Old 30th October 2010, 19:48   #16
IQBAL VEERJI's Avatar
Thanked: 282 Times
Boss give me full details of your existing engine Year of manufecture, whatever maximum information you get from your physical inspection or service book ,owners manual and also your budget for replacement I will definately find out solution to you problem
Last edited by GTO : 31st October 2010 at 19:47. Reason: Quoted post has been deleted
IQBAL VEERJI is offline   Reply With Quote
Old 31st October 2010, 19:50   #17
Thanked: 91,641 Times
Originally Posted by boeuff View Post
I will PM you the number of the chap that maintains my car in Mysore. He does all the work on my car and is really good.
Hi Boeuff, why PM? Please share the information out here on the public forum itself. That way, it'll help countless other members & guests.
Remember, PM'ing useful information defeats the purpose of this forum
GTO is offline   (1) Thanks Reply With Quote
Old 31st October 2010, 20:28   #18
Mpower's Avatar
Thanked: 1,682 Times
First get your timing issue sorted. The powerloss could be because of that. Replace all gaskets and o-rings wherever you see leaks. Then do a compression test.
Where are you losing oil. Do you have blue smoke or is leaking out?
Old 1st November 2010, 06:37   #19
harjeev's Avatar
Thanked: 256 Times
As all member above me has said, the engine re-build/ replacement should be the last resort. Now that you did a 1500 kms trip shows that the engine is ok and can be trusted and relied upon.
As Arka and Mpower and others have said, try sorting out the issues one by one and then take a call.
A picture speaks a 1000 words, Please post pics of the places you see oil leakages
harjeev is offline   Reply With Quote
Old 1st November 2010, 20:08   #20
boeuff's Avatar
Thanked: 63 Times
Good thought,
His name is Ravikiran, Bharathi Motors Mysore. Mobile 9845341324
boeuff is offline   Reply With Quote
Old 1st November 2010, 20:58   #21
narendra.vw's Avatar
Thanked: 401 Times
Firstly I want you to check the engine your self. Start the engine, does it crank smoothly, starts immediately. If so then engine life should be partly good. Next leave the engine running for normal temp. Next remove the oil cap while engine is running. See if any smoke is coming out of valve door. See if oil has burning smell. Pull the oil dip stick check for any white smoke coming out of it. If yes then it means engine has lost its life. Least you can do is change piston rings to slightly over size, it really works. Change all oil seals( cam, crank etc), give pump for recalibration . For these work to be done a mech is in Banreghatta road is the best for pajero. Need any help pm me.
narendra.vw is offline   Reply With Quote
Old 23rd February 2013, 22:54   #22
breakneck's Avatar
Thanked: 18 Times
Default Re: help required for a pajero engine rebuild
can someone help me source a engine for my 1996 pajero,its a 2800cc turbo diesel engine the model no is 4m40t its similar to the one sold in india.
breakneck is offline   Reply With Quote
Old 24th February 2013, 09:53   #23
Thanked: 647 Times
Talk to Kannan in Chennai. No is 9444051901.
jyobeb is offline   (3) Thanks Reply With Quote
Old 24th February 2013, 20:22   #24
breakneck's Avatar
Thanked: 18 Times
Thanks a ton jyobeb,
spoke to Mr Kannan,he said he only has the bottom half but could arrange for a delica engine which is similar to the one in the pajero and get it installed at a known garage.he said it would cost about 1.5.Is he trust worthy and is that a good price?
Old 25th February 2013, 09:21   #25
Thanked: 647 Times
The difference in the Delica engine is the oil filter placement and maybe the sump, both of which can be fitted from your old engine. Kannan is a very dependable person, but you could bargain a little more with him. His stuff is usually very good quality. You can tell him John (me) referred you to him.
By the way the imported 4M40 engines are about 10bhp up on power over the Indian built ones!
jyobeb is offline   (1) Thanks Reply With Quote
Old 25th March 2013, 13:38   #26
mashmash's Avatar
Thanked: 117 Times
That sounds good. Are you going in for the transplant?
BTW didn't you try going back to the Pune mechanic who did the rebuild?
Do keep us updated.
MaSh
mashmash is offline   Reply With Quote
Old 13th June 2013, 11:45   #27
Default Need help for sourcing parts for Pajero
So, the driver abused the car on the expressway leading it to over heat and stall. On towing the car to the authorised here's the list of parts that they came back with,
Part Number Description Qty
ME193804 HEAD ASSY ENG CYLINDER 1
ME200752 GASKET CYLINDER - 2DOT 1
ME200403 GASKET ROCKER COVER 1
ME202687 VALVE INLET 4
ME202688 VALVE EXHAUST 4
ME203754 GLOW PLUGS 4
ME241213 VALVE STEM SEAL 8
tantricindian is online now   Reply With Quote
2lac+ kilometers m800 engine rebuild project. SirAlec Modifications & Accessories 75 24th June 2013 17:36
MM550 rebuild - new engine ? bigman 4x4 Technical 25 5th July 2011 21:58
Gyspy Engine Overhaul / Rebuild jealousdiamond 4x4 Vehicles 13 2nd February 2010 12:23
Sluggish Accent CRDI after engine rebuild. clipto333 Technical Stuff 30 10th March 2008 23:44
