Old 27th May 2011, 15:27   #241
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
Default Re: CJ3B, 'The Dog 2' or 'The Pup': Should I ??
^ Jaggu, you are 101% correct! A grommet also has a hole in it, the pics shown by you are plugs / stoppers made of different materials. I agree with this idea of yours, doable!
I don't understand why the confusion exists between a Grommet and a plug, such an elementary stuff.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 27th May 2011, 19:09   #242
Thanked: 50 Times
Originally Posted by fazalaliadil View Post
Dr. Amar,
Thanks.
The handles on the windshield are there since I bought the Jeep.
Planning grab handles on the roll frame like the DOG.
The Pup, I thought was a Dog, but as it grew up...realized its a cat, and is now rechristened the 'LYNX'.
Yep, lynx sounds very apt
feline grace and all that, epitomizes the jeeps u build
couldnt resist adding an african lynx i came across in kenya
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-dsc00525.jpg
maverick56 is offline   Reply With Quote
Old 27th May 2011, 20:59   #243
jeepster's Avatar
Thanked: 1,035 Times
Reenforcement within and hinge plates.
why a single support channel?
the cj3b type hoods are very flexible so IMO two support channels should be used.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-cj3bdog2.jpg
just a suggestion.
Originally Posted by SPIKE ARRESTOR View Post
^^ On a stock Chassis, manufacturer provided holes are for a reason.
Originally Posted by JeepCaptain View Post
Yes your honour Mr.Manufacturer!! We will leave them as it is.
Its so good to have someone from the manufacturer's side in any automotive forum. Thanks Spike for all your contribution to this forum.
i thought spikey is (or was) from our side.
jeepster is offline   Reply With Quote
Old 27th May 2011, 21:56   #244
fazalaliadil's Avatar
Thanked: 626 Times
Dr. Amar,
Thanks for contributing the Lynx pic. Lucky you.
Yes, the LYNX..is my inspiration on this build for, its compact and powerful character, size to power ratio, its predatory skills in bursts, the wide paws for grip and traction, its height against a short frame...like a SWB.
Even the colour is planned on similar lines, but like the Canadian Lynx (pic. attached).
Trying to emulate the beauty of nature.
Nikhil,
There are three reinforcements from the inside (red arrows) and one planned from the outside which also doubles up as a cosmetic component.
Also, the flexibility is taken care of once the four ends are clamped in closed position.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0762.jpg
fazalaliadil is offline   Reply With Quote
Old 30th May 2011, 14:10   #245
getsurya's Avatar
Thanked: 967 Times
Here goes Fazal again! Very cool.
Fazal Bhai, I am sure that this would turn out to be yet another awesome restoration work/project.
Good Luck! Meet you soon in Hyd!
getsurya is offline   Reply With Quote
Old 29th June 2011, 16:27   #246
Thanked: 626 Times
These WIP photographs are a week old. Presently, colour has been done and the 6 point roll cage is under fabrication.
Entire chassis, differentials, engine with GB, tub were disassembled and sand blasted, primed, filler putty, sanded, WURTH sealant, underbody, RAPTOR truck bedliner and GLASSURIT paint, done at New Mars.
Primer and filler putty done.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0779.jpg
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0782.jpg
Filler putty being sanded.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0785.jpg
Wurth underbody sprayed.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0790.jpg
Differentials back on after paint.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0777.jpg
Spring extended outward with side bed mounts.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0794.jpg
Old 29th June 2011, 17:16   #247
DKG
DKG's Avatar
Thanked: 969 Times
Fazal the shock mounts don't seem vertically aligned? Maybe if you install the base plate of the springs reverse with the shock pin inward they should line up?
DKG is offline   (2) Thanks Reply With Quote
Old 29th June 2011, 18:32   #248
Thanked: 626 Times
Deepak Thanks,
The plates need to be swapped left to right and vice versa, for the pins to be aligned. That is how I had got it from Jannaiah to here with shocks fitted. The mechanic at New Mars did it the standard fitment and corrected it later.
Old 29th June 2011, 19:14   #249
svsantosh's Avatar
Thanked: 1,444 Times
Fazal, Did you get a feedback from Sivakumar (Trammway) on the helper setup on a short chassis? Have you factored that in? You may need to reduce a few leafs all around.
svsantosh is offline   Reply With Quote
Old 29th June 2011, 19:28   #250
Thanked: 626 Times
Santosh,
The Siva experience made me reduce not one but two leafs from the pack. Now it is soft but I got to test it off road to make sure it isn't too soft.
