old 15th March 2011, 22:38   #146
Jaggu's Avatar
Thanked: 7,662 Times
Nice to see a fully rebuilt engine with some detailing also Can't wait to see the progress. Am always envious with hyderabad jeepers, you guys have so much of passion and so many options with mechs in one place!
Old 16th March 2011, 06:51   #147
madhkris's Avatar
Thanked: 70 Times
Fazal Sir,
All your threads are a treat to read and your rebuilds are done with passion. Thanks for sharing with us here. Its great for new jeepers like me. Waiting for more pics and details. Thank you.
madhkris is offline   Reply With Quote
Old 16th March 2011, 06:59   #148
Thanked: 624 Times
Jaggu,
Lets say we are just lucky to still have the Jeep mechanics, denters painters and guys who still know their job and don't treat a Jeep like a car. It is the passion that has fueled employment and kept the expertise in continuation for the men behind the scenes and us.
Santosh,
Thank you, I did not realise it until you mentioned.
Srinivas
Srinivas,
Sad part is that XD2 is meanwhile kept aside as I could not source one part for it, everything else is available. I ran it about a month back, it was smooth as expected and also torquey, it was making a racket, noise due to badly scratched pistons. I could have ignored the noise but couldn't.
I will make it run once I can source the pistons, as everything else has been worked upon it and it is a beautiful engine.
MaSh
Mashmash,
The AC needs to be done after I get this thing going to my satisfaction.
I have not checked the weight difference between the two but it should hardly be much as the sizes are the same. They both fit on the same foundation brackets like a glove.
Body is in good condition but the paint and other cosmetic surgery will have to wait until I do up all the mechanicals first.
However, yesterday after cranking for about 10 seconds we put it off, until we connected the water lines, air cleaner etc. ran it again for about 30 minutes and there is diesel dripping from the pump and oil from the timing cover oil seal which was brand new, but had to open it. Also got the pump checked and serviced, new nozzles are going in today as there was erratic, crude running of the engine due to the pump and nozzles.
Old 16th March 2011, 21:00   #149
Thanked: 624 Times
Serviced pump, new nozzles and Arka's valuable advice, the engine did 6 hours and temp did not cross the 80 mark.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0487.jpg
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0492.jpg
Old 16th March 2011, 22:49   #150
svsantosh's Avatar
What brand is the radiator? Is it a jeeps?
The DOG: Is this the Ultimate CJ3B build? 14000rpm 4x4 Vehicles 33 10th December 2011 03:26
A-Star AT, a.k.a "wide-eyed pup", comes home!. pgsagar Test-Drives & Initial Ownership Reports 70 12th September 2011 21:38
whats better than an original cj3b?? two original cj3b's. 0333 4x4 Vehicles 33 5th March 2009 11:15
Shocking news : $166000 paid for a 10 week labrador pup in Florida santanu Shifting gears 0 31st January 2009 19:55
My Pup and I are in a hurry - Schumi drives a taxi ajmat The International Automotive Scene 30 19th December 2007 11:26
