Old 21st May 2011, 22:26   #211
Jaggu's Avatar
Thanked: 7,658 Times
Default Re: CJ3B, 'The Dog 2' or 'The Pup': Should I ??
I think fuel tank at rear is a bad idea for offroad pup, i would say keep it at the rear but inside the tub.
Jaggu is online now   (1) Thanks Reply With Quote
Old 22nd May 2011, 10:31   #212
fazalaliadil's Avatar
Thanked: 624 Times
Jaggu,
You are right about losing on the break over angle here, after much deliberation I made this choice, favoring a larger capacity tank. It is not practical to have the tank inside the cabin with smell of diesel, more over the filling point will need to go higher than the body line at the sides.
Keep scraping the tank shield is the best option, I guess.
fazalaliadil is offline   Reply With Quote
Old 22nd May 2011, 19:22   #213
Thanked: 624 Times
On second thought, let me check out the possibilities tomorrow.
6 inches at exit means a lot in off roading.
Old 22nd May 2011, 20:36   #214
headers's Avatar
Thanked: 457 Times
If the tank sits within your leaf spring perch points, you will not have issues. But please do not have the tank inside the tub. You may have problems. I've tried and failed!
Old 23rd May 2011, 00:25   #215
Jaggu's Avatar
Get a new age plastic tank with proper caps with rubber O ring seal, you will have no problems
Old 23rd May 2011, 13:06   #216
Thanked: 624 Times
I am bleeding all over already, and theres a lot to go. Moreover the fuel filler hole has been punctured in the side of the body.
Old 23rd May 2011, 13:08   #217
Jaggu's Avatar
I dont think they will be that costly Fazal saab. I say really worth it, even if you dont have the opening in the body what is the problem. Its a soft top, just lift the top and fill her up!
Old 23rd May 2011, 18:03   #218
Thanked: 624 Times
Ironically, the bonnet, grille, windshield are the only parts surviving on the CJ 340 I had.
There goes one more thing out of the above three.
The bonnet does not fit good enough to appeal, fabricating a new one.
Will the windshield and grille survive? Will let you know soon.
Very Best Regards,
Old 24th May 2011, 16:12   #219
Thanked: 624 Times
A bit more progress as on today. I am looking at another 10 days at the body shop, which includes getting things done from my end after finishing and detailing of the whole shell.
That is the fuel tank shifted to the rear
(sorry Jaggu), bottom level about 2" below the leaf spring shackles. Also notice the gap between the springs and the tank after the rear spring shift on side beds, it would be about 2" otherwise.
Tail pipe to the left.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0736.jpg
The unfinished bonnet. The new fenders are 11 1/4th" wide as against the original 9 3/4th". I don't intend to use the Classic type fiber extensions which are 1 1/2" too. Slightly reduced the dog ear overhang on the front of the fenders.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0747.jpg
Air vents and fuel inlet provisions.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0741.jpg
The tub, recess in tyre wells for bucket seats.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0739.jpg
Tail lamp position, tyre well recess and widened fenders.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0746.jpg
Bolero hinges, with a 6mm plate reinforcement from inside (thanks GTO).
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0743.jpg
Tail pipe yet to be fixed at the tail end and sawed.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0745.jpg
Old 24th May 2011, 16:46   #220
Thanked: 16 Times
Fazal,
Do you by any chance accept students.....
regards
salil
scphanse is offline   Reply With Quote
Old 24th May 2011, 16:51   #221
JeepCaptain's Avatar
Thanked: 468 Times
A bit more progress as on today. I am looking at another 10 days at the body shop, which includes getting things done from my end after finishing and detailing of [b]the whole shell.
Dear Fazal Sir, What a project this has been. Wonderful transformation.
Your attention to detail has always impressed me.
I think you are in the wrong industry w.r.t your career. You should be in the auto industry building cars/ 4x4's than designing buildings.
You are also blessed with the best tinkers in the country around you in Hyderabad. I envy you on that part.
Just to give you an example.. I have never seen anyone taking so much of effort to make one silencer for his Jeep.
All the Best with your Dog 2 project. Looking forward to see it completed soon.
Shibu
JeepCaptain is offline   (1) Thanks Reply With Quote
Old 24th May 2011, 17:03   #222
Thanked: 624 Times
Shibu,
Thank you.
I love my career as an interior designer, that is where I get my 'attention to detail patience' I guess.
Yes, thank God, there still are good Jeep related professionals on the job here.
Ah! the silencer...I wanted it to be sitting inside the skid plate, without the right angle "L" bends like on 540. Using a 2" CR tube, so as to suit the 2.5L engine exhaust, with least contact and vibrations passing on from the engine to the body.
Drawing out the brackets for auxiliary light and indicators which are not from Mahindra, but should suit this Jeep.
Originally Posted by scphanse View Post
Fazal,
regards
salil
Salil,
I still am learning, so that makes me a student right?
Last edited by Jaggu : 25th May 2011 at 21:41. Reason: Back to back posts, please use Multi Quote (Quote +) instead. Thanks
Old 24th May 2011, 21:39   #223
Dear Fazal Sir,
Awesome project and respect you for your patience..looking forward to see you in AKC/EXAMM.
Suggestion- please put round front fenders.
PATH~FINDER is offline   Reply With Quote
Old 25th May 2011, 00:09   #224
Thanked: 16 Times
Salil,
Dear Fazal,
It definitely does. Anyone in his right senses shld always keep learning. I did associate your sense of aesthetics and detail to your career choice. Nevertheless, I still feel I could be a student under you...
regards
salil
scphanse is offline   (1) Thanks Reply With Quote
Old 25th May 2011, 21:42   #225
Jaggu's Avatar
I love the rear tail gate-less design, even i would love to have it done ie if it gets into a total cosmetic restoration mode. With rear seats those gates are totally useless
The DOG: Is this the Ultimate CJ3B build? 14000rpm 4x4 Vehicles 33 10th December 2011 03:26
A-Star AT, a.k.a "wide-eyed pup", comes home!. pgsagar Test-Drives & Initial Ownership Reports 70 12th September 2011 21:38
whats better than an original cj3b?? two original cj3b's. 0333 4x4 Vehicles 33 5th March 2009 11:15
Shocking news : $166000 paid for a 10 week labrador pup in Florida santanu Shifting gears 0 31st January 2009 19:55
My Pup and I are in a hurry - Schumi drives a taxi ajmat The International Automotive Scene 30 19th December 2007 11:26
