Old 26th May 2011, 09:06   #226
svsantosh's Avatar
Thanked: 1,392 Times
Default Re: CJ3B, 'The Dog 2' or 'The Pup': Should I ??
How much flex is lost due to the rigid tail gate? I am sure at least a little...
svsantosh is offline   Reply With Quote
Old 26th May 2011, 10:23   #227
fazalaliadil's Avatar
Thanked: 624 Times
Santosh,
The chassis flex, if lost should be close to negligible. As the top most area of the tub (tailgate area) would still flex by an inch or two even without the open-able tail gate as the tub flexes and twists along with the chassis.
Originally Posted by Jaggu View Post
I love the rear tail gate-less design, even i would love to have it done ie if it gets into a total cosmetic restoration mode. With rear seats those gates are totally useless
Jaggu,
That gate less design, I have incorporated from Ford. That is the only way to beat the noise and rattle in the tail gate, which crops up in no time, especially after OTR's.
Reenforcement within and hinge plates.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0762.jpg
The bonnet now nearly finished and windshield in place gives some shape to it. Seat is not fixed, just placed. The two black (windshield and grille) are the only surviving parts from the original 340, internal, external and mechanical.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0760.jpg
The widened and shortened front mudguards, in proportion.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0763.jpg
Originally Posted by scphanse View Post
Dear Fazal,
It definitely does. Anyone in his right senses shld always keep learning. I did associate your sense of aesthetics and detail to your career choice. Nevertheless, I still feel I could be a student under you...
regards
salil
Salil,
Thank you.
Yes, a student through distance education.
Note from the Team-BHP Support Team: Please use the "edit" button if posting within 30 minutes of the first post, instead of creating another back-to-back post.
Also use "Multi Quote" option for quoting Multiple posts.
fazalaliadil is offline   (1) Thanks Reply With Quote
Old 26th May 2011, 17:35   #228
Jaggu's Avatar
Thanked: 7,684 Times
Also i see lot of holes in the chassis, isnt it better all those are covered up?
Old 26th May 2011, 18:05   #229
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
^^ On a stock Chassis, manufacturer provided holes are for a reason. If possible, leave them as it is.
Spike
SPIKE ARRESTOR is online now   Reply With Quote
Old 26th May 2011, 18:13   #230
JeepCaptain's Avatar
Thanked: 468 Times
Spike
Yes your honour Mr.Manufacturer!! We will leave them as it is.
Jokes apart when I saw Jaggu's comment I had the same feeling/answer as you Spikey.!
Its so good to have someone from the manufacturer's side in any automotive forum. Thanks Spike for all your contribution to this forum.
Sorry Fazal sir for hijacking your thread. Your pup is progressing well. And I am learning many things from you.
JeepCaptain is offline   Reply With Quote
Old 26th May 2011, 19:39   #231
headers's Avatar
Thanked: 460 Times
^^: The holes in the chassis aid in:
1. Draining water which invariably enters in a jeep
2. Draining Dust and grime out after a water wash.
3. Reduce body weight
4. Improve power / torque to weight ratios
5. To add all fancy attachments for various regulating bodies
Old 26th May 2011, 23:30   #232
Thanked: 16 Times
Fazal,
Just observed on the wind screen those chrome grab handles . I hope you are going to do away with those?
Read earlier you were planning on the roll cage? what kind are you planning to make it? You could integrate these handles in the cage.
regards
salil
PS: I have no problems being a distance education student Sir.
scphanse is offline   Reply With Quote
Old 26th May 2011, 23:59   #233
Jaggu's Avatar
Still for that you need some holes at some points, not all over the place right?? ^^^
Old 27th May 2011, 00:27   #234
Thanked: 757 Times
Are you sure??
@Jaggu, as I said earlier they are there for a purpose. Some are tooling holes, pilot holes, tool access holes, mounting holes, stress relieving holes / slots / notches etc. They can be covered up but nothing substantial will come out of it.
Spike
Old 27th May 2011, 09:39   #235
Thanked: 624 Times
Are you sure??
Spike
Spike,
Yes, thats very true.
One more thing missed, they are holes for both, RHD and LHD fittings on the chassis, depending on the country they would be exported to during WWII.
No point in covering the holes and putting the chassis to the torch. Previous chassis was drilled with holes more than acceptable limits something like "HULLO WHERE IS THE CHASSIS????", hence the change.
fazalaliadil is offline   Reply With Quote
Old 27th May 2011, 09:42   #236
Thanked: 48 Times
fazal bhai
have been following the thread....only now getting the hang of it
technical stuff goes way over my head
the jeep's shaping up grt, one peeve though
pls get rid of the handles on the wind shield
happy build, will see the pup when i come over to hyd next
regards
amar
maverick56 is offline   (1) Thanks Reply With Quote
Old 27th May 2011, 10:22   #237
Thanked: 624 Times
Originally Posted by maverick56 View Post
fazal bhai
regards
amar
Dr. Amar,
Thanks.
The handles on the windshield are there since I bought the Jeep.
Planning grab handles on the roll frame like the DOG.
The Pup, I thought was a Dog, but as it grew up...realized its a cat, and is now rechristened the 'LYNX'.
Old 27th May 2011, 11:19   #238
Jaggu's Avatar
Covering up can be with rubber stoppers Not necessarily weld jobs.
Old 27th May 2011, 11:24   #239
headers's Avatar
Thanked: 460 Times
@ Jaggu: They are called "Gromets"
BTW, we are talking about an antiquated design where the rules were different - It cannot be accepted in todays day and age! Hence Gromets were born [Dont shoot me - this aint from Wiki!!]
Old 27th May 2011, 14:41   #240
Jaggu's Avatar
First of all its grom"m"et. Second though its the popular usage and in parts list, may not be the right technical term.
Grommet - Wikipedia, the free encyclopedia
A grommet is a ring inserted into a hole through thin material, such as fabric. Grommets are generally flared or collared on each side to keep them in place, and are often made of metal, plastic, or rubber. They may be used to prevent tearing or abrasion of the pierced material, to cover sharp edges of the piercing, or both. A small grommet may also be called an eyelet.
Since you always want to be 101% correct, i should clarify. This is what i meant and they are known as rubber plugs.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-plugs1.jpg
Jaggu is offline   (2) Thanks Reply With Quote
The DOG: Is this the Ultimate CJ3B build? 14000rpm 4x4 Vehicles 33 10th December 2011 03:26
A-Star AT, a.k.a "wide-eyed pup", comes home!. pgsagar Test-Drives & Initial Ownership Reports 70 12th September 2011 21:38
whats better than an original cj3b?? two original cj3b's. 0333 4x4 Vehicles 33 5th March 2009 11:15
Shocking news : $166000 paid for a 10 week labrador pup in Florida santanu Shifting gears 0 31st January 2009 19:55
My Pup and I are in a hurry - Schumi drives a taxi ajmat The International Automotive Scene 30 19th December 2007 11:26
