Old 8th August 2011, 10:02   #16
Baburajs's Avatar
Default Re: My CJ340 Rebuild - A thought
My new FWH are not working fine. The right side is stuck and not moving at all. Removed it cleaned with diesel and refitted . but no avail. Looks like the front moving part is slightly bend . My 3500 odd bucks gone up in smoke :-( . Have to check for a new one now.
Baburajs is offline   Reply With Quote
Old 10th August 2011, 10:36   #17
Baburajs's Avatar
Guys I have a small problem. I feel that the idling speed of my Jeep is a little high. But the adjustment screw is in the maximum limit or low idling. So what can be the problem. Can we still adjust the idling of the jeep . If yes then how.
Babu
Old 10th August 2011, 14:57   #18
svsantosh's Avatar
Thanked: 1,444 Times
See if the throttle cable is too tight and binding on the throttle clamp. Dont go by the pedal play - doesnt matter in a old jeep. See if the clamp can get any more play/loose by opening up the screw that holds it in place. If all fails - go to a MICO pump repair shop and check for timing advance/retard.
svsantosh is offline   Reply With Quote
Mahindra: Difference between a Classic and CJ340 bhoise 4x4 Technical 81 25th September 2017 19:44
Mahindra CJ340 joins Team-BHP family Samurai 4x4 Vehicles 1469 6th July 2017 14:42
Using MM540 axles in CJ340 Samurai 4x4 Technical 50 30th June 2009 02:04
CJ340 conquers the hill... Samurai 4x4 Excursions 29 11th August 2008 22:06
Upgrading brakes on CJ340 Samurai Modifications & Accessories 54 18th June 2008 08:25
