Old 19th April 2012, 21:30   #91
1100D's Avatar
Thanked: 2,369 Times
Default Re: Marengo- Rocky Beige Scorpio mHawk 4WD- Only one in India till now (Updated with
Checking not the locking part, but the unlocking/ relocking part.
Sutripta
Have done that too. After the wheel lets go off the hand, revved upto around 30kmph and then stopped the wheels from spinning. After that it was a simple check to see if they were able to hold onto that wheel again after it was allowed to spin at idling rpm.
However, I did not really need to check for the functionality because had experienced this thing on a Chevrolet Avalanche Pickup (on which this was offerred as a standard equipment) a few years back. The guy simply hoisted one wheel on a roller fitted hydraulic jack and the spun to lock. Drove upto 20 mph and then it lost power, although he could activate it again by spinning.
1100D is offline   (1) Thanks Reply With Quote
Old 19th April 2012, 21:49   #92
Thanked: 2,132 Times
Was not talking of the speed > ~ 30 Km unlocking, but of the unlocking/ relocking which should occur if the wheels alternately meet slippery patches.
Sutripta
Sutripta is online now   Reply With Quote
Old 19th April 2012, 21:58   #93
1100D's Avatar
Sutripta
That wont happen. Once locked, the axles will continue to be locked till the > 30kmph event happens.
For example, if any wheel spins at a 100rpm differential at a vehicle speed lower than 30kmph,the differential will be in locked state. Will remain that way, as long as one does not exceed 30kmph.
Thats why I mentioned, that I would still prefer a proper diff-lock with manual controls to lock, unlock. Their e-locker does that.
Old 19th April 2012, 22:03   #94
That's why I want to check it out!
Sutripta
Sutripta is online now   (1) Thanks Reply With Quote
Old 19th April 2012, 22:09   #95
1100D's Avatar
Sutripta
As I mentioned, feel free. However, any tests,personally, i wont like being done on tarmac. Because where I intend to derive some value out of it, mainly on our farm lands, I wont have to bother about moving about in a locked state for a little extended duration, without being able to reach the 30kmph threshold.
Old 19th April 2012, 22:20   #96
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
Thanks. But essentially same as the other clip, but in colour. No added information (other than the detent about 0 speed diff).
Oops, I did not notice that a similar video has been posted. My mistake.
There is a better video with explanation, let me try to dig that out.
Please let us know of your findings.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 19th April 2012, 22:49   #97
1100D's Avatar
Another Video
1100D is offline   (2) Thanks Reply With Quote
Old 20th April 2012, 10:28   #98
pjbiju's Avatar
Location: Karamattom, Aluva, Kotagiri, Yercaud, Hospet, Indore, Nashik, Pune (now)
Thanked: 461 Times
Originally Posted by SPIKE ARRESTOR View Post
Inside the Eaton G80 Locker
Spike
Spike,
Is this a direct fit in Thar CRDe too?
pjbiju is offline   Reply With Quote
Old 20th April 2012, 10:44   #99
fiat_tarun's Avatar
Thanked: 585 Times
Originally Posted by pjbiju View Post
Spike,
The Thar uses the same Scorpio axle, so it is a direct fit for the Thar
fiat_tarun is offline   (1) Thanks Reply With Quote
Old 20th April 2012, 21:45   #100
1100D's Avatar
Well! A project that will now remain WIP forever. Because I shelved it.
Marengo: Rocky Beige Mahindra Scorpio mHawk 4WD & MLD. 4 years & 1 lakh kms up!-140420126201.jpg
Old 21st April 2012, 20:20   #101
Spike
Best checked on a bench. Pls. donate me one, and I'll let you know the results!
Sutripta
Old 21st April 2012, 20:47   #102
Thanked: 757 Times
Spike,
Tarun, has answered your query and he is right. It is a direct fit only on the rear axle.
Locking / unlocking we have checked enough times and I know how to lock and unlock this thing (not posting details in this thread due to some reasons) . I thought you were really going to check this out; may be you could find out something which we 'may' have missed. Some trials were still undergoing while I left in between, hence this query and anxiety.
Tell me what kind of bench you want and we can arrange it in Kolkata.
Spike
Old 21st April 2012, 21:03   #103
I really want to check it out, but don't see how. Requires stripping, measuring, ... (You know the drill). The rest (bench, road) is a validation and checking for anomalies run.
Would also like to do it with the gerotor design. (The principle appeals to me more)
Was asking for you to donate the unit, not the bench!
Sutripta
Old 21st April 2012, 21:11   #104
Thanked: 757 Times
^^ Ok, now I understand what you were referring to - a sample, I thought it as a test bench. And you are right, the process for analysis is pretty tiring, time consuming and cumbersome.
May be Tarun can help us with a sample, I am sure there must be plenty lying around with him unused for different reasons.
Spike
Old 21st April 2012, 22:13   #105
Your test bench: Did you just control/ measure speeds? Or also torque?
Sutripta
Life with Scout, my Mahindra Scorpio mHawk SLE - 7 years & counting comfortablynumb Long-Term Ownership Reviews 62 17th October 2017 12:12
The Intrepid Explorer III - Rocky Beige Mahindra Thar desertfox 4x4 Vehicles 111 24th January 2016 01:10
Scorpio VLX mhawk 4WD with Air Bags EDIT - 43000 kms update 4x4addict Long-Term Ownership Reviews 110 11th April 2013 16:16
Old Scorpio Mhawk>>> New Scorpio Mhawk rishin.kalra SUVs, MUVs & 4x4s 9 21st July 2009 15:51
