Old 1st July 2010, 14:29   #16
Thanked: 23 Times
Should be interesting. RedMM340 had the Scorpio 2.6 plonked in his MM340.
http://www.team-bhp.com/forum/4x4-te...tml#post834209 (Highly Modified MM340 - Scorpio Powered Beast)
bigman is offline   Reply With Quote
Old 1st July 2010, 14:57   #17
Sabareesh's Avatar
Thanked: 79 Times
Originally Posted by sreerajunnithan View Post
Sabareesh, even 2WD gear box will do, He may have to reduce the length of shaft which goes in the T-18.
--Sree--
Sree, I read that thread with great interest, would this kind of conversion hold true for the double lever t-18 case as well ?
Assuming that I buy a 2.6 CRDe Scorpio engine, get a NGT 530. Will it mate with the t18 2 lever case which is in my JEEP ?
Sabareesh is offline   Reply With Quote
Old 1st July 2010, 15:54   #18
sreerajunnithan's Avatar
I don't see a reason why it should not. Essentially xfercase remains same. Double liver is a simple mechanism whereas single lever has linkages. There is no other difference. I have a single lever T-18 transfercase.
--Sree--
sreerajunnithan is offline   Reply With Quote
Old 1st July 2010, 19:43   #19
Thanked: 655 Times
Sorry if this is a bit of a dampener but the NGT520/530 BA10 2wd gearboxes cannot be directly bolted on with any transfer case. You need an adapter plate for the T18 and a different kind for the BW transfer case.
This is the adpter for the BW transfer case on the right. The adapter on the left is from the stock 2wd gearbox.
http://www.team-bhp.com/forum/attach...arbox-side.jpg
This is the NGT to T18 adapter.
http://www.team-bhp.com/forum/attach...er-housing.jpg
jyobeb is offline   Reply With Quote
Old 1st July 2010, 21:19   #20
1100D's Avatar
Thanked: 2,503 Times
This might turn out to be the offroad package a lot of people are waiting for. Will keep watching.
1100D is offline   Reply With Quote
Old 1st July 2010, 21:58   #21
Amartya's Avatar
Thanked: 450 Times
Really exciting specifications. Looking forward to the build. Have you sourced the 550 as well, and what happens to it's powertrain?
Amartya is offline   Reply With Quote
Old 2nd July 2010, 06:52   #22
joshguy's Avatar
Thanked: 92 Times
Allan where are the WIP picture?
Whats the status of the work as of now
joshguy is offline   Reply With Quote
Old 2nd July 2010, 14:19   #23
Thanked: 66 Times
pictures soon
work started today
need to source parts
yes 550 is from my army stock
the original drive train goes into my stock
Originally Posted by GoSlow View Post
Hi Allan
This should be an interesting project. Please dont let the thread die. We need constant feedback from you as to what's going on!
What lockers are you planning to use?
Ankit
aussi lockers for now
just trying to source them
anyone knows of anyone coming down from usa
Another Head Turner from Allan
* Composite leaf springs in the rear(they come in hard n soft versions)
Thats a Good news for jeepers and what about the cost of it??
* power steering
Which PS are you gonna use ?From Armada,Bolero ???
ALL the best for the Project and as someone said let it not be ORANGE/Blue PLS
the jeep ones are 20k i think
ps will be of the bolero
no blue or orange
dark matt grey will be the colour as of now.(that with a bit of red)
Originally Posted by Jeepfreak View Post
Allan, we all know mechanically you will be doing an awesome job, but please color it something different this time, no more orangie )
- Fahad
point noted
Originally Posted by The Wolf View Post
Oh, looks like we have a home made Thar killer
On a serious note, cant wait to see the completed product. Do you have good mechs in mumbai when it comes to these things? Ive heard a lot from only up north so far...
Allan, what are floating seats, one with springs like in a chopper?
no mechs this time, doing it myself
seats will be normal, floating will be the base as used in the old pajeros, the have shock absorbers and springs for comfort
xtreme power is offline   Reply With Quote
Old 7th July 2010, 18:20   #24
Thanked: 66 Times
heres the update
happy feet shall dance tonight,(health permiting that is)
special thanks to jyobeb and arka for answering all thoses calls and for all the information.
i myself just transformed the 2wd ngt530 to a 4wd ngt530 with a manual borg warner transfer case
thanks again for all the help, rest assured lots more calls till this project is complete.
pictures as soon as i find the usb (during tonights match)
Old 7th July 2010, 18:24   #25
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
Please post WIP pics. How much did the engine and tranny cost you?
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 7th July 2010, 19:55   #26
Thanked: 655 Times
Glad to be of help Allan.
Just one more thing. If the tyres you plan to use are 31 inchers, you will have to change your diff ratios to 5.375:1 (43/8). Anything bigger and you will need the 5.75:1 diff.
Using the stock 4.88 ratio will rob your engine of all power.
Old 7th July 2010, 20:55   #27
Jassy1313's Avatar
Thanked: 56 Times
Originally Posted by xtreme power View Post
heres the update
where did you get this transmission from?
Jassy1313 is offline   Reply With Quote
Old 8th July 2010, 14:50   #28
Thanked: 66 Times
ok here goes,
project on in full swing
body has been removed off the chassis to start full sanding of the body as well as the chassis
Name:  Resize of DSC02964.JPG
Name:  Resize of DSC02963.JPG
the engine
Name:  Resize of DSC02970.JPG
the ngt 530 3wd gearbox
Name:  Resize of DSC02951.JPG
Name:  Resize of DSC02952.JPG
the ba10 4wd gearbox with the manual borg warner transfer case
Name:  Resize of DSC02954.JPG
Name:  Resize of DSC02955.JPG
now the process to remove the transfer case from the ba10 and put it onto the ngt530
Name:  Resize of DSC02956.JPG
Name:  Resize of DSC02958.JPG
Name:  Resize of DSC02960.JPG
Name:  Resize of DSC02962.JPG
and voila the ngt 530 with the manual borg warner tranfer case, what some say is rare
Name:  Resize of DSC02967.JPG
Name:  Resize of DSC03062.JPG
Name:  Resize of DSC03064.JPG
aussie lockers are on their way
Old 8th July 2010, 15:01   #29
ex670c's Avatar
Thanked: 1,821 Times
Default Sleeper
Hi Allan,
Nice JEEP, Nice Colour and Nice Mechanical Upgrade.
Now for a Custom Skid Plate & Winch Plate.
Keep 4.88:1 Differential Ratio and Maxxis Big-Horn (245-75-16 Tyres on the Army Rims and Rear Auto-Lockers)
I would suggest to keep the looks sober, like a stock Army MM550XD, but the performance will be scorching.
Very Interesting Project.
Arka
Old 8th July 2010, 15:35   #30
Thanked: 809 Times
Hmm, interesting. This combination ^^ is present in a few export 4wd models.
Spike
PS- Allan what about the rear propeller shaft. Is the position of the transmission mounting cross member the same?
Review : Philips Xtreme power bulbs for my M800 para_7k Modifications & Accessories 50 8th August 2012 15:08
Mahindra Scorpio's Photos - Scorpio Xtreme hotkar Modifications & Accessories 35 3rd March 2012 23:43
Happy Birthday xtreme power and aveek Aditya Shifting gears 10 27th September 2009 20:28
Birthday Wishes for xtreme power egangsta Shifting gears 10 2nd June 2007 17:07
