Old 8th April 2010, 14:15   #76
vinod_nookala's Avatar
Thanked: 416 Times
Originally Posted by fazalaliadil View Post
Vinod,
Project LYNX: Build this CJ into a powerful, wide stanced, light weight and sized on and off-roader without sacrificing the character of a CJ , minimum cosmetic changes. Yet it should have a distinctively different look and not necessarily like THE DOG. Though its roll over/ frame I might incorporate into my design
I plan to use this CJ on the lines of an SUV, 4 days in city and 2 days out off-roading, OTR's etc. Though I do not have hard core off-roading in mind but do not want this Jeep to be deficient in any way.
Arka,
Sorry, I do not understand this or can decipher it.
Thanks,
Fazal sir,
Please go with Gypsy rims and BFG 235's. You can blindly go with specs what Arka said. I have the same setup on my 540, but steering system is still old type. Gypsy's negative off set rims will provide you that low stance and wide look. It will not look dominating though!
MRCBT he meant Manual recirculating ball type steering box which he has on his vehicle and is on NGCS vehicles. The steering box here sits just behind the front bumper on RH chassis side member. The advantages are less play, more direct steering and lighter steering.
vinod_nookala is offline   Reply With Quote
Old 8th April 2010, 15:05   #77
fazalaliadil's Avatar
Thanked: 626 Times
Originally Posted by vinod_nookala View Post
Fazal sir,
Originally Posted by headers View Post
MRCBT - Manual Recirculating Ball type?
Basically you dont need that steering on a CJ3B as it is a small vehicle
The recirculating ball type, you mean the one in pic,. fitted on my Last MM550. The universal joint type by RANE?
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img_4425.jpg
fazalaliadil is offline   Reply With Quote
Old 8th April 2010, 15:12   #78
Thanked: 416 Times
I think this is the one!! Armada type with idler arm. NGCS type remove linkages from idler arm setup, hence lesser play and more direct steering.
NGCS type set up mentioned in this thread-
http://www.team-bhp.com/forum/4x4-ve...d-upgrade.html (My MM540XD upgrade)
Old 8th April 2010, 15:18   #79
Thanked: 626 Times
Vinod,
I have one brand new set with me with tie rods.
It may not be required for 3B, but since I have it and will only help in making the steering more smoother, I can also go for a bit more wider tyres with this mechanism, will it help is the question to you, Arka and others.
If I am not installing a PS, will it be better than the existing XLO type?
Old 8th April 2010, 15:23   #80
Thanked: 66 Times
fazal bhai,
i have the solution for your 16inch problem,
According to me this will look the best ,
just going from my office back to the garage to click two pictures for you,
shallpost them in ten minutes
regards
Allan
xtreme power is offline   Reply With Quote
Old 8th April 2010, 15:24   #81
Thanked: 626 Times
Originally Posted by xtreme power View Post
fazal bhai,
regards
Allan
Allan,
Thanks Buddy.
God bless you.
Old 8th April 2010, 15:59   #82
Thanked: 66 Times
fazal,
the first two picture are 16" jeep rims widened, they will look killer, with a side pin stripe,
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img00201201004081532.jpg
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img00202201004081534.jpg
the third picture is a gypsy wheel widened, was talking bout a pinstripe like this
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img00204201004081535.jpg
Allan, what engine and GB are you running?
datsun L18 engine,
datsun geabox,
i know ill never stop amusing you, just wait for tpc
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img00207201004081538.jpg
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-img00208201004081540.jpg
Old 8th April 2010, 16:11   #83
Jaggu's Avatar
Thanked: 8,684 Times
BTW, How to compensate for GC with suspension tweaks? Please explain, I have a gypsy with gypsy rims and tyres and I need 6" lift now.
My bad i was mentioning tweaks to improve the break over angles. GC yes since the axle will be low will remain low, remaining (suspended) parts can be saved though. But i dont think 16 NDMS to 15 Radials on gyspsy rims is that big a deal?
If you want 6" lift talk to one and only Mr Spidey Dont really remember whats the lift he is aiming at now lol
Jaggu,
There was a thread which discussed this topic at large and was concluded that there can be no increase in GC by suspension tweaks, but can only be achieved by adding bigger wheels and tyres. Suspension mods can only help in articulation.
Not only articulation, overall lift of the suspended parts right?
Old 8th April 2010, 16:27   #84
Thanked: 626 Times
fazal,
Attachment 325147
Allan,
Thanks, Yes they look very good and stock too. How to widen them???
And what size tyres are they intended for?
Will they be BF 235/70/r16 compatible?
Now you are getting me into a deeper hole.
Old 8th April 2010, 16:28   #85
Jaggu's Avatar
Cut the rim and add a piece in between is what i know of this mod. Best is to get Allen to do it for you and ship you a set
Old 8th April 2010, 17:22   #86
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
IMHO, please stay away from such practice as the wheel rim will be a suspect for failure during- a) Impact loads b) Fatigue loads.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 9th April 2010, 04:14   #87
JeepMkd's Avatar
Fazalaliadil, I wasn't able to take any info about the BFGs today, I only snapped a photo from the Tigar tires I previosly mentioned. They fit the original rim perfectly, but they sit a bit low. Dimensions are 175/80-16. This is the most probable setup that I would go with. They perform great on road and have respectful performance off road. Without a doubt, you can't expect too much from a tire intended for a light commercial vehicle
CJ3B, 'The Dog 2' or 'The Pup': Should I ??-dsc00055.jpg
JeepMkd is offline   Reply With Quote
Old 9th April 2010, 06:51   #88
Thanked: 626 Times
JeepMkd,
It has good and deep lugs, do I feel it is kind of narrow or maybe after inflation it will widen up to the right size. What would one cost in INR and their availability here?
Thank you.
Old 9th April 2010, 07:03   #89
headers's Avatar
Thanked: 464 Times
JeepMkd,
Thank you.
Fazal, i would go for wider lugs for better self cleaning properties!
And yeah, price and availability is an issue in India, I guess
Old 9th April 2010, 09:33   #90
Thanked: 626 Times
Headers,
The BF is a all purpose and good tyre but the self cleaning lugs, it lacks is what I have heard.
The DOG: Is this the Ultimate CJ3B build? 14000rpm 4x4 Vehicles 33 10th December 2011 03:26
A-Star AT, a.k.a "wide-eyed pup", comes home!. pgsagar Test-Drives & Initial Ownership Reports 70 12th September 2011 21:38
whats better than an original cj3b?? two original cj3b's. 0333 4x4 Vehicles 33 5th March 2009 11:15
Shocking news : $166000 paid for a 10 week labrador pup in Florida santanu Shifting gears 0 31st January 2009 19:55
My Pup and I are in a hurry - Schumi drives a taxi ajmat The International Automotive Scene 30 19th December 2007 11:26
