Old 10th September 2010, 23:41   #31
Thanked: 27 Times
@santosh
Even if your battery went dead, the alternator/dynamo should have substituted for it. So in this case did the alternator quit ?
In event of a transmission wind up, flat tow is not recommended hence propeller shafts required to be disconnected.
Timson is offline   Reply With Quote
Old 11th September 2010, 11:10   #32
harjeev's Avatar
Thanked: 256 Times
I was wondering that if we have to tow the vehicle and its is not possible to remove the propeller shaft, would it help if from the 4x4 lever we slot it into neutral and keep towing the vehicle?? This was the vehicle's gearbox & transfer case would not be engaged!
harjeev is offline   Reply With Quote
Old 11th September 2010, 19:39   #33
Thanked: 27 Times
@harjeev
Ya the method you suggested would work fine if the damage was in the main transmission/gearbox, but if you had a situation as Arka mentioned regarding T-Case having damage like the Main Shaft Gear Nut giving way, this method won't work as the main shaft of the T-case will keep spinning even in the Neutral position, hence creating more gear damage.
In case you have FWhubs in the front you could set it to the free position and for if the rear axels are of fully floating type you could remove either both axle or just the end flanges, and then cover the hubs suitably to prevent dirt contamination. This way you could save on the prop-shaft removal.
Old 13th September 2010, 10:17   #34
ex670c's Avatar
Thanked: 1,799 Times
Default Flat Towing
Hi Harjeev,
It doesnt matter if you slot the Main Gear Box or T-Case in Neutral.
When a vehicle is being towed the wheels rotate at a speed, then the axles rotate the Diff, the Diff rotates the prop shaft at 4-5 times the wheel speed, there by rotating the Gears in the Gear Box, and even the Engine.
The CJ3B Page has the issue covered much better.
Towing a Jeep on The CJ3B Page
Arka
Old 13th September 2010, 10:41   #35
Tejas@perioimpl's Avatar
Thanked: 5,059 Times
Originally Posted by ex670c View Post
Hi Harjeev,
Arka
I remember having this discussion on the towing thread and the best option decided was to go for a FFRA (as suggested by Arka) and have FWHs on the rear too. Unlock both and tow without tension.
Tejas@perioimpl is offline   Reply With Quote
Old 13th September 2010, 13:10   #36
Rajachu's Avatar
SVS,great narration.Dev seems very good navigator.And Shibu congrats for your new possesion.
Raj
Rajachu is offline   (1) Thanks Reply With Quote
Got Jeep! CJ3B Hurricane. Jaggu 4x4 Vehicles 695 1st April 2015 08:50
2011 i10 Asta A/T - its Korean, its new, its fast, its red, and its coming. nirupesh Test-Drives & Initial Ownership Reports 1 8th January 2011 10:45
Hurricane is "Gone" ... Long Live the Hurricane RAINMAKER 4x4 Vehicles 11 21st April 2010 09:28
Away from hustle bustle of bangalore jassi Travelogues 9 3rd July 2007 12:03
The Jeep Hurricane Neel The International Automotive Scene 4 23rd February 2005 15:51