Only after 300 more kilometers I will be able to do the off road run as the engine hasn't done over 200 kms. after the overhaul.
Will keep you updated.
Old 2nd July 2011, 10:29   #251
Thanked: 626 Times
THE ROLL CAGE ( A la the DOG)
A 3.5mm, 2" HR (hot roll) pipe was chosen over CR (cold roll) for its hardness.
Thanks to Prabhu, New Mars...the man behind the entire make over of this project who made it possible to get this job done at his friend, Raji Reddy's fabrication unit, which primarily fabricates Wind Mills.
Mr. Reddy, a wizard took no time in understanding the design of the roll cage in photographs and transformed the images into form. He was personally involved in each and every part of th progress till completion, it was due to him that this beautiful roll weighing about 40 kgs. cage took form.
The bending,
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0818.jpg
and checking (Prabhu on right)
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0817.jpg
4mm ms plates, (notice, RAPTOR bedliner under the plates)
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0813.jpg
Turned and threaded into perfection,
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0819.jpg
to fit into pipe.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0820.jpg
NOTCHING all ends for that perfect fit.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0833.jpg
The product. A six pointer.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0821.jpg
In profile.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0827.jpg
The X design over the front passenger and driver seat was changed for lack of head room, due to full sized seats.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0824.jpg
Removed for,
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0835.jpg
final welds.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0837.jpg
NDMS vs TREPADOR
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0831.jpg
The scrapped tyre bracket.
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_0826.jpg
fazalaliadil is offline   (1) Thanks Reply With Quote
Old 2nd July 2011, 14:15   #252
V-16's Avatar
Thanked: 862 Times
Excellent RC Fazalbhai. Was just waiting for these pics.
Im a little confused about the front two points. Could you kindly elaborate that set up please? Is that where the front RC ends (on the dash) or does it further continue unseen down to the floor? Is it good enough in case of a roll? Will it not tend to snap out or even rip the mount if the pressure is extensive?
Please give close up and also explain as it really looks drool worthy.
V-16 is offline   (1) Thanks Reply With Quote
Old 2nd July 2011, 16:09   #253
Thanked: 626 Times
Gogi Bhai,
The two front ends are fastened on the dash, supported by two solidly fabricated 4mm brackets.
The dash and the whole body is in 16 guage CR, good enough to not let the brackets rip off.
In case of a roll over the load/ stress would be randomly distributed on the 6 points of the roll cage, not knowing which would take the worst hit. But your apprehensions are justified as these two, I too fell are most vulnerable of the six.
I had no choice but to go with this (DOG design) as the CJ340 does not have the leg room to accommodate the pipes till the floor. You can incorporate it in your 550 and pray I don't roll over on the front two points.
EDIT: Prabhu is the guy who did the Hyderabad Rubicon in his body own shop, with Arun, Nazim and Ravvenddrra, all T-BHPians..
The bush threaded inserted inside the pipe is the same one in the previous post.
Old 2nd July 2011, 16:40   #254
Jaggu's Avatar
Thanked: 8,684 Times
Been away from the threads for sometime and what a surprise when i return. Super Fazal saab and love the shade. Exactly what i want in DwArF when he goes in for some cosmetics
Reg Roll cage, is there any way to reenforce the dash point from behind? That should give some additional strength??
Old 2nd July 2011, 17:01   #255
ex670c's Avatar
Thanked: 1,821 Times
Hi Fazal,
Please run the A-Pillar Roll Bars Right Through the floor and also connect them across the dash board to for a "H".
Don't you think the bracket on the dash board will injure the knee/shim and will come off in a roll over and maim the occupant.
PLEASE FOLLOW A TRIED AND TESTED DESIGN, THE INTERNET IS FULL OF THEM.
Arka
ex670c is offline   (1) Thanks Reply With Quote
The DOG: Is this the Ultimate CJ3B build? 14000rpm 4x4 Vehicles 33 10th December 2011 03:26
A-Star AT, a.k.a "wide-eyed pup", comes home!. pgsagar Test-Drives & Initial Ownership Reports 70 12th September 2011 21:38
whats better than an original cj3b?? two original cj3b's. 0333 4x4 Vehicles 33 5th March 2009 11:15
Shocking news : $166000 paid for a 10 week labrador pup in Florida santanu Shifting gears 0 31st January 2009 19:55
My Pup and I are in a hurry - Schumi drives a taxi ajmat The International Automotive Scene 30 19th December 2007 11:26
